Flashing CEL
Old Dec 23, 2005 | 03:40 PM
mikeb's Avatar
100% Italian
Flashing CEL
For the first time ever last night I got a flashing CEL while doing about 70. Anyone ever got that before? The cel light is now off but I wonder why it came on at all.
Old Dec 23, 2005 | 03:46 PM
Go48's Avatar
If you were at high rpm, it could have been a misfire. If that's the case, it may come back. Check the ECU for error codes if you have that ability. Otherwise, take it to a dealer.
Old Dec 23, 2005 | 03:51 PM
Mike,
a Flashing CEL is usually not a good thing.
Did it stay on for quite a while? Were you revving the engine pretty high?
Oh oh, might be time to visit our friends in Tustin or HB...
Old Dec 23, 2005 | 03:54 PM
zoom44's Avatar
misfire mike
Old Dec 23, 2005 | 05:46 PM
mikeb's Avatar
100% Italian
well I was driving fast
it has not come back on
i dont know
sometimes my car drives well and other times not so much
Old Dec 23, 2005 | 06:32 PM
that's the Nanny-CEL telling you
Old Dec 24, 2005 | 06:05 AM
mikeb's Avatar
100% Italian
well i dont care as long as the CEL stays away
Old Dec 24, 2005 | 07:22 AM
if it happens often enough within a specific period/cycle it will latch on full time
Old Dec 24, 2005 | 07:32 AM
BoosTED's Avatar
Is the misfire caused by the fuel cutoff when it hits 10,500 RPMs?
After it hits the 10,500 RPM cutoff when does fuel kick back in?
Old Dec 25, 2005 | 04:20 AM
mikeb's Avatar
100% Italian
I dont know but my AT doesnt rev that high
Old Dec 25, 2005 | 02:47 PM
RX-Nut's Avatar
8 the HARD way.
if youre lucky its just a bad spark plug. thats what happened to me.. same symptom
Old Dec 26, 2005 | 02:31 AM
mikeb's Avatar
100% Italian
you could be right
but the dealer just changed my spark plugs about 1k miles ago
I wonder why they keep going bad
Old Dec 26, 2005 | 03:18 PM
10,500 rpm?????
whachatalkinaboutwillis???????
fwiw, flashing CEL is typically the PCM detecting occasional misfires, but not often enough to trigger a full-on misfire CEL, it's mentioned in the service manual
Old Dec 27, 2005 | 03:53 PM
Red Devil's Avatar
If you're having plugs replaced often, they may be fouling from carbon. How often do you take in into the upper rev range?
Old Dec 27, 2005 | 06:38 PM
Brice-RX8's Avatar
Fuel cutoff is at roughly 9500 rpms, the tach's in most cars are generally off by a could hundred rpm's, which can make you think the cutoff is much higher.
Old Dec 28, 2005 | 12:36 AM
mikeb's Avatar
100% Italian
I guess not often enough
Old Dec 28, 2005 | 03:45 AM
BoosTED's Avatar
I thought I had seen fuel cutoff at 10,500
must be wishful thinking.
Old Dec 28, 2005 | 03:47 AM
BoosTED's Avatar
and I swear I had gotten it to 10,500 before realizing I had to shift.
Don't have that problem now that I have the high flow cat and Greddy SP2
Old Dec 28, 2005 | 06:43 AM
JerrsRX8's Avatar
i had the same problem with flashing cel. its caused by a misfire. my misfire was caused by an arching spark plug wire which gave a weak spark that caused to plug to foul out and make the cel stay on eventually. take it to the dealer and have it fixed. my car runs awesome all the time now, no "bad" days anymore.
Old Dec 30, 2005 | 04:19 AM
mikeb's Avatar
100% Italian
I think its the spark plugs but I just got them changed about 5k ago
they keep going bad
what causes them to go bad
now the cel light is on and flashes at high rpm's
Old Dec 30, 2005 | 05:38 AM
Go48's Avatar
"now the cel light is on and flashes at high rpm's"
Failed catalytic converter!
Old Dec 30, 2005 | 06:49 AM
JerrsRX8's Avatar
that was the exact problem i had. it prolly feels like its hesitating a little bit as well at high r's. go get the plugs and wire changed. its under free, and you'll be happy with the results. i was sooooo sick of the problems with the car and was dying to get rid of it but after that fix i'm in love with the car again.
btw its prolly the arching wire that is causing the plugs to go bad. it took my tech three tries to get it right.
Old Dec 30, 2005 | 12:06 PM
mikeb's Avatar
100% Italian
I think you guys are right
whats a arching wire
Old Dec 30, 2005 | 12:16 PM
BoosTED's Avatar
A bad spark plug wire.
If it has bad connectors or a small break in the wire when it is pushing all those volts for the spark plugs it arcs like a spark plug does but inside the wire or connector.
RevMeHarder
Jun 1, 2026 02:30 PM
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
Evan Gray
Sep 26, 2015 12:30 PM
Forevermore
Sep 20, 2015 01:04 PM
