RP Supercat vs. SR Motorsports
Old Jan 26, 2006 | 08:18 PM
urby1970's Avatar
Old but Proud
Who has the best high flow cat? I have been researching the two above and can't decide which one to buy. I also want something that throw the CEL.
I appreciate your help!
Thanks,
Urby
Old Jan 26, 2006 | 10:19 PM
Fanman's Avatar
I had both. Currently running the RP Supercat. Both of them are very high quality pieces. Both very well made. I had them put a resonator/silencer on my SR unit ($59 option), and it was very quiet. I sold it at the time because it made my Greddy turbo pop/backfire, but later on I got them to tune that out. I wish I had kept it. But you can't go wrong with either one. The RP unit is a bit louder because it does not have the silencer on the unit.
Old Jan 26, 2006 | 11:20 PM
southwest8's Avatar
I currently am running the sr with the silencer/resonator option. Sounds almost stock to me(passed the girlfriend test! she didnt even notice). The only difference I can tell is the backfire when I let off around 8000-8700rpm when shifting at times. Other than that I think it sounds pretty much stock. If I could do it over again I would order without the resonator, but thats just me.
Old Jan 27, 2006 | 01:05 AM
BoosTED's Avatar
I have the SR unit without the resonator and the Greddy SP2, my wife didn't notice a difference!!!
I certainly did though
What I like about the SR cat is it has the hanger, RP didn't the last time I checked.
I just installed the Canzoomer 1.1 and will be tuning out the pop.
Under normal driving there isn't any pop of the exhaust but if it is revved a few times up into the 8s it will give a couple without tuning.
Not sure on a stock catback exhaust though. Malamore may be able to give feedback on that.
Those that have aftermarket cats does it help to have the Revi?
Old Jan 27, 2006 | 01:59 AM
Fanman's Avatar
Yeah, that's the way I like it. Near stock at idle levels, and opens up at WOT. I'm older (34) so I don't really like it too lod. I guess it just is really up to the individual. My setup with the SR Motorsports hi-flow cat (w/ resonator) & RB Catback exhaust was probably the best sounding setup I had.
Old Jan 27, 2006 | 02:10 AM
echoj8's Avatar
I've been looking at hi-flow cats and my only concern is the exhaust heating up more than normal causing the bumper to melt some. Any truth to this? Thanks
Old Jan 27, 2006 | 02:45 AM
no,
Old Jan 27, 2006 | 03:38 AM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
im looking for the best high flow cat for my borla exhaust.. and i dont know which would sound a little louder but doesnt have the popping noise?
Old Jan 27, 2006 | 03:41 AM
BoosTED's Avatar
I believe they both will.
It's worth it though.
You can always get an aftermarket ecu and tune it then you will get even more power and a smooth sound.
Old Jan 27, 2006 | 06:28 AM
Whitehot's Avatar
Mr. Clean
This only happened after I installed my RP Supercat midpipe. Went for a test drive up my favorite mountain road and smelled burning plastic. It wasn't a big deal, I just trimmed a bunch of the plastic off the exhaust shrouds and its been fine after that. It was a pain in the *** to get the melted plastic off the tips though.
Old Jan 27, 2006 | 08:17 AM
urby1970's Avatar
Old but Proud
Thanks for the response. Now I know they are both good products. I will decide here shortly, and let you know how it goes after I get it installed
Old Jan 27, 2006 | 11:58 AM
urby1970's Avatar
Old but Proud
FanMan, Did you throw a CEL with either of them?
Old Jan 27, 2006 | 12:51 PM
Fanman's Avatar
Nope. Both functioned fine.
Old Jan 27, 2006 | 01:08 PM
dgcls's Avatar
did any of you guys install any of these units before adding a catback? i'm curious to know whether or not a catback is worth adding in terms of gains. i really don't care so much about the sound. i know the cat pipes will def make gains... please help.
Old Jan 27, 2006 | 01:21 PM
Red Devil's Avatar
I have the RP cat and OEM cat-back. Never had the car dyno'd. I do think the car feels a bit more peppy in the upper rev range, but nothing that will blow you away. The sound is throaty and more aggressive. That said, I revved mine next to someone with just a Racing Beat cat-back and theirs was louder than mine.
Old Jan 27, 2006 | 01:24 PM
cdove's Avatar
I have the rp supercat installed with the stock exhaust. I think it sounds great pretty quiet (my wife coudnt tell the difference) Performance gain is definately noticeable.
Old Jan 27, 2006 | 01:59 PM
dgcls's Avatar
i'm starting to realize that the only reasons for upgrading our exhaust would be for a nicer sound & reduced weight. i think simply swapping out the cat pipe is the way to go if you're on a budget...
Old Jan 27, 2006 | 02:04 PM
Red Devil's Avatar
I swapped out my cat for the high-flow unit simply because I know how loud a rotary can be and didn't know about doing both that and a cat back system as I feared it would be too loud. And since I plan on using some sort of FI, I didn't want the heat generated from the engine to burn through the OEM cat. For me, replacing the cat was the more logical choice. That said, now that I've had the cat for the last ~10K, I'm probably going to do a cat back at some point in the near future also.
Old Jan 27, 2006 | 05:06 PM
jays8's Avatar
i have the rp supercat and the RB exhaust and it sounds perfect. I had the RB exhaust first and the sound was fine, but no real noticeable power difference, but as soon as i added the rp supercat there was more power and the tone was perfect. I highly recommend the supercat. No cel's,6000km, just remember to swap the gaskets and you will be fine. A hanger was a 2 second job to put on. good luck.
Old Jan 27, 2006 | 08:26 PM
urby1970's Avatar
Old but Proud
Who did you have put the hanger on. You got some pics of your work. I was thinking of jerry-rigging something. I am leaning towards the SuperCat but I am concerned about getting the hanger on
Old Jan 27, 2006 | 08:48 PM
OBryanRX8's Avatar
happy rotoring
no need to jerry rig anything just stop by a local midas or exhaust shop and have them cut off old hanger and weld on to rp cat
Old Jan 27, 2006 | 09:33 PM
urby1970's Avatar
Old but Proud
Thanks bud, I think it is the Supercat then.
Old Jan 27, 2006 | 11:44 PM
jays8's Avatar
no need to cut off the old hanger....a good muffler shop will put a new one on. Then you can keep the old cat intact.
Old Jan 28, 2006 | 02:51 AM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
is your rp super cat resignated??
Old Jan 28, 2006 | 05:19 AM
chrism's Avatar
Misfit Moderator TnC
i have the rp supercat/midpip with the b & b exhaust.....i didnt have to have a hanger welded on...its just fine without it.....mine is just silly loud though......but you do notice a difference!
