coolingmist
12-12-2005, 10:04 PM
We have been working very hard to get our controller ready and it will be available for sale in about 4-6 weeks. Our methanol/water injection controllers will be designed for turbo/supercharged vehicles and we will have normally aspirated models also. This can be a great item for those that are having pinging/detonation problems and want more power out of your turbo/supercharged vehicle. It also is great for n/a cars that are running extreme timing/compression, etc.
The controller is completely programmable to allow you to change any of the variables. out of the box, it ships with 10 different programmed methanol/water maps. With addition of the ability to change the parameters, you can change the fuel curve infinite.
The rx7store.net carries our products and will be carrying this item as well. I just wanted to post the specs, a picture and the details for those of you that are interested in this kind of thing. Thanks for your time.
http://www.coolingmist.com/products/images/controller01.jpg
Controller Specifications:
· 16 Bit High Speed Digital Signal Processor (DSP) Control that operates at approximately 0.5ms.
· A tunable linear control algorithm updates the Motor control output > 2000 updates/second.
· 16 Bit Motor current control resolution provides finely tuned output adjustments of 0.001% of the maximum Motor current draw.
General Specifications:
· 10 position tuning switch limits maximum pump pressure to prevent intake engine bogging down.
· Boost pressure operating ranges 0 – 30 PSI, 0-100 PSI or 0-30” Hg vacuum (depending on model #) with an integrated pressure sensor.
· Variable Min and Max boost pressure settings with large knobs and resolution of 0.01 PSI over the boost pressure operating range.
· 12 bit resolution reading on boost pressure (0.01 PSI resolution over boost pressure operating range).
· A single green status LED simplifies operating status determination.
· High speed RS232 serial communications port operating at 115200 baud to allow data logging, analysis and custom configuration/calibration of the unit using Vari-COOL PC software.
· Coolingmist Vari-COOL software provides precise adjustment and configuration of VariCOOL operating parameters.
Physical Specifications:
· Operating temperature range of 0 - 85°C (32 - 185°F)
· 10/32 Male threaded pressure input port accepts 10/32 Female to barbed tubing connection that can be easily sized to accommodate various tubing sizes.
· Heavy gauge all aluminum enclosure construction with black powder coat paint for long lasting finish durability.
· Enclosure mounting tabs provide ease of mounting in any location.
· Durable label is smudge proof, chemical and petroleum products resistant and does not deteriorate over time.
Electrical Specifications:
· Operates on wide input voltage range 7 – 26 VDC
· Up to 30Amps DC to the pump across the operating voltage range (using proper wiring and fuse).
· Unit itself draws less than 50mA with the Motor control output turned off. This means that if the car is not running, this unit can run off the battery alone for a very long time.
· 0 – 5VDC Auxiliary Input with transient voltage protection and 12 bit resolution (0.01 V resolution) can be used with any 0-5VDC sensor to control the Motor Output level or monitored (via serial port).
· External automotive style fuse protection that can easily be sized to accommodate various motor sizes.
· Can be wired directly to the electrical system for always on operation or wired through an Automotive Relay connected to the ignition switch for ignition switch operation.
The price of our controller is $199.99.
Software specs are below:
Vari-Cool software specifications
Overview
Software talks to the Vari-Cool unit using a serial port that will work with any compatible PC running Windows 2000, Windows XP, Windows 2003, Windows ME, Windows 98, or Windows NT.
Vari-Cool operates in 2 modes. Run mode and configuration mode. In run mode, you monitor data collected by the Vari-Cool unit. In configuration mode, you can set tuning and calibration parameters.
Serial Port
Vari-Cool serial port has the following settings:
Baud Rate 115200 baud
Data Bits 8 bits
Stop Bits 1 bit
Parity None
Flow Control None
The Vari-Cool serial port connector is a standard 9 Pin Female DSUB style connector. The Vari-Cool is configured as Data Communications Equipment (DCE device). The connector pin out is as follows:
DSUB-9 Pin Number Function
2 TX – Transmit Data
3 RX – Receive Data
5 GND
* Other pins are not connected and have no function
Run Mode (Status LED Fast Flash)
The Run Mode is the default operating mode of the Vari-Cool controller. While in the Run Mode the Vari-Cool controller continuously runs the motor control processing loop. This loop reads the inputs and adjusts the motor control output accordingly. In the Run Mode a Status Message can be requested or setup to be sent automatically on a configurable Timer period.
The following data values are monitored, logged, and charted with the software:
- Operation mode (0=Run Mode, 1=Configuration Mode)
- Boost Pressure Reading (PSI or “Hg, whichever applies)
- 0-5V Auxiliary Input Reading (%)
- Output to Motor (%)
- Minimum Pressure Setting (PSI or “Hg)
- Maximum Pressure Setting (PSI or “Hg)
- Tune Switch Setting (1-10)
- Auxiliary Input Switch Setting
- Controller Status
Configuration Mode (Status LED Slow Flash)
The Configuration Mode of the Vari-Cool controller provides an operating mode in which Configuration Parameters can be read and written.
The following parameters are able to be modified:
- Minimum Motor Output (%) – This is minimum output at which the pump is able to operate and spray water. This value defaults to the requirements of the pumps we supply. If you use a different pump, you may need to modify this value.
- Maximum Motor Output (%) – This is the maximum output at which the pump should ever operate. This value defaults to the requirements of the pumps we supply. If you use a different pump, you may need to modify this value.
- Minimum Pressure (PSI or “Hg) – This is the minimum calibrated range of the pressure sensor supplied with the Vari-Cool unit.
- Maximum Pressure (PSI or “Hg) – This is the maximum calibrated range of the pressure sensor supplied with the Vari-Cool unit.
- Tuning Parameter – This is a parameter that will change the shape of the output curve to the pump. This can be used to account for any non-linear effects of your vehicle, pump, etc. By default, the unit will be calibrated; however you may wish to work with this curve to obtain even better results.
Coolingmist does things right. When we set out to design a product...simply put...Its better. When we designed our checkvalve we had it made out of brass and gave it a 45 lb cracking pressure. This makes it bullet-proof and the safest water/methanol injection kit you can put on your car (much more reliable than ANY solenoid or cheap plastic checkvalve). When we designed our kits everything was designed to be put together seamless.
Our controller is no exception, infact it re-writes the rules of controllers. We are the first and only controller on the market that is user-configurable. This makes a great option for those that want to tune to the last detail. No other controller will allow you to do that. For those that just want a simple controller you are in for a pleasant suprise. The Vari-Cool coolingmist controller is designed to be superior to all other controllers out of the box. This means you can install the controller on your car and be able to fine tune to your vehicle far better than any other controller on the market..without even using the software.
Look at other controllers on the market and compare. We designed ours to compare favorably to all other controllers in Design, ease of use, performance, durability and functionality. We are certain that we can say this is the best, highest performing, most user friendly controller ever built.
Dont you love it when you purchase a controller and then 3 weeks later the newer and better one is out? Or every 2 months release a new "Stage". ?
We dont need to do those gimmics here. Because of the software, if we come out with a "stage II" it will be a simple software download. How is that for convenience?
Here is a sample of how you can change the output curve. Note that this is just a sample, the possibilities are infinite and can be configured to your own needs if you wish.
http://www.coolingmist.com/pictures/tuning_plot.jpg
Overview
Serial Port
Data Bits 8 bits
Stop Bits 1 bit
Parity None
Flow Control None
3 RX – Receive Data
5 GND
- Controller Status
