Jyariten
01-23-2006, 09:12 PM
I installed a Defi link display controller and VSD concept controller in an ashtray.
I changed the surface rough finish of a cover of an ashtray for the painting in piano black in D.I.Y.
rkostolni
01-23-2006, 09:19 PM
Looks great. What paint did you use?
Jyariten
01-23-2006, 10:14 PM
HOLTS Spray Paint.
I do polishing in sandpaper (#1500) after having painted it.
I improve it in Compound of ultra-fine particles afterwards.
Alex_
04-13-2006, 09:10 AM
Only one question...where do you take electric cable? i.e. did you connect defi controller to ECU or did you use another cable? Do you have photos or other , I want installa a control unit by my self but I need some image :)
Thank you
Jyariten
04-13-2006, 09:41 AM
Please see this site.
http://www.nippon-seiki.co.jp/defi/car/list.html
Alex_
04-14-2006, 01:32 AM
I know, but for me it's difficoult understand, there are some images that explain everything?
Thank you
takahashi
04-15-2006, 07:02 AM
Hey since we have CAN diagnosting system. I think we cannot get a line from the ECU that single out the tachno speed whatever and it has to get it from the CAN slot - under your steering wheel.
http://www.nippon-seiki.co.jp/defi/car/rev.html
Here - plug it in and hook up the wire.
BigOLundh
04-19-2006, 05:28 AM
I am interested in refinishing the ashtray lid to piano black.
Does the lid just pop right off?
mcstin
01-22-2007, 01:25 PM
Is there a D.I.Y. for removal of the ashtray/lighter compartment as shown in the 2nd picture? I am trying to remove it, and cut a hole in the piece on bottom left of the picture so I can put my Ipod in there.
chickenwafer
01-22-2007, 05:06 PM
to remove the ashtray:
-unscrew and remove the shift knob, set aside
-reach to the center console panel (where the e-brake is) and reach under the handle and tug up on the panel. One side will pop up, then pull up again and remove and panel. If you have heated seats or a nav system unplug the connectors.
-There are two Phillips head screws holding in the ashtray. Unscrew them and then simply pull the ashtray assembly towards you. It will pop out just like the center console panel did. Unplug the connectors and the ashtray is free.
Pretty easy
Dave
mcstin
01-29-2007, 10:42 AM
Thanks for the help. It went just like you said.
4 years to Supercharge
04-22-2008, 04:17 AM
Jya riten do you have any pictures of the VSD?
