View Full Version : Headlamp washer thingy
Evil Weevil
07-30-2003, 07:59 AM
Another little thing I noticed; most of the official Mazda UK pictures I've seen don't have the little moulded headlamp-washer blanking plate (for want of a better way of describing it!). But the review cars (Autoexpress pics on the forum somewhere) do. Some of the US cars have it, and some don't. I've yet to see a car with an actual headlamp washer unit... anyone know what's going on?
Personally I think the car looks alot neater without that extra lump of plastic.
c170673
07-30-2003, 08:14 AM
The washers are a requirement for the Xenon headlights which come with the High Power version.
If you do a search there are a number of threads which have discussed this previously.
Chris
RobDickinson
07-30-2003, 08:19 AM
Yep - legal requirement for HIDs. So I guess the low powers wont have, and some US car packages have HIDs too.
oilman
07-30-2003, 08:23 AM
I believe you're correct Mr Dickinson although headlamp washers is not mentioned anywhere in the spec.
Cheers
Oilman
Evil Weevil
07-30-2003, 09:05 AM
Ahh, so I guess what looks like a blanking plate must actually be a very 'slimline' washer unit. I had read the various other posts about it but couldn't determine whether it was a blanking panel or the real thing.
Gord96BRG
07-30-2003, 10:55 AM
Nope, it's the cover on a pop-up washer unit - when activated, it pops up an inch or so to spray the lights (similar to current Audi headlight washers).
No US car has headlight washers, period, regardless of option package or type of headlight. However, every Canadian car has headlight washers, regardless of package.
Regards,
Gordon
hairyfrog
07-30-2003, 04:26 PM
A pop up headlamp washer... cooool!
I do love a good gadget :)
Lensman
07-30-2003, 04:35 PM
Just in case any of you can't visualise how these units operate:
The whole rectangular panel under each light moves forward about 2.5 centimetres (1 inch) and then two diagonally angled washer jets poke out of the top of the hole and spray the lamp. Then they scurry back home. Apparently some owners of other cars call them 'The Aliens': you'll see why eventually.
rael
07-31-2003, 02:04 AM
'Aliens' was the name given by the TT Forum as the TTC has the same system which is watered powered. ie only works when the lights are on but then after a few seconds of normal front window spraying once the water pressure has built up sufficiently. Weird thing is seeing your aliens is something you can never do solo.
rael
