View Full Version : Vtec/Variocam/Vanos
Aoshi Shinomori
12-13-2005, 03:55 PM
Out of all of these kinds of systems, who was first? I am being badgered by someone because I was under the impression that Honda developed this kind of system first. He says Ferrari but I can't find any information telling me that. Can someone maybe fill me in and tell me where I can see this information? Thanks a lot.:)
BlueEyes
12-13-2005, 03:59 PM
NSX had the first variable valve timing on a production car.
Aoshi Shinomori
12-13-2005, 04:01 PM
I was just about to PM you. I thought that actually, but is there some resource that might help me prove someone wrong? I can't even find any information about Ferrari's version of this. :Freak_ani
brillo
12-13-2005, 04:06 PM
I don't count Ferrari as they are not really a production car.
Honda is likely the first, with Porsche right behind it.
BlueEyes
12-13-2005, 04:09 PM
Ferrari is most certainly a production car. Anyway, I don't know what the ferrari version is called, I know it works similar to Vanos, using cam phasing. Though, I believe they did it before Vanos.
I looked for a timeline, but couldn't find one. Everything I see says NSX was the first, however.
RX8-79
12-13-2005, 04:10 PM
The first experimentation with variable valve timing and lift was performed by General Motors. GM was actually interested in throttling the intake valves in order to reduce emissions. This was done by minimizing the amount of lift at low load to keep the intake velocity higher, thereby atomizing the intake charge. GM encountered problems running at very low lift, and abandoned the project.
The first functional variable valve timing system, including variable lift, was developed at Fiat. Developed by Giovanni Torazza in the 1970s, the system used hydraulic pressure to vary the fulcrum of the cam followers. The hydraulic pressure changed according to engine speed and intake pressure. The typical opening variation was 37%.
The next big step was taken by Honda in the late 1980s and 90s, where Honda began by experimenting with variable valve lift. Pleased with the results, engineers took the knowledge and applied it to the B16A engine, fitted to the 1989 EF9 Honda Civic. From there it has been used in a variety of applications, from sport to utility, by many different auto makers.
In the year 1992, BMW introduced VANOS, their version of a variable valve timing system, on the BMW M50 engine used in the 3 Series. VANOS significantly enhances emission management, increases output and torque, and offers better idling quality and fuel economy. The latest version of VANOS is double-VANOS, used in the new M3. Double-VANOS adds an adjustment of the intake and outlet camshafts.
Variable valve timing was the sole domain of overhead cam engines until the 2005, when General Motors began offering the LZE and LZ4, pushrod V6 engines with VVT. For the 2006 model year, General Motors will introduce the Vortec 6200, the first mass-produced pushrod engine with variable valve timing.
source: http://en.wikipedia.org/wiki/VVT
BlueEyes
12-13-2005, 04:13 PM
So, what the hell. Is the EF9 civic a production car? Anyhow, seems as if Honda was the first to put it into production.
moRotorMotor
12-13-2005, 04:36 PM
Click here. (http://www.teirney.net/civic/)
BlueEyes
12-13-2005, 04:39 PM
Word. Thanks.
therm8
12-13-2005, 05:13 PM
Mazda had its first variable intake timing system on the '81 JDM 6port 12A motor, if I remember reading correctly. Not entirely the same, but without camshafts it's the closest thing. :)
babylou
12-13-2005, 05:23 PM
Well heck, any Ferrari outsells the Honda NSX.
BlueEyes
12-13-2005, 05:28 PM
haha, it's funny because it's true.
rotarygod
12-13-2005, 06:05 PM
Correct! I was going to say this but you beat me to it. Mazda was first to do variable timing on a production car and it was first used on a rotary! If you want to go even farther back, they first tried the "combo port" back in the very early 70's which was a combination side and peripheral port that was controlled by opening additional butterflies on a carb.
ASH8
12-13-2005, 07:35 PM
Did this "combo port" (70's) make it into production?, if so what model, I am trying to recall, or was it only JDM.
I think this set up was in the JDM 'Luce' 4 Door in 1981.
Here, the piston model was the 929, 2 and 4 door hardtop...Luce rotary was never exported to.AU
As dealers we thought that this was coming to Australia as an RX-6, I recall looking at the car in Mazda's reception in Hiroshima...it was a deep blue 4 door hardtop.,,and yes 12A(B).
Im_DANomite
12-13-2005, 07:39 PM
i thought Nissan was the first to come up with variable valve timing technology. honda was the first to actually put it on a production car. that's what i always thought. too lazy to search around....
YT1300
12-14-2005, 01:15 PM
Ferrari and NSX are hardly mass-production vehicles.
I'd still probably consider the B16A-powered Civics to be the first incarnation (haha, I made a funny) of true variable valve timing technology on a mass-production scheme. Agreeably, Mazda, Fiat, and Ferrari all probably 'did it' first, but mass-production is where it counts...
tuj
12-14-2005, 01:19 PM
Ferrari also made a version of variable lift that was continuously variable, rather than the two-lobe vtec system. Basically the lobe was a smooth taper between low and high lift, and the follower was at an angle, thus varying the lift as the cam slid.
BlueEyes
12-14-2005, 01:35 PM
Who said they were mass production vehicles? and who said mass-production is where it counts?
If we're talking about dabbled in it first, then GM seems to be the answer. If we're talking who put it on a production car first, it seems to be Honda. Over in NA, the first car would be the NSX, in '91. I fail to see how being mass produced changes the fact that is was produced.
BlueEyes
12-14-2005, 01:36 PM
yeah, that's what's on the 360 isn't it. A 3 phase cam profile?
rotarygod
12-14-2005, 05:05 PM
Nope. It did briefly make it to a race engine but that was it.
Saint_Spinner
12-14-2005, 06:38 PM
Nope. The civic si or sir (can't remember) technically had it before the NSX.
BlueEyes
12-14-2005, 06:40 PM
yeah, thanks, we've been through it already.
YT1300
12-14-2005, 10:16 PM
The cynical reply: mass production counts in that a manufacturer thinks that they can actually put the engine into a car, and provide a standard warranty, and still make money.
The more-likely reason: mass production counts in that a manufacturer thinks that there are enough people stupid enough to buy a car with finicky technology and questionable reliability, and, despite a few trying to make warranty claims, still make money.
Oops. Maybe the "cynical" and "more-likely" labels are switched there...
BlueEyes
12-14-2005, 10:21 PM
That's nonsense. What was the first car with a gasoline engine? The one that sold X number of units, or the first car that had a gasoline engine in it?
Similarily, what was the first production car with a gasoline engine? the one that sold X number of units, or the first gasoline engine car sold to the public?
