Ltft
Old Jan 11, 2006 | 10:34 AM
Nemesis8's Avatar
Bigus Rotus
Ltft
Are the Long Term Fuel Trim values stored in NVRAM or KAM?
Old Jan 11, 2006 | 10:41 AM
Aseras's Avatar
niether.... you can clear them both and it won't go away....
Old Jan 11, 2006 | 10:49 AM
MazdaManiac's Avatar
KAM. However, they are set immediately after the first warm-up to values based on the current drive-cycle.
They don't go away because they are always in flux. As more drive cycles go by, they average and won't move as much unless something drastic happens (like a lot more fuel added or a sever knock event).
Old Jan 11, 2006 | 11:07 AM
Nemesis8's Avatar
Bigus Rotus
Thanks Jeff
Mine are up to 7.2% right now. I have not tried resetting the PCM in awhile. How about removing the negative cable from the battery and pressing the brakes a few times to discharge the remaining charge, will this clear them?
Old Jan 11, 2006 | 11:50 PM
Originally Posted by Nemesis8
Thanks Jeff
That produces funny results sometimes. The PCM seems to hold onto its power for a long time after it is disconnected from the battery.
Best bet is to leave it disconnected for about 1/2 hour and then still do the full KAM reset manually afterward.
04Green
Series I Engine Tuning Forum
12
May 13, 2023 10:08 PM
fistofmeat
Oct 7, 2016 12:15 PM
9krpmrx8
Nov 5, 2015 11:45 PM
dbarber
Jul 25, 2015 01:34 PM
MadDog
25
Sep 26, 2005 04:28 PM
