DCaraway
11-30-2005, 08:38 PM
Since "flooding" happens to a significant percentage of RX-8's I wanted to understand what was happening and why. I have looked at a number of threads with bits and pieces and rants and fixes.
Does flooding occur from a leaking of the injectors in a cold condition or poor ECU logic? Or is there a loss of compression/rotor seal due to the cold engine and excess fuel?
It appears to consistantly occur with a cold start and shutdown before the engine warms and air temperature may be a factor. Then the engine will crank but won't start. What actually happened is less clear.
In a piston engine there is too much fuel to support ignition, usually from carburetion problems or pumping the throttle too much, and in extreme cases you could fluid lock the engine. This is hard to do with a modern stock fuel injected piston engine. To restart the engine means cleaning the plugs and allowing the excess fuel to evaporate.
In the rotary engine cleaning the plugs and airing out the combustion chamber only occasionally works. The factory fixes include: haul it to the dealer, reflashing, hotter plugs, faster starter motor, bigger battery, retrain the owner ( I may have missed a few). The DIY fixes include: let the car sit for days/weeks, clean the plugs, replace the plugs, inject water/antifreeze/oil/atf fluid, extended startup startup/shutdown procedure. Some of these fixes are consistant with classic piston engine flooding and some with loss of compression.
My engineering curiosity is tweaked with this one and I appreciate your feedback.
