joestewart
08-04-2003, 11:26 AM
I can't get the homelink system to accept the garage door opener codes from my Sears GD opener. Homelink indicator Light does not flash as indicated in the manual when the opener is activatred.
Anyone had any success?
Doctorr
08-04-2003, 11:37 AM
*1 Make sure you hold it for long enough - 20-30 seconds.
*2 Mine did not like the key chain remote but took 'old clunky' OK.
*3 Try another button, #3 (seemed) to take it easier?
doc
Gord96BRG
08-04-2003, 11:38 AM
Yup - I have a Sears opener with the rolling code security, and have it working fine from the Homelink.
I just followed the manual, but from memory - hold the old remote opener button and the Homelink button down at the same time (remote about 2 inches away from the mirror) until the Homelink light changes flashing speed (it starts slow and then switches to fast flashes after 30 seconds or so - or else it starts fast and changes to slow, I don't recall which!). That trains the Homelink to be a rolling code remote - THEN you have to press the learn button on the opener itself, then run down the ladder and press and hold the Homelink button. That should synchronise the Homelink with your opener.
Regards,
Gordon
joestewart
08-04-2003, 11:59 AM
Doc and Gord
Thank you so much. Pressing remote 20 - 30 secs solved the problem.
Regards and thanks again.
Joe
73JPS
08-04-2003, 01:12 PM
Hey guys...
Will homelink work with the clunky old dip-switch type garage doors openers, the kind that are about 20 years old?
Evolv
08-04-2003, 11:02 PM
Originally posted by 73JPS
Hey guys...
Just get a new opener, Seems like everyone has a sears model, those are probably good! :D :D
By the way, when r u taken delivery of your Titanium Gray?
ZoomZoom
08-05-2003, 08:11 PM
Not even God knows the answer to that one... ;)
73JPS
08-06-2003, 06:48 AM
*Sigh*....
Too true. It seems the car I "traded" (to Performance Mazda in Orleans) already arrived and is being driven by mdmaclean... which begs the question "WHERE THE F--K IS MY CAR?"...
Anyway, anybody got an answer (a REAL answer) to my garage door question?
ZoomZoom
08-06-2003, 03:30 PM
*Sigh*....
May I suggest that we try your garage door opener on my car to see if it works? Besides, having access to your garage may have some advantages! ;)
Doctorr
08-06-2003, 03:50 PM
Yes, surely, fer sher, absolutement, defo, and 'no problem'!
The homelink like the big old clunkmonsters. When the little keychain remotes have problems programming, the standard answer is use the big old clicker that came with the opener.
doc
