help quick!! removing radio
Old Dec 26, 2005 | 02:19 PM
Acclaim99's Avatar
Where in the heck is this hidden 10mm bolt
Ive been looking everywhere, what is it next to (screwed into)
I know it isnt the two bolts that are near each others... and the pic i found doesnt help at all
Old Dec 26, 2005 | 05:43 PM
forbidden's Avatar
It is located on the back right upper side of the head unit. You have to go after it from under the dashboard on the drivers side while contorting your body into positions that it was not designed to do. Ensure that you have a flashlight so as to see it. The bolt that is there slides along and buts up against a plastic barrier to keep it from moving.
Old Dec 26, 2005 | 07:49 PM
Acclaim99's Avatar
the thing screwed into the white plastic thing (at the top)?
if its thats, its impossible to take out :-/
Old Dec 27, 2005 | 05:11 PM
Acclaim99's Avatar
Thanks guys.... since no one bothered to help at all, I spent 5 hrs trying to get out a bolt I described above, pulled the *#($ out of the radio and nothing. So I give up... oh, not only that, but after reassembling my car... the center HUD isnt working.
Old Dec 27, 2005 | 05:57 PM
8is>enuff's Avatar
Bland
I took the same bolt out at first. That's not the one you need. There's a metal shield you can take out to see the bolt more easily. It's pictured in the third picture here http://www.whatsmyip.org/ipodrx8/4.php There's two screws holding the metal shield on, one of which is visible in that third picture.
Good luck.
Old Dec 27, 2005 | 06:15 PM
Acclaim99's Avatar
took that part off. is it on the steering column or what?
Old Dec 27, 2005 | 06:17 PM
dkuhlman's Avatar
It is a 9MM bolt that will come out with a ratchet wrench with extension. Put a small piece of tape or something to hold the bolt in the socket otherwise if it falls good luck finding again! The problem is getting your body under the steering wheel to remove it. You need to lie on your back so you can see up into the radio rack area. Not good if you have back problems like me!! Also helps if you have someone there to hold a light.
Old Dec 27, 2005 | 06:34 PM
8is>enuff's Avatar
Bland
Not on the steering column. It literally screws into the side of the radio.
You are talking about taking off the metal bracket, right? The bolt should be visible and easier to access once that metal piece is off. If you have trouble you can narrow your search area to the depth and height of the radio. In other words, since it screws into the side of the radio, there's only a small area in which the bolt can be. You can figure it out by estimating how deep and tall the radio is when it's installed, and searching that area.
If my car wasn't in the shop I'd try to take a pic for you.
I used a 10mm ratchet and didn't need an extension.
RX8mzda
Oct 1, 2015 10:17 PM
Racingjunkie
Sep 29, 2015 05:05 PM
xAgyex
Sep 28, 2015 08:54 AM
Learners_Permit
Sep 27, 2015 07:38 PM
