Dynomatting
Old Jan 11, 2006 | 09:29 PM
UFGator12's Avatar
TEBOW FOR HE15MAN
Dynomatting
Does anyone have just 1 10" sub with around 300 watts and around a 500 or 600 watt amp? I would just like to know if there is much rattling and if dynomatting would be needed if I got a 4080 box. And since the box sits right under the trunk, I am worried that the trunk is going to start rattling. Thanks!
Old Jan 11, 2006 | 10:02 PM
MRJ024's Avatar
MJ
I will be Dyno-matting this weekend. I just installed a 10" JL W1 with an Alpine MRP-M350 amp and I seem to have a little Getto rattle kickin.... My box sits in the well and is almost flush (just sits up an inch)
Old Jan 11, 2006 | 10:12 PM
UFGator12's Avatar
TEBOW FOR HE15MAN
How much do you think it would cost if I had it done someplace? Just for the minimal dyno... just enough to stop the rattling?
Old Jan 11, 2006 | 10:43 PM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
it's dyna-matting!
Old Jan 11, 2006 | 10:44 PM
I have a bunch of pictures on my website if you wanna see...
www.trickrx8.com
Old Jan 11, 2006 | 11:24 PM
LiL BenNy's Avatar
Bubblicious? DEF.
i have 2 10w6v2 jl's running a 500/1 jl amp... theres rattling.. i need to dynamatt soon... i was recomended raammat bxt.... from reviews looks good
Old Jan 11, 2006 | 11:28 PM
xrider01's Avatar
127.0.0.1
i have 2 400 watt (RMS) 10in. sony Xplods (P.O.S. subs, but looking to upgrade soon) powered by a Sony Xplod class D 500 watt (RMS) amp. my trunk and license plate rattle quite a bit and find it rather annoying. soooo, dynAmatting is a must for me as well. how much would it go for just in materials?
Old Jan 12, 2006 | 10:51 PM
irish021's Avatar
i have two 12's in my car and the only thing that really irritated me was the license plate so as a temporary quick fix i took the soft, not the scratchy side of some velcro i had laying around and put it on the back of the plate and it stopped the rattle perfectly cost about 10 cents, ha
Old Jan 13, 2006 | 12:10 AM
xrider01's Avatar
127.0.0.1
for the license plate, i have spongy stuff that i'm thinking of using, but i think after time it will wear off and start to flake off the back of the plates and look nasty like.
Old Jan 13, 2006 | 06:53 AM
Asmoran's Avatar
I recommend you check out Second Skin Audio. It's a lot better than dynamat, and the owner of the company is a really great guy.
Old Jan 18, 2006 | 11:14 PM
ElPaco13's Avatar
Bite my shinny metal...
I would recomend dynamat for any size/ power sub. Also, if the dynamat is not going to be visible don't bother using actual dynamat, Use what is called Juke padding (I think that is how you spell it) I got some at a local trim and interior shop near me. $21 for 9 feet by 3+ feet. Pretty much just like dynamat only a tenth of the cost and no sliver heat shield.
The sound improvment it made on my '91 Cherokee was incredible (just a 2x2 ft. square behind my 12" sub).
Old Jan 18, 2006 | 11:26 PM
Astral's Avatar
Purveyor of fine bass
My 1 10" sub with 500W RMS in a 4080 box produces rattling primarily on the rear deck, and a bit on the roof headliner towards the back. The trunk is pretty small and doesn't seem to rattle really all that much. I get a little rattle in the rear right side door as well on certain frequencies.
So, IMO, not much rattling, and you don't NEED dynamatting. You can start by getting the sub/box and then alleviating any problem spots once you have your system in.
Old Jan 18, 2006 | 11:27 PM
Astral's Avatar
Second Skin Audio is an excellent place. I also recommend Raammat BXT, from Raam Audio, which I use myself. The owner there is also a great guy, very helpful w/ any questions.
Seriously, don't buy Dynamat the brand, it's a waste of $, when you have Second Skin and Raammat.
Old Jan 19, 2006 | 09:49 PM
UFGator12's Avatar
TEBOW FOR HE15MAN
Thanks a lot. Even with my Bose system I get rattling in the doors and it is extremely annoying. I am getting 1 12" sub put in on Saturday. How many square feet of product would I need to do both doors and my trunk? And, is there a major difference in the dampening spray and the mat?
success07
Jul 29, 2008 01:30 PM
GrAfiX
Apr 25, 2007 06:20 PM
Lacroft3
Apr 26, 2004 10:37 AM
