2200°F Metal Cat
Old Jan 20, 2006 | 04:03 PM
Slick8's Avatar
2200°F Metal Cat
Originally Posted by Maniac
Supreme Performance http://www.supremeperformance.com offers a converter called "MetalCat".
I don't think is available quite yet, but the rep at SEMA said it will be available by the end of the year.
The element is made of steel instead of ceramic and will survive up to 2200°F.
Anybody? Search Google with no real answers.
Old Jan 20, 2006 | 04:59 PM
there are plenty of metal cats, haven't seen any yet that will survive 2200 degF continuous, not even $1000 max racing cats, MetalCat is an OK brand though
you didn't try very hard, last I heard they were not being marketed in the US:
http://www.arvinmeritor.com/products...convertors.asp
http://www.metalcat.com.au/
a low cost hi-flo metallic sold here in the US is PowerCat by Dynatech, most of the discount auto aftermarket places sell the (Jegs, Summit, etc.) they go for $150 - $180 each in 2.25", 2.5", and 3" in/out sizes, the cat size is the same for all three, I don't know the temp limitation specs on them though
Old Jan 21, 2006 | 12:24 AM
Slick8's Avatar
I got those links too, still not much to go by...
Old Jan 21, 2006 | 08:00 PM
Did you try contacting Supreme for a release update? It's shown on their website, but they are a large scale supplier, not retail sales. They distribute through AutoZone, so once it's out it should be easy to get.
Old Jan 21, 2006 | 09:59 PM
Slick8's Avatar
I called them last Friday, but the techs have already left for the day. I'll call again Monday to ask questions. I just want to check if the 2200 F claim is baseless or true.
Old Jan 21, 2006 | 10:26 PM
peak maybe, but I have a hard time believing continuous
fwiw there's no advantage for them to use type 316L stainless for the case rather than the usual type 304 on an automotive exhaust application, it just costs more. Typical marketing BS.
Old Jan 21, 2006 | 11:20 PM
Slick8's Avatar
I burned out my random tech high flow cat, but got a new one from warrantee. The ceramic substrate started to deform from the heat and was loose. Just curious to see if the metal substrate should be able to handle more heat without deforming.
Old Jan 21, 2006 | 11:22 PM
random tech now sells metallic cats too
do you have the SR Motorsport cat pipe? They appear to use a ceramic Random Tech cat.
Old Feb 8, 2006 | 07:43 PM
boostedrx8's Avatar
that's some high temps .. is that really necessary
Old Feb 8, 2006 | 07:59 PM
StealthTL's Avatar
Metatron
Exclamation Random Shmandom.....
I wouldn't bet on a stainless steel substrate Random unit, in his early testing, Canzoomer blew the guts out of one in about three days.
S
Old Feb 9, 2006 | 10:28 AM
olddragger's Avatar
In doubt about exhaust temps? Ever see a rotary engine with a single wall exhaust header? Find one then you will have some idea how hot it gets!
olddragger
Old Jun 2, 2006 | 10:20 PM
SC-ed's Avatar
Check this out:Metal Cat
It retails for $180.
The part# listed matches the Supreme Metal Cat one.
I'm asking the seller is it real thing?
Old Jun 3, 2006 | 03:49 AM
Dan 8's Avatar
There are a couple of guys here in OZ running with metal cat and so far no problems with them
The one on ebay seem to look like the real deal they do come with a 5 year warranty .
92trbolzr
May 18, 2025 09:04 AM
mdl0209
May 23, 2019 05:46 PM
Evan Gray
Nov 24, 2015 01:00 AM
XianUnix
Sep 29, 2015 03:48 PM
FubarI33t
Sep 28, 2015 08:45 PM
