Gulf RX-8 Forum Serving TX, OK, AR, LA, MS
Anyone on this sub-forum have a canzoomer?
Old Jan 4, 2006 | 11:01 PM
El Kabong's Avatar
What do you think of it?
Have you ever gotten it properly tuned for our hot/humid conditions?
Is it worth the trouble?
Thanks for your input.
Looking for some way to kill the time between now and when the warranty runs out and I can supercharge this sucker.
- El Kabong
Old Jan 26, 2006 | 01:13 PM
El Kabong's Avatar
Le Bump
Old Jan 26, 2006 | 02:24 PM
dazygirl415's Avatar
Whoa... I totally missed this thread. Unfortunately, I'm no help. Sorry.
Old Jan 26, 2006 | 09:26 PM
adrian-1's Avatar
Ex- member.
I got it when it first came out. It was a big headache.
Lots of tuning will be required to get the most out of it. Not to mention, with all the flash changes I'm not sure if R-flash is harder/easier to tune it.
You'll need a CanScan or equivalent to pull the data, then the extra cable for the canzoomer to load/change maps. You'll need to remove it if you ever take it in for service.
I gave up and sold it after a few months. I went with the Greddy turbo and it used the emanage (canzoomer is basically an emanage) which also had problems. Ditched the emanage for the Interceptor-X and I'm running good now.
I say wait for the warranty to run out and then get that s/c.
Old Feb 27, 2006 | 11:23 PM
El Kabong's Avatar
Any other thoughts? Anyone else around the gulf coast have one?
I've got a little under three years to go before the warranty runs out.
-Kabong
Old Feb 27, 2006 | 11:45 PM
BigOLundh's Avatar
#1 Legend
I think Sam has one (8 is enough). You may want to try sending him a PM.
-hS
Old Feb 27, 2006 | 11:47 PM
8 is enough's Avatar
No, I got the Canscan unit, not the canzoomer unit. I am not to sure on the canzoomer kit
Old Feb 28, 2006 | 08:50 AM
Hey Sam - are you in town this week? If you're not tied up, I'd like to meet up with you maybe tomorrow night....
Old Feb 28, 2006 | 06:54 PM
ok, give me a call
Old Mar 13, 2006 | 09:23 AM
musclecarconvrt's Avatar
I have one. I had it dyno tuned with a Midpipe, resonator, and Cat delete pipe. I saw max increase of 19 over stock at close to 9000. Most of the increase was over 7500. Trouble is, that Canzoomer box is pretty well useless below 6250 because the ECU will "fix" any changes you make at less than 6250 and WOT. I got tired of the CEL from the Cat delete pipe (and ricey rasp) and took the exhaust off. The Canzoomer unit still seemed to have some possitive effect, but when the weather got cold my ECU went nuts and started pulling timing so bad I eventually took everything off. The ECU is just too much of a control freak. We either need to break the code (RB already has but is still developing) or use something like the Intercpetor X which is a stand alone system.
MichRX7
Mar 9, 2004 07:44 PM
93rdcurrent
Series I Engine Tuning Forum
Mar 1, 2004 01:16 PM
RX8Z
70
Feb 21, 2004 06:51 AM
rotarygod
16
Dec 20, 2003 06:18 PM
