Ran out of gas, added more :: Car won't start?
Old Jan 8, 2006 | 02:31 PM
RJBCAL's Avatar
I ran out of gas in my 2004 Rx-8. I added almost 2 gallons to the tank and it will not start. It cranks but will not turn over. Did I break something? Any suggestions?
Thank you
Rick
Old Jan 8, 2006 | 03:41 PM
iKenndac's Avatar
Your fuel system will be full of air - the fuel has to be pulled through. I know most diesel engines need to have a mechanic bleed it through manually, but I don't know enough about the 8's fuel system to say if this is the case here.
Old Jan 8, 2006 | 04:15 PM
you're suppose to turn the key to the ON position for several seconds without cranking then back to the OFF position, repeat this 6 or 7 times before trying to crank, the purpose is to allow the fuel pump to run and refill the lines/injectors
this is a standard procedure for fuel injection systems that have been run dry
otherwise there's the possibility that you ended up flooding it too
Old Jan 8, 2006 | 05:01 PM
RJBCAL's Avatar
TeamRX8,
Thanks for the information. If the engine has been flooded, what is the procedure to start the car? I see several threads about flooded engines, but there are so many replies, its hard to find the preferred/correct procedure.
Thank you
Rick
Old Jan 8, 2006 | 05:18 PM
\\Konig\\'s Avatar
turrrbo!
There is a procedure for deflooding in your RX-8 Manual.
Old Jan 8, 2006 | 10:35 PM
Moonrover333's Avatar
My Goodness My Guinness
put the pedal to the floor and let it turn over for a lil bit than try to start normally (for flooded engine)
Old Jun 6, 2019 | 12:44 PM
jnfootman's Avatar
This advice helped me today (06/06/2019)
I will add that after the 6-7 times of cycling from ON to OFF, I tried cranking it about 4 times before it would turn over.
Old Jun 6, 2019 | 02:38 PM
UnknownJinX's Avatar
Smoking turbo yay
13 years too late LOL.
It's not hard to keep the car at a reasonable fuel level. Having less than 1/4 tank of gas can already cause you some trouble if you do high G left turns.
You also risk burning out the fuel pump, and S1 fuel pumps are already very fragile.
ZiG
Mar 21, 2016 11:30 PM
culwatrnca_general@yahoo.com
Nov 30, 2014 04:35 PM
Big_Hoss
10
Jan 2, 2013 10:44 AM
yokohamaboi
Dec 30, 2011 06:55 AM
ahmadkabalan
Oct 28, 2011 10:34 AM
