Simple Question about Rear Strut Bar
Old Jan 2, 2006 | 10:39 PM
Rx-8 TT's Avatar
Hi, Iam trying to get a Rear strut bar, but there are two types of strut bar.
One is this.
http://www.finishlineperformance.com...key=RX08MS1021
This is a Shock Tower Brace.
This goes upper, middle of trunk.
Another one is this.
http://www.boomplustoys.net/autoexe_rx8.shtml
This is a Floor Cross bar.
This goes bottom of trunk.
However, I am trying to JIC Carbon one, which is this
http://www.vividracing.com/catalog/p...oducts_id/2687
1) Does JIC Carbon strut bar go middle of trunk, like first Shock Tower Brace?
Or, does it go bottom of trunk, like Floor Cross bar?
2) Anyone got JIC Carbon one? If you do, can I see the pictures?
Old Jan 3, 2006 | 06:48 AM
expo1's Avatar
He's as bad as Can
Good Question, looking around other sites the photo for the JIC front & Rear look the same. Either they used the wrong photo or to install it you would have to remove the rear strut which would be a big pain. If correct that does look like it would be close to the floor. Your post did give me an idea, I like the AutoExe one because it's closer to the floor than the MazdaSpeed. You can have my MazdaSpeed one for $90 shipped. PM if interested.
Old Jan 3, 2006 | 10:11 AM
Red Devil's Avatar
I just got my JIC AL front and rear strut bars in the mail...if you have a spare tire kit, the rear strut bar will fit into that exact location. For the JIC photo, they used the wrong one. The rear bar only has two bolt locations and should slide right into place. And if you have a spare tire kit, most of the work should already be done.
As for the floor bar, I'm not sure how well that would work in comparison. The weakest flex point should be at the top of the shock tower where the JIC bridges the gap - like in the front. But keeping the trunk space would be nice.
Old Jan 3, 2006 | 10:18 AM
Rx-8 TT's Avatar
I want to get both, floor cross bar and shock tower bar.
But, if JIC rear one is floor cross bar, then I will get JIC and shock tower bar.
If JIC rear one is shock tower bar, then I will get JIC and floor cross bar.
That's what Im thinking now.
Old Jan 3, 2006 | 10:25 AM
Red Devil's Avatar
Oh, okay. Yeah, the JIC rear is simply a shock tower bar. It's mounting is basically identical to the front, it just has two mounting points instead of three. That was my point above.
If you got the JIC then you could also use the floor bar in conjunction.
WingleBeast
22
May 23, 2016 09:22 PM
Kahl
Aug 20, 2015 11:49 PM
Mr.Durden
Aug 12, 2015 02:21 PM
Jazzmeson
Jul 31, 2015 01:48 AM
