e-manage ulrimate wiring Q
Old Jan 25, 2006 | 11:14 AM
adofly's Avatar
I am trying to wire the ultimate on the RX8, please give me some help on how to wire up the ignition and injector harness, how to wire the 4 ignition channeLs on to RT FT FL RL, which chanel goes where?
Also about the injectors which chanel goes to FP1 RP1 FS and RS.
Any help appriciated
Old Jan 25, 2006 | 08:45 PM
rkostolni's Avatar
I believe Jeff (MazdaManiac) attempted to install the emanage ultimate, but found it is not currently compatible with either the ignition system or the fuel injectors. It is being used as a paperweight until Greddy releases a patch. Unless Greddy has already released this patch, I believe you may also have a rather expensive paper weight.
Old Jan 27, 2006 | 01:11 AM
adofly's Avatar
Thanks, but why Greddy include the RX8 in the manual then? They should have a note regarding the RX8.
Anyways, I'll connect only the Airflow and adjust a/f.
In your opinion, what a/f ratio makes more power but reliably on the RX8?
I heard that these cars are too rich from the factory.
Thanks again guys!
Old Mar 4, 2006 | 04:50 PM
fito's Avatar
The diagram for MT is NOT supplied in the manual, greddy knows it and if you call them, the'll e-mail it to you.
Old Jul 15, 2006 | 10:03 PM
mysql101's Avatar
or just get the premade harness :>
tjohnmeyer
Sep 28, 2017 05:03 PM
Danield97
Sep 30, 2015 05:59 PM
Quiggs321
Sep 30, 2015 05:34 PM
jer2911
Sep 29, 2015 06:37 PM
Learners_Permit
Sep 27, 2015 07:38 PM
