View Full Version : Suggested setup to get fastest AutoX car, regardless of Class?
GULAMAN 01-03-2006, 07:20 PM Just got my RX8 and ostensibly I was going to run it in B Stock this year. Then I got to thinking, what's the best setup if all I wanna do is compete w/ my buddies(who are all in diff. classes anyway) for raw times??
SO, what would *you* do with $2000 and a bone-stock RX8??
(training and add'l seat time is a given, so let's put that aside)
-17" wheels with widest V710s that'll fit?
-coilovers?
-alignment (a given, I know)?
-brake pads?
-sways?
I should add, I'm talking about setup/mods that still make the car streetable; not gonna gut the car or anything like that!
any thoughts?
TIA!
Dark8 01-03-2006, 07:41 PM $2000 will get you a set of lightweight 18" wheels and R tires....
17" wheels, coilovers and rear swaybar would put you out of B stock.
ULLLOSE 01-03-2006, 07:50 PM Just got my RX8 and ostensibly I was going to run it in B Stock this year. Then I got to thinking, what's the best setup if all I wanna do is compete w/ my buddies(who are all in diff. classes anyway) for raw times??
-coilovers?
-brake pads?
-sways?
any thoughts?
TIA!
$2k wont even get you a top BS car setup much less a faster class. Better step up the budget.
GULAMAN 01-03-2006, 07:57 PM Thanks for the reply Dark. yes, I understand the non-Stock setup, and I'm saying that's OK. Looking for the fastest setup for the $, regardless of what class it puts me in.
Part of the reason I'm considering this is that I run in about 4 different AutoX clubs (ain't NorCal great, heheh) depending on where my buds are showing up. so, even if I was competitive I would never rack up enough events/points in one single club to worry about Class season totals. in other words, I'm looking for "vanity speed" :) , for a given budget.
Ain't that the truth. R-comps are $1K alone. Another set of wheels around $1-$2K there. Shocks... even Konis are around $650-$700.
$2K isn't going to get you much.
ULLLOSE 01-03-2006, 08:06 PM Ain't that the truth. R-comps are $1K alone. Another set of wheels around $1-$2K there. Shocks... even Konis are around $650-$700.
Not to mention that cheap crap instead of good parts will give you a BSP/SM setup that is slower than a good BS car. A set of stock wheels, Koni shocks and 245-35-18 V710s are at about your budget.... If you can drive better than your buddies you will beat them anyway.
GeorgeH 01-03-2006, 08:37 PM If you want your car to be faster than a BS car but don't care about classing, get some 18x9.5 wheels, put some 285/30-18 710s on it, and get some JIC or KW coilovers. Toss in a light flywheel & intake for good measure, and you are at about $5.5k or so. This *should* be faster than a BS car, but whether or not you have the setup and driving skills to realize the potential performance is another question.
As others have stated, some Konis & 245 710s on stock wheels should be very fast and a good basis on which to learn (and, of course, in your budget). Since you don't care about classing you could get a matched set of sway bars for relatively little extra $$$, but tires & dampers should be your top priority.
GULAMAN 01-03-2006, 08:51 PM Not to mention that cheap crap instead of good parts will give you a BSP/SM setup that is slower than a good BS car. A set of stock wheels, Koni shocks and 245-35-18 V710s are at about your budget.... If you can drive better than your buddies you will beat them anyway.
Thanks, pretty much what I thought, yes $2k isn't all that much. Stock classing aside, do you think stock wheel/245 combo you allude to will give up much speed compared to,say, lighter 17"x9 wheel/275 V710s??
L8APEX 01-03-2006, 10:14 PM spend the 2k on driving lessons, and some good tires. The driver makes the most difference IMO.
StrokerAce 01-03-2006, 10:29 PM Get about 7k and get a shifter kart and driving lessons..
ULLLOSE 01-03-2006, 11:21 PM Thanks, pretty much what I thought, yes $2k isn't all that much. Stock classing aside, do you think stock wheel/245 combo you allude to will give up much speed compared to,say, lighter 17"x9 wheel/275 V710s??
I would think that a light 17X9 with a 275 would be quicker than stock 18s with 245s. I would not expect a big difference, maybe .5 sec. If you are happy with always having to run BSP/SM with a mostly stock car on big wheels and tires go for it. There are a few people like yourself out there that just run for fun and don't care what class they are in..... The rest of us are nuts. :Eyecrazy:
It would kill your budget but you can get the SSR comp in a 17X9.5, $429ea. Not to many light 17X9s for the RX8.
moto_bruce 01-03-2006, 11:46 PM Tires are the biggest contributor to low times. Next would be dampers.
If you don''t have a great deal of seat time, and aren't used to R compounds, I would think carefully about the V710s. It is harder to learn fine car control on tires that are not very forgiving and they are expensive and won't last very long. If you have experience with sticky rubber, then great, go for it. If not, step gently into r-compounds. Tire rack is selling Dunlop SSR in 225/40-18 for less than $120 each (no affiliation). Don't come in enough sizes to be legal, but if you are only looking to smack down some clowns, this could be a relatively cheap way to break yourself into sticky rubber. Definitely not sticky like V710s but much more grip than street tires and they will last much longer.
Another good tire would be a Toyo RA1. Last long, but expensive also. The nice thing about the dunlop and the toyo are that you can drive on them to the event and also do track days on them.
Depending on where you drive and the surface condition, you can see some great improvements in time with good dampers. They are worth more time on rougher surfaces. I use Konis on my miata and RX8 and I think they are the best bang for the buck in a damper. I knew I was getting konis for the RX8 when they were available without looking for reviews because they were just so darn good on my CSP miata. You would have to spend ALOT more on a damper to get something significantly better than the Koni and you would have to be a pretty darn good driver to perceive the difference. A strenght of the koni is that when adjusted properly, you don't notice them. Another nice thing about the Konis is that your car will ride a little lower all around. This means you can dial in more negative camber up front. I was able to get -1.5 degrees. This is a big deal because you will get considerable more grip up front and dial out a lot of the understeer.
I have not installed springs or bars on my car. I'm like you and I don't confine myself to B-stock with my mods because my main auto-x ride is the miata. Springs and bars will help with the transients, but it takes some skill to get the most out of them. Setup starts to be a bigger issue when you add more mods. The difference between a well set up car with little mods and a poorly set up car with great mods is huge. The sorted car will be quicker. I am considering the MS springs because their rates are much higher than the other "performance" springs. Stay away from the springs that eat up 1-2" of travel and only increase the spring rate by 20-30%. You will get familiar with your bumpstops if you don't. What I don't like about the MS springs are that the ratio between front to rear is different than stock, shifting traction to the rear (understeer). If I recall correctly it is only about 10-15%, but when you are talking about balance at the limit, this may be too big a difference to counter with bars. Don't know, haven't gone there yet. Like I said, set up becomes a big deal.
If I was going to burn $2K, i would go with modest r-compounds, konis and get to the evolution school. I'd get some decent track pads and do some HPDE with the money I didn't spend on gear.. Anything else you buy won't get you anywhere near the time that tires, dampers and software upgrades will.
Bruce
carbonRX8 01-03-2006, 11:57 PM If you want your car to be faster than a BS car but don't care about classing, get some 18x9.5 wheels (http:///#), put some 285/30-18 710s on it, and get some JIC or KW coilovers (#). Toss in a light flywheel & intake (#) for good measure, and you are at about $5.5k or so. This *should* be faster than a BS car, but whether or not you have the setup and driving (http:///#) skills to realize the potential performance is another question.
Um, this is about what I have plus sways and Im no where near $5.5K. More like $4.5 (do my own work and not counting stuff that I have added and taken off) And if you are wondering, no I dont have the mad skilz nessisary to realize the performance gains. At least I wouldn't brag that I did.
Oh, and bruce, that was very informative. Thanks.
GULAMAN 01-04-2006, 01:28 AM Thanks Moto_Bruce, interesting points. what you described actually mirrors my recent experience, regarding tires and springs.
-Tires: I did in fact run the Dunlop SSRs for most of last year on my A4, they are a good transition tire as you said, and last a long time. now I'm Jonesing for more *stick*!
-Springs: I installed some pretty stiff & low Intrax springs on my A4 that did improve steering response/roll on an absolute basis, but w/ many accompanying negatives as you implied; yes I was on first-name basis with the bumpstops....
Lastly, at the end of your post you mention brake pads. are the Mazda OEM pads sufficeint for AutoX? I will also HPDE this car so I suppose it's a foregone conclusion that pads are in my future. My outgoing A4 had Hawk HP+ but I couldn't stand the squealing so I only left 'em on for HPDE and ran with Hawk HPS for street/AutoX.
Gulaman
L8APEX 01-04-2006, 07:59 AM Lastly, at the end of your post you mention brake pads. are the Mazda OEM pads sufficeint for AutoX? I will also HPDE this car so I suppose it's a foregone conclusion that pads are in my future. My outgoing A4 had Hawk HP+ but I couldn't stand the squealing so I only left 'em on for HPDE and ran with Hawk HPS for street/AutoX.
Gulaman
IMO the stock pads to a good job for autocross. I have the Hawk HP+ on the car right now prepping for a track day, and the squeal and dust is killing me. Looks like my car is neglected. They are great pads for track use, but not necessary for autox if you ask me, I can brake later than a lot of the other cars on the course, and I feel like I get slowed faster too. But hey, I don't have the experience that some of the other guys have.
For pads all last year, I ran stock pads. They are great for auto-x.
I did a track day at NHIS after the season was over and ran Carbotech Panther+ in the front and Bobcats in the rear. No fade, at all... and I'll probably be running them this year too for that little extra bite and pedal feel I like.
Bruce, when are we going to see you at an SCCA event at Devens? :) More seat time to fill in the gaps between Miata events. :)
--KC
John V 01-04-2006, 11:56 AM Just got my RX8 and ostensibly I was going to run it in B Stock this year. Then I got to thinking, what's the best setup if all I wanna do is compete w/ my buddies(who are all in diff. classes anyway) for raw times??
Nobody asked the obvious question of what your buddies drive...? Also, what's their skill level?
Get another set of stock wheels for 300 bucks and budget a couple sets of V710s. Run all the events you can which watching and talking to the best drivers in your area. You'll go lots faster than just slapping on an intake and light flywheel (neither of which will make you much faster).
John
clyde 01-04-2006, 12:17 PM Assuming I had to spend the money on the car itself, or $2k I would do the following...
$300 - one set of OE wheels
$950ish - one set new 245/35-18 Kumho V710s, with mounting
$650ish - one set Koni Sports
$100 - replacement exhaust shrouds (black plastic trim in rear bumper) to replace the ones that will break and assorted replacement fasteners for the front undertray that will break and/or disappear during a season of autocrossing.
If I didn't have to spend all the money on the car:
$300 - one set OE wheels
$950ish - one set of new V710s, mounted
$750 - schools
moto_bruce 01-04-2006, 01:52 PM Gulaman,
To answer your question about the pads, I found that the stock pads were more than adequate for auto-x. Initial bite is good when cold, modulation is good. You never really build up that much heat in a run so I've never run into fade, and I think most of the other auto-xers will agree that the stock pads are a cheap, long life, 95% solution for auto-x. Some guys like the feel of other pads, thats personal preference, but I don't think (opinion) that stopping distance or even modulation (at auto-x speeds) are different enough to mean any time out on course. Of course if the pad makes you feel more confident, you will be faster because your outlook and attitude are more positive. At auto-x speeds, we just don't get near the edge of performance of the brakes so there is little to be gained there. The braking system is very good. I think part of this is because the rotors are pretty big, giving lots of surface area and high relative speed to the pad at the outer edge of the rotor.
Track is different. I drove a few HPDEs out in CA a couple of years ago (street tires, OEM pads), then did the Glen last fall with Tracquest. The Glen was my first time on track on R-compounds (dunlops). I thought the brakes would be good to go, but by lunch on the first day, I overheated the pads and put pad material unevenly on the rotor (that has to be worth some kind of bone-head award). Had to live with the vibration for the rest of the weekend (they were new OEM pads, maybe I should have let them cure longer after breaking them in). An S2K buddy of mine (first track day for him) put Cobalts on his car and he had no problems, but he was on street tires. He used up about 2/3 of his pads over two days, about 300 track miles. I have a new set of XP8s that I will use at my next HPDE in the spring. I'm slow on the upgrades. I only upgrade when my driving skill improves enough to show me that I need to.
I think (opinion) that cars with big rotors and high relative rotor to pad speeds are more sensitive to the performance envelope of a pad. I've never had pad problems with my miata (OEM auto-x, OEM HPDE), but with the small brake rotors (and light weight of course) it just isn't possible to generate the rotor surface temperatures of a bigger rotor. Hopefully, I made the right choice with the XP8s, at least for the speeds at the Glen. I'll continue to use the OEM for auto-x.
KC,
yes, I need to get out to more of the NER events this year! I spent most of my auto-x effort in my miata getting schooled by the CSP guys in the miata club and I also ran a couple of times with CART and FCSCC. I haven't worked too hard on the RX8 for auto-x, mostly using what I know of setup from driving CSP. I am impressed with how fast an RX8 really can be at auto-x. Numbers don't do the car justice. It has good synergy and really talks to you when at the limit. Maybe someone who is fast can really show me what good technique really is. I hate it when I forget to turn off the DSC at the line. I'm sure we all have stories of holding the button down and checking the indicator lights in the middle of a braking zone or turn!
I hope to get out there more with NER. Its been a while since I've gone all the way around Devens. What's really rough is the lack of events during NE winters. Been watching alot of racing videos and playing GT4. Poor substitute for the real deal. Considered karting at F1....
Bruce
Dragonrider 01-04-2006, 02:00 PM spend the 2k on driving lessons (#), and some good tires (#). The driver makes the most difference IMO.
You can spend all you want on the best handeling car around, and it won't do you any good in AutoX if the nut behind the wheel is not tuned.:ylsuper:
L8APEX 01-04-2006, 02:05 PM I hate it when I forget to turn off the DSC at the line. I'm sure we all have stories of holding the button down and checking the indicator lights in the middle of a braking zone or turn!
Bruce
done that, and left the A/C on a couple times. her in GA, in August, waiting in line, it is hot as hell. Dumbass me has done that a few times, and the DSC button. It does nto take long to figure it out.
GeorgeH 01-04-2006, 06:18 PM My fastest run yet in my RX-8 was with the DSC on at launch. Fumbled with it during the first slalom and still got the fastest time for that run group. Since then I don't worry about the long press so much. :)
How does 2nd run this year at Nationals sound? Bleah. But it happens.
The difference between Miata and NER is: You get less runs and more standing around with NER. Not going to hide that one. You can have days with 95 people or 195 people. So less people, more runs. More people (and any problems with timing, etc...) then you get less runs. We don't have limited entry, and we let non-members run. So yep... it can be hectic at times.
If you're new to the region... the 1st NER event of the year is usually the most problematic. You get a lot of people that heard about auto-x through forums like this, find out it's going to be racing, and show up on the 1st event of the year never to return. It's a lot of waiting for 3-5 runs.
Annual meeting is in 2 weeks. We might hear of some changes to the program to help make the event run more smoothly.
moto_bruce 01-04-2006, 08:37 PM KC,
I didn't want to say it, but you hit the nail on the head and I agree with you completely. I came to NE summer of 2004, did a couple of NER and Miata events and everything was cool. In the spring I did Evolution phase 1 and the first auto-x was NER. That was a long day for three runs and I didn't think it was good bang for the buck. I have been dragging some friends into the sport to try to help it grow and I have a hard time recommending the NER events for those still learning how events are organized and basic car control. I've been trying different clubs so that I can make good recommendations to my friends so that they have fun and stick with the sport. CART and FCSCC have been fun events, although less technically challenging.
I like the competition with the Miata club. They probably have the highest density of CSP cars (duh) and the courses are technical and at times deceptive. Not sure where the center of gravity is for BS. I drove a test and tune at CART and was approached by a 350z pilot that was looking forward to seeing me at more of the events to flesh out BS. Unfortunately, I didn't drive the RX8 at CART since.
But you hint at something important that I haven't been doing well as a member, driver and motorsports citizen, and that is supporting our region. I need to be out there. I need to be present, drive my best and be a part of the competition that makes auto-x fun. Although NER isn't perfect (is there such a thing as a perfect club?) I do believe NER events generally attract the better drivers in the region and you are right, the event organizers have the challenge of running the biggest events, educating novices and keeping the rest of us in line.
I'm getting motivated. Deep breath.
Bruce
yiksing 01-05-2006, 01:11 AM Best Mod = Driver + Tires
John V 01-05-2006, 07:05 AM My fastest run yet in my RX-8 was with the DSC on at launch. Fumbled with it during the first slalom and still got the fastest time for that run group. Since then I don't worry about the long press so much. :)
Left the DSC on for first run in Atlanta and then again in Toledo. It was about a 1.5 second penalty :Freak_ani
GULAMAN 01-05-2006, 12:22 PM Thanks for the thoughtful answers, guys. From a car setup standpoint, it def. sounds like doing the B Stock-type mods are the shortest mechanical route to shaving seconds off my time. I just wanted to get all your opinions before making this conclusion on my own, as I'm still quite unfamiliar w/ the strong/weak points of this car.
I'm still debating on whether to go 17" or 18" sizing; the former potentially allowing for wider widths in light of cost.
Also, I'm gonna make an effort to finally get to Evo school this year; in Los Angeles.
Gulaman
John V 01-05-2006, 12:47 PM Thanks for the thoughtful answers, guys. From a car setup standpoint, it def. sounds like doing the B Stock-type mods are the shortest mechanical route to shaving seconds off my time. I just wanted to get all your opinions before making this conclusion on my own, as I'm still quite unfamiliar w/ the strong/weak points of this car.
Gulaman
If you go to 17" wheels, what size tire is available? I think Kumho has a 275/40/17 available. In my opinion, that size isn't going to be a whole lot better (if at all) than their 245/35/18 which is what all the fast guys were running last year.
Now if you can get ahold of some 18x9.5" wheels you could fit the 285/30/18 V710. But if I were you I'd stay stock and learn to drive the car to the limits of a stock setup. It will be the most instructional.
GULAMAN 01-05-2006, 02:02 PM If you go to 17" wheels, what size tire is available? I think Kumho has a 275/40/17 available. In my opinion, that size isn't going to be a whole lot better (if at all) than their 245/35/18 which is what all the fast guys were running last year.
Yeah, for 17", the 275 is what I had in mind. In any case, I'll be running at least the first few events this year bone-stock. gotta start saving up for all these goodies. Just last night I sold my track wheel/tires from my A4...so at least I've got a bit of a start on my mod piggy bank!!
Last question: for those that have used V710s, are these so soft that they would completely be written off if used in HPDE?? if so, that may require me to downgrade to Victoracers or 'kook Z211. I definitely want to get a couple of DE days in along with a full season of AutoX out of my next tires.
ULLLOSE 01-05-2006, 02:26 PM Yeah, for 17", the 275 is what I had in mind. In any case, I'll be running at least the first few events this year bone-stock. gotta start saving up for all these goodies. Just last night I sold my track wheel/tires from my A4...so at least I've got a bit of a start on my mod piggy bank!!
You asked what was the fastest setup for $2k and now you want to hurt yourself in the one area you gain the most.... Make up your mind. :mdrmed: The V710 was on the pole setting T1 and T2 cars at the run offs, if the big fat T1 viper can make them last all race and come home 2nd I think the will live on your RX8.
My last set of V710s had about 100 runs and 1000 miles when I gave them away for someone else to finish off. You will notice that around 50-60 or so runs the V710 gets slower, more like a Victoracer at that point.
The only way I would ever even think about 17s is to run the 275. However if I had the funds I would rather run the 285-18. The guys that go to 17s and run 245s are nuts, good way to slow your car down.
GULAMAN 01-05-2006, 09:52 PM [QUOTE=ULLLOSE]You asked what was the fastest setup for $2k and now you want to hurt yourself in the one area you gain the most.... Make up your mind. :mdrmed: The V710 was on the pole setting T1 and T2 cars at the run offs, if the big fat T1 viper can make them last all race and come home 2nd I think the will live on your RX8.
QUOTE]
Well, that's why I'm asking first, not acting first!! would like it to be an informed decision. Data gathering, rationalizing, weighing the options, etc, etc....you should see my big decision matrix I've got posted on my wall <sarcasm> !!
Good to know however that the V710 holds up decently. I would've been prepared to just run my street tires for DEs, if the consensus came back that the V710s would be thrashed by DE use.
-Gulaman
clyde 01-06-2006, 10:19 AM if the consensus came back that the V710s would be thrashed by DE use.
The driver has a lot do with whether that will happen.
ULLLOSE 01-06-2006, 10:29 AM Well, that's why I'm asking first, not acting first!! would like it to be an informed decision. Data gathering, rationalizing, weighing the options, etc, etc....you should see my big decision matrix I've got posted on my wall <sarcasm> !!
-Gulaman
No doubt you could go one season on a set of V710s autoxing. If you toss in a few track days you might need two sets for the year. Just depends on how many laps and how hard you push. The 275 would take a track day better than a 245, more tire to spread the heat over.
moto_bruce 01-06-2006, 08:10 PM 2 sets of V710s pretty much kills your budget. That means no konis, no schools.
I'm not a V710 driver, but the sprint races are only a few laps. If you run with a group like Chin Motorsports, you'll get lots of laps. You may get over 6 hours of track time in a weekend, and I doubt a V710 will hold up to that kind of use.
Another track acquaintance of mine drives a 996 and gets more track days in a year than I will get in the next 5 (over 20 this last year!). He drives Mich Pilot Sport Cups and when I asked him about tire life, he was able to get 10-11 track days out of a set. When he first started out he was only getting 7-8 days before replacement. As his skilled improved, he got quicker (very, very quick), but he wore his tires less.
Don't know how many track days you have, but I would think twice about bringing out an expensive sprint tire for a weekend of high speed mayhem. I would prefer to have a tire that has longer life and consistency over its life. I find that finding speed out on the track is directly proportional to my consistency and smoothness. In other words, I find speed in very small increments, by increasing my speed by 1mph in some places, or moving a braking point a few feet. I can't do this without consistency. I'm still working at it and have a long way to go and for my skill level, a V710 is wasted grip and money.
The V710 may give you the opportunity to put down a very quick time at the track, but it's going to be expensive. If you are going to buy 2 sets of tires, I would get the V710s and a dedicated track tire, like a PSC, RA1, Advan, or even another set of dunlop SSRs. All except the SSRs cost about the same as the V710.
Bruce
GULAMAN 01-06-2006, 09:46 PM Good food for thought, Bruce. In my case though I'll never get 6 hours of track time per weekend. NASA events usually give me only 1.5 hours per day, and by the time I get around to getting tires this year I'll probably only get 2 track days in for '06. On my Dunlop SSRs last year, I did 3 DE days and about 9 AutoX (@7 runs/event average) days, and they look only about 1/2 worn.
But I'm more interested in optimising my car for AutoX rather than DEs; so much so that I'm willing to run some of the DEs on street tires if it means lengthening the AutoX life of an expensive tire like the V710.
Anyhoo, this is all January stovepipe talk for me it seems...my car's not even broken in yet!!!
ULLLOSE 01-06-2006, 09:55 PM If you decide you want to run 17s check this out:http://www.rx8club.com/showthread.php?t=79804
GULAMAN 01-08-2006, 09:35 AM Hey ULLOSE, in your experience is there any minute benefit from using wheel *offset* as a selection criteria? e.g. say, if choosing between a couple of wheels 18x8 to mount AutoX tires...one is designed w/ less offset, therefore providing a slightly wider track. is that even a worthy consideration?? I thought of this because it seems that nearly every aftermarket rim out there has less offset than the stockers.
ULLLOSE 01-08-2006, 12:18 PM Hey ULLOSE, in your experience is there any minute benefit from using wheel *offset* as a selection criteria? e.g. say, if choosing between a couple of wheels 18x8 to mount AutoX tires...one is designed w/ less offset, therefore providing a slightly wider track. is that even a worthy consideration?? I thought of this because it seems that nearly every aftermarket rim out there has less offset than the stockers.
"Wider is better" :rock: it has to be true or Pontiac would not have spent all that money on those adds. :mdrmed: I would go for width before offset. I would rather have stock offset with an extra 1/2" of wheel width than stock width with a 1/2" of offset. Most aftermarket stuff has the wrong offset for us beacause they were built for another car but just happen to fit the RX8.
PedalFaster 01-08-2006, 03:15 PM You can always fix offset with spacers too. (With longer studs if necessary.)
dannobre 01-08-2006, 03:49 PM You can always fix offset with spacers too. (With longer studs if necessary.)
But ...it's always better to get the right wheels in the first place :D:
StrokerAce 01-08-2006, 04:31 PM When it comes to tires. The DOT R tires are sticky. Howerer they are closer to mud and snows compared to real racing slicks. As long as you don't drive them on the street, not at all. Gross generalization warning: Best of street tires ~0.95g, Best of DOT R tires ~1.15g, Best of real racing slicks ~1.45g.
If you really don't care about class. Real slicks are a bigger jump over DOT R's than they are from street tires.
Ray
clyde 01-08-2006, 06:08 PM When it comes to tires. The DOT R tires are sticky. Howerer they are closer to mud and snows compared to real racing slicks. As long as you don't drive them on the street, not at all. Gross generalization warning: Best of street tires ~0.95g, Best of DOT R tires ~1.15g, Best of real racing slicks ~1.45g.
Ray
But getting real slicks up to their optimum temp range is, at best, problematic in autocross conditions. If you can't get the tires into their temp range they may or may not be faster than r comps...or even knobby mud and snows for that matter.
StrokerAce 01-08-2006, 07:04 PM But getting real slicks up to their optimum temp range is, at best, problematic in autocross conditions. If you can't get the tires into their temp range they may or may not be faster than r comps...or even knobby mud and snows for that matter.
Guess you're right. I never see a competive mod or prepared car running real racing slicks.
:spank:
Ray
John V 01-09-2006, 07:49 AM Guess you're right. I never see a competive mod or prepared car running real racing slicks.
:spank:
Ray
Actually, I've never seen a nationally-prepped mod or prepared class car running anything but real racing slicks. :dunno:
I think that's what's called sarcasm.
