Permanence of Canzoomer
Old Dec 20, 2005 | 10:07 PM
Tastic's Avatar
If I tune AF ratios with Canzoomer, will the settings be permanent or will the stock ECU, over time, change my AF ratios back to stock?
Old Dec 20, 2005 | 10:21 PM
Armaant's Avatar
Armaan
i second the question...also if the ecu does adjust back can it be easily overridden by resetting the ecu the reloading the tuned maps?
Old Dec 20, 2005 | 10:58 PM
WantedTwo's Avatar
C4 burns real good
it depends on how drastic your changes are. If you do everything all at once the car says wtf, blow me. So do your tuning slowly. There is no reason to reload your map the car isn't going to change that, it has no idea its even there, the map its adjusting is its own.
Old Dec 21, 2005 | 10:31 AM
r0tor's Avatar
if you do it correctly and only above 5600 rpms, you will have permanent effects... if you choose not to do this you will have a 1 day effect
AutoBahnRX8
Europe Forum
18
Mar 20, 2015 11:06 AM
RX8Z
Series I Engine Tuning Forum
70
Feb 21, 2004 06:51 AM
RXhusker
Jan 16, 2004 06:10 PM
rotarygod
16
Dec 20, 2003 06:18 PM
