Gear rattling (not throw-out)
Old Jul 30, 2003 | 06:49 PM
Elak's Avatar
Question Gear rattling (not throw-out)
Besides the throw-out bearing noise discussed elsewhere, I'm noticing more gear noise than I've experienced in previous manual cars. It is especially noticable in low gears - e.g. driving the last bit of my driveway in first gear. Is this normal with Mazda's (someone suggested straight cut gears v.s. angular). I'm thinking of going back to the dealer to test drive one of the lot cars to see if they sound the same. The noise is more rattling than just whining. Not really loud, just louder than expected.
Anyone else have this?
/Elak
Paranoia never feels lonely
Old Jul 30, 2003 | 07:27 PM
zoom44's Avatar
could it be something to do with the triple synchros?
Old Aug 1, 2003 | 03:14 AM
TerenceT's Avatar
the 8 uses dog box???????
Old Aug 1, 2003 | 03:33 AM
wakeech's Avatar
mostly harmless
hahaha... what?? hell no, then most of our forum members would probably be having significant problems with grinding...
nono, it's got TRIPLE cone synchros on first, second, and maybe (?) thrid, and dual cone synchros after that...
i cannot really offer any explination, as i'm extremely far removed from the RX-8 driving experience.
Old Aug 1, 2003 | 04:27 PM
TerenceT's Avatar
i know it's not a dog box, i wish tho... but Elak said straight cut.. :D
Old Aug 1, 2003 | 10:39 PM
P00Man's Avatar
uhhhhh....hello?
uhhhhhhhhhhh whats a dog box?
________
Wendie 99
Old Aug 2, 2003 | 12:40 AM
Digisan's Avatar
Alpha Powered
Yup, triple syncros on third
Old Aug 2, 2003 | 02:27 AM
TerenceT's Avatar
dog box is refered to transmission gears that are straight cut instead of angle cut (worm gears?)
angle cuts are quieter and easier to shift but dog gears are stronger, can shift clutchless at higher rpm and louder, i.e. motorcycle gears and race car tranny
Old Aug 2, 2003 | 01:37 PM
wakeech's Avatar
mostly harmless
well, that's usually one difference, but a dog box usually refers to the transmission having no synchros (meaning you have to rev match every single shift yourself). the ***** on the side of the gear selector (which poke into the side of the gear you want to spin the output shaft) are called "dog teeth", and if the selector and your next gear of choice are spinning at different rpm, you hear (and feel) that characteristic *BUZZ* of gear grinding.
thus, synchro-meshing is now a part of the modern gearbox. these are little collapseable cones on the side of the gear selector (usually a copper alloy, i think: nice and soft) which act like mini-clutches in the gear box. when you depress the clutch, your gearbox is completely separated from any source of acceleration and is basically free wheeling. when you go to engage the gear, the synchros touch the gear first, and act as a point of friction between them, bringing them to the same speed: this is why you cannot shift clutchless in a box with synchros, and why it's also so damned easy.
for more visual references and a differently worded explination see http://auto.howstuffworks.com/transmission.htm
Old Aug 4, 2003 | 11:57 AM
lefuton's Avatar
tyranosaurus rex-8
i don't see why that meants you cannot shift clutchlessly...i've done it, and it seems to work just fine.
Old Aug 4, 2003 | 02:04 PM
P00Man's Avatar
uhhhhh....hello?
why would you WANT to shift clutchless?
i mean, doesnt that like, destroy the transmission at worste, and make an awful sound at best?
________
LEXUS LF-XH SPECIFICATIONS
Old Aug 4, 2003 | 02:20 PM
DocHolliday's Avatar
I clutchless shifted my 82 Sentra all the time. As far as I could figure it out it slipped into gear right at the point the shaft and the gear were spinning at the same RPM's. When you do this you spare the clutch some wear and extend its life. I could be horribly wrong though.
Also that would explain why my 01 Stratus R/T does not clutchless shift. Tried a few times without much success.
Old Aug 4, 2003 | 02:29 PM
lefuton's Avatar
tyranosaurus rex-8
oh, by no means would one force it into gear, if you match the revs perfectly, it just slips right in, no sound, no bucking, no nothing, it's not terribly easy to do, but not entirely difficult either... that being said, i normally do use the clutch i was just curious why wakeech said you couldn't clutchless shift
Old Aug 4, 2003 | 10:13 PM
TerenceT's Avatar
clutch is meant to be a serviceable item, transmission is relatively not. the general concensus is to kill the clutch before killing the tranny.
depending on the gear and syncro designs, some syncroed tranny can clutchless shift. but again, these ideas are not meant for everyday driving right?
i think it's good if the 8 cannot clutchless shift, don't want to see, i power shift and over rev my 8 kinda threads
Old Aug 5, 2003 | 01:40 PM
Smoker's Avatar
RX-8: Hmmmmmmmmmmmmm.....
So how do you shift clutchless really ? (just wanted to know the theory behind it) Do you just shift into neutral rev match, and then shift to your next gear ? or do you just pop it to the next gear and couldn't careless ?
And another question ? What is the Throw-out bearing ?what is it purpose ?
Old Aug 5, 2003 | 01:46 PM
wakeech's Avatar
mostly harmless
...what the?? dammit!! lost my post!! stupid server... i already answered this one: i'll do it again on my lunch break.
short answer: you CAN, it'll kill your synchro's if you eff up.
Old Aug 5, 2003 | 01:56 PM
lefuton's Avatar
tyranosaurus rex-8
eh, good enough, i thought you meant you'd ruin syncros regardless of whether you did it correctly.
RevMeHarder
Jun 1, 2026 02:30 PM
theblinkof
Oct 4, 2023 05:24 PM
Mane
Nov 20, 2015 12:16 PM
Luke.s
Sep 30, 2015 05:57 PM
Zube6115
Sep 30, 2015 12:57 PM
