View Full Version : Pulleys.
PJ Yukiyu 12-19-2005, 02:01 PM I want to buy some pulley for my 8, but don't know if its a good idea. There are several companies that makes them and I'm not shure which one is the best for my car.
Right now I'm very interested on buying the shane racing power pulleys at www.shaneracing.com.
http://http://www.shaneracing.com/RX8_Pulleys_Kit6Large.jpg
Can any one help me? I'm not sure if its a good adea. Very interested on your comments and advices.
Glyphon 12-19-2005, 03:36 PM i've seen a couple of posts by people here saying that if they had the chance to go back and do it again, that they would not purchase underdrive pullies again, because they make almost no difference at all.
if you want to do something and get a few extra hp, go with an intake. look/search around ther performance mod section here to see opinions on the different options.
4 years to Supercharge 12-19-2005, 03:44 PM Unorthodox Racing and I would definitely install them if I did it again!
Mazdaparts.com has them for 250 shipped.
4 years to Supercharge 12-19-2005, 03:50 PM The Unorthodox pulleys look real nice too. I believe the complaints were with the SR Motorsports pulleys. I wish that $99 acorn nut for the alternator pully was more reasonably priced.
Cool-Blue-Dad 12-19-2005, 04:09 PM Unorthodox Racing and I would definitely install them if I did it again!
Well that sounds like a satisfied customer. 4 years to Supercharge, can you elaborate?
Are they so much lighter that you feel/measure some horsepower gain?
The pictures in your 2nd post look nice - do they stay clean enough under the hood to be a regular 'show-off' item?
Did you have a dealer install them or DIY? Any concerns about warrenty? I think they shouldn't be an issue, but I'd be interested to know what you've heard.
4 years to Supercharge 12-19-2005, 04:17 PM I would be surprised if the dealer would even notice the only one that is really in plain sight is the alternator pulley. They have to be looking for it, as in over the battery looking down.
They are lighter I was amazed by the difference they made in acceleration. It revs easier too.
I installed them myself. The toughest thing would be removing the alternator nut if a person does not have an impact wrench. With one it is a trigger pull and it comes spinning. Rest of them were easy to get at once the airbox is removed.
PJ Yukiyu 12-19-2005, 04:44 PM Thanks a lot for the info.
Can you post a picture of them install?
4 years to Supercharge 12-19-2005, 05:07 PM Here's some pics just took 'em with my PDA.
Fanman 12-19-2005, 05:57 PM Freakin' worthless. Save your money and get a hi-flow cat. more hp gain. The pullies (I have the SR units) were not much lighter, if at all then the stock units. The stock pullies aren't 15 lbs., like on some V8's so you are not going to save much weight (hence make the engine more efficient) and the underdrive is only 20%.
4 years to Supercharge 12-19-2005, 06:35 PM Like I said earlier the ones that ^ complain ^ eh hem (fanman) have only tried the SR Motorsports pullies. :eyetwitch
I know he has warned many about the SR's.
Have you tried the UR pullies Fanman? :squint:
hes the get ur specializes in pulleys so they r good sr dont so they are bad theres more to just how heaxy pulleys are to make power
4 years to Supercharge 12-19-2005, 07:55 PM That said, high flow cat is good from SR Motorsports :) I had to heat up the hanger and put a twist in it just before the catback. It fit but it was right against the frame and I didn't want it resonating through to the cabin. I have that installed with the Greddy SP2.
carbonRX8 12-19-2005, 11:18 PM :wallbash: :soapbox: Why do people insist on asking if the pulleys are LIGHTER??? The lightness or heavyness MAKES NO DIFFERENCE!!!!! It is the underdriving that counts. And you get every horse to your drivetrain that you stopped sending to your water pump/alternator/ac. Sending less rpms to your waterpump actually can be a good thing. :soapbox: :wallbash:
Pulleys do not equal Flywheel. Lightweight flywheel, good. Light pulleys, who cares.
If I have offended, I am sorry. That was not my intent.
Fanman 12-19-2005, 11:57 PM That is not correct. The two ways you make hp with pulleys is you lighten them, and/or you underdrive them. When you lighten them, you make the engine do less work hence it is not really increasing hp, but it is freeing up hp. This is exactly the same principal as a lightweight flywheel, but in this case you are not talking about dropping a few pounds off of a 18 lb. flywheel (& counterweight), you are talking about less than a lb. That is why this doesn't work for the RX8. On a large V8 engine the pulleys are solid steel, and huge, and might weigh 15 lbs., and if you can drop off 6-7 lbs. that is a huge difference. Similar concept to underdriving it as well.
Understand that there is not much weight there to begin with Supercharge. It's different if one set of pullies is 15 lbs, and the other is 5 lbs, but the stock ones weigh about 2-3 lbs. as it is. You are talking about ounces. Second thing is the degree of underdriving them is not far off from the 2. UR is about 20% underdrive, the SR units I believe are about 15%-18%. The dyno claim of 9 whp is far fetched. I got about 1 whp on mine. If somebody has pulled off 9 whp, other than UR I would love to see it. So far, even in the RX Tuner magazine I have seen butt dynos, but as we all know those are notoriously inaccurate.
carbonRX8 12-20-2005, 12:14 AM That is not correct. The two ways you make hp with pulleys is you lighten them, and/or you underdrive them. When you lighten them, you make the engine do less work hence it is not really increasing hp, but it is freeing up hp. Similar concept to underdriving it as well.
Understand that there is not much weight there to begin with Supercharge. It's different if one set of pullies is 15 lbs, and the other is 5 lbs, but the stock ones weigh about 2-3 lbs. as it is. You are talking about ounces. Second thing is the degree of underdriving them is not far off from the 2. UR is about 20% underdrive, the SR units I believe are about 15%-18%. The dyno claim of 9 whp is far fetched. I got about 1 whp on mine. If somebody has pulled off 9 whp, other than UR I would love to see it. So far, even in the RX Tuner magazine I have seen butt dynos, but as we all know those are notoriously inaccurate.The difference in power that is required to increase the angular velocity of two disks equally with moments of intertia that, vary equally as a function of radius, that have radii of 0.25 feet, and when the two disks differ in mass by 25%, is miniscule (about 0.3 hp by my calc with rpm increasing linearly at 1000 rpm/sec) compared to the hp output of the engine. On the other hand if it takes 10 hp to drive the alternator and water pump (this is about right for an approximation) and you reduce the gearing by 25%, you get 2.5 "free" hp. Do you see my point. Difference in mass on this small of a diameter means just about nothing (differnent on a flywheel cause you have more diameter and more mass. You can get 10 hp by theory easy and you can also change I to bias the weight to the center of rotation) Do you see my point. The weight savings is insignificant (for non-race use)
Fanman 12-20-2005, 12:42 AM The difference in power that is required to increase the angular velocity of two disks equally with moments of intertia that, vary equally as a function of radius, that have radii of 0.25 feet, and when the two disks differ in mass by 25%, is miniscule (about 0.3 hp by my calc with rpm changing linearly at 100 rpm/sec) compared to the hp output of the engine. On the other hand if it takes 10 hp to drive the alternator and water pump (this is about right for an approximation) and you reduce the gearing by 25%, you get 2.5 "free" hp. Do you see my point. Difference in mass on this small of a diameter means just about nothing (differnent on a flywheel cause you have more diameter and more mass. You can get 10 hp by theory easy and you can also change I to bias the weight to the center of rotation) Do you see my point. The weight savings is insignificant (for non-race use)
When you are talking about a 1-2 hp gain, your example is literally 15%-30% of the hp gain. Obviously it's not going to give you the hp gain/freed hp of a flywheel. Especially for this application. On big engines, the pullies can be quite a bit larger & heavier, and they can make that application where they lessen the weight, but also because the diameter of the pully is larger, they can concentrate the weight towards the middle more as well (and I understand that concept as you look at a stock flywheel vs. the MS, and while the MS is only 1 lb. lighter, more of the weight is centered in the middle). In our application is is not very feasible.
carbonRX8 12-20-2005, 12:58 AM When you are talking about a 1-2 hp gain, your example is literally 15%-30% of the hp gain. Obviously it's not going to give you the hp gain/freed hp of a flywheel. Especially for this application. On big engines, the pullies can be quite a bit larger & heavier, and they can make that application where they lessen the weight, but also because the diameter of the pully is larger, they can concentrate the weight towards the middle more as well (and I understand that concept as you look at a stock flywheel vs. the MS, and while the MS is only 1 lb. lighter, more of the weight is centered in the middle). In our application is is not very feasible.Agreed.
Cool-Blue-Dad 12-20-2005, 10:27 AM This is the first I have ever heard of under-driving. Do I understand this right - the SR and UR pulleys have different diameters from the OEM parts and thus will transfer less spin or less power to the water pump and the alternator?
If I understand that right - wouldn't reducing the drive to your alternator be a bad thing in a cold climate? Wouldn't reducing the drive to your water pump be a bad thing in a hot climate?
4 years to Supercharge 12-20-2005, 10:42 AM Understand that there is not much weight there to begin with Supercharge. It's different if one set of pullies is 15 lbs, and the other is 5 lbs, but the stock ones weigh about 2-3 lbs. as it is. You are talking about ounces. Second thing is the degree of underdriving them is not far off from the 2. UR is about 20% underdrive, the SR units I believe are about 15%-18%. The dyno claim of 9 whp is far fetched. I got about 1 whp on mine. If somebody has pulled off 9 whp, other than UR I would love to see it. So far, even in the RX Tuner magazine I have seen butt dynos, but as we all know those are notoriously inaccurate.
It also has to do with ratios; if the crank pulley is smaller it changes both the amount of drive to the other pulleys but if those are smaller on the same scale the drive stays the same.
The size of these is considerably smaller. This gives gains like a figure skater spinning around with her arms out is not as efficient as spinning with her arms in.
4 years to Supercharge 12-20-2005, 10:47 AM This is the first I have ever heard of under-driving. Do I understand this right - the SR and UR pulleys have different diameters from the OEM parts and thus will transfer less spin or less power to the water pump and the alternator?
As for cold climate I haven't had any problems and I live in Minnesota. It's been below zero numerous times this year already.
NoTears316 12-20-2005, 08:23 PM This is the first I have ever heard of under-driving. Do I understand this right - the SR and UR pulleys have different diameters from the OEM parts and thus will transfer less spin or less power to the water pump and the alternator?
I've had SR's pulleys on for over 2 years now, and haven't had any problems in the heat of El Paso.
carbonRX8 12-20-2005, 08:48 PM This is the first I have ever heard of under-driving. Do I understand this right - the SR and UR pulleys have different diameters from the OEM parts and thus will transfer less spin or less power to the water pump and the alternator?
If I understand that right - wouldn't reducing the drive to your alternator be a bad thing in a cold climate? Wouldn't reducing the drive to your water pump be a bad thing in a hot climate?Your alternator begins DUMPing power after about 2000rpm. Also look up, cavitation on the RX7 site to see positive results with underdriven waterpumps.
Fanman 12-20-2005, 09:00 PM It also has to do with ratios; if the crank pulley is smaller it changes both the amount of drive to the other pulleys but if those are smaller on the same scale the drive stays the same.
I understand ratios, but to shrink the pullies like you are talking about you would have to have a new belt first of all (taking diameter away from a pulley, you would also need to get a new belt as it would fall off otherwise), which I don't think the kit has, and we are talking to get the effects that you are talking about you would need to take inches of the circumference of the pulley & belt. Our stock pullies are not that big to begin with. You are not talking big V8/V10 units the size of small pizzas, you are talking about pullies the size of hockey pucks already, so the size decrease is minimal at best. other than that weight shrinkage or centering of weight, look what carbon & I have stated about that.
Also if you are talking ratio change to a smaller pulley on one unit you are also talking about overdriving a component, that will lead to more wear & tear on a component.
carbonRX8 12-20-2005, 09:21 PM Just to add to what Fanman said, to underdrive you either make the drive wheel small or the slave wheel big. Or a combo of both. Like on a 10 speed bike. To go slower you go into the granny gear on the front, and the sissy gear on the back. (I love bike terminology!!! translated it means small chain wheel on the front and big cog on the back)
4 years to Supercharge 12-20-2005, 09:41 PM Fanman I had to put smaller belts on. The kit doesn't come with it but they say which ones to get for it. :) Belts were only $15 for both.
NoTears316 12-20-2005, 10:46 PM you would also need to get a new belt as it would fall off otherwise, which I don't think the kit has
I thought you had the SR kit. I know mine came with belts.
zaglo6204 12-20-2005, 11:29 PM im a wee bit confused. from wat i understand, or thought i understood, the weight savings would simply allow the engine to rev more quickly, which would thus allow for quicker acceleration because of the celerity with which you would reach the 'powerband'. but under load, ie the engine making the tires turn on the ground (with traction), that would set a far lower limit on rev speed than the mass of the pulleys.....im so unbelievably confused.....AAAAAAAAAAAAAAHHHHHHHHHHH i just gave myself a headache
carbonRX8 12-20-2005, 11:43 PM im a wee bit confused. from wat i understand, or thought i understood, the weight savings would simply allow the engine to rev more quickly, which would thus allow for quicker acceleration if you were talking about a lightweight flywheel, that would be measurably true. It is also true with the pulleys, but the difference is so minisule, it is unmeasurable by any practical means. Now, I contend (and this is somewhat disagreed upon) that you could measure, on a dyno, a hp increase with underdriven pulleys with an underdrive ratio greater than 20% over stock (about 2-8hp, big range for flame safety).
AlexCisneros 12-20-2005, 11:48 PM :scratchhe
...get the UR pullies. They're good, mkay...
:hippie:
zaglo6204 12-21-2005, 12:23 AM yeah, thats wat i thought. i just confused myself for a moment there......happens way too often. i think my parents dropped me on my head when i was little, but thats okay. i still love them for helping with car funding....hehehehehehehe. thanks for clearin it up carbon. :)
Fanman 12-21-2005, 12:37 AM I had to adjust my belts as well, still won't justify substantial increases. In the beginning of the post, the difference is only a few % of underdrive.
rotarygod 12-21-2005, 12:42 AM I've had underdrive pullies for RX-7s for years. I can't feel a thing different. It's not saying there isn't a difference. It's just not big enough for the human body to feel with any degree of accuracy. A dyno might see it though. The weight differences between pullies is a nothing more than advertising as people believe it makes a difference. As has been stated earlier, it's the location of the weight to the rotational centerline that makes the big difference. The pullies concentrate this weight close in. I could care less what a big V8 has as far as pullies go. We aren't talking about a V8 and their harmonic balancers weigh more than all the pullies combined anyways. The power gain comes from being under driven. Period. If and that's a big if, there is a power gain from weight loss on this car, it would be miniscule and probably smaller than the variation between 2 dyno runs so you'd never even prove it was there. I always find it funny that people swear by pullies and it's gains. A gain is a gain yes but don't expect to noticably feel it. That would be a placebo effect. If you combine this with several other small gains, they could add up to something you would actually notice though so they aren't worthless.
KJ238 12-21-2005, 11:36 PM I'm using a pair of Trust (GReddy in states) pulleys for the SE3P... I'll take a couple of pics later...
Jaguar_MBA 12-22-2005, 07:45 AM I have the SR Motorsports pullies on my RX-8. If you must get Pullies, I would suggest UR ones and save yourself a couple of hundred dollars.
On a regular piston car these work just fine because they have a heavy harmonic balancer. The RX-8 does not. Reducing weight on the crank shaft increases HP to the rear wheels...or reduces inefficiencies that reduce HP from the Rear Wheels. A standard harmonic balance on my 1992 300zx must have weighed ~ 20lbs and I replaced that with an aluminum unit that weighed ~ 4-5lbs or so. That is where the performance gain is to be had. RX8's underdrive crank pulley must weight ~ 1.25lb stock.
4 years to Supercharge 12-22-2005, 06:55 PM Anyone factor in RPM's?
The majority of gains, if not all, are after 4,000 RPM's. It is there for me and even if you barely pay attention to how your car feels you will notice a difference.
Since we have a higher revving engine the weight being less will make more of a difference with even small underdrive since it is spinning that many more revolutions per minute.
Jaguar_MBA 06-23-2006, 05:40 PM Right..all the gain is due to less parasitic drag....very limited gain from weight reduction....jump for joy +1HP
