Navagation question
Old Nov 29, 2005 | 03:54 PM
mikeb's Avatar
100% Italian
Navagation question
My dealer set a marked point on my nav and I cant remove it so now when I drive it keeps recaluting. how do you remove the marked point?
Old Nov 29, 2005 | 04:05 PM
Hung_horse31's Avatar
I think you need to press down on the button(joy stick) and then select "delete destination".
Old Nov 29, 2005 | 04:11 PM
cleoent's Avatar
n00b
yeah, all you have to do is in the main map area (where it shows yoru cars and the streets) click the joystick down, you'll have all kinds of options. One of them is marked something like "disable navigation" or something like that. I think it's the last option. GL.
Old Nov 29, 2005 | 04:15 PM
mikeb's Avatar
100% Italian
I will try that
it changed since I got the new nav disc from mazda
Old Nov 29, 2005 | 04:19 PM
8is>enuff's Avatar
Bland
What they mentioned will delete the current destination and stop the annoying "recalculating" crap. If you want to delete the marked point in its entirety you have to go through the menu. I'm not sure the exact options to take, but it's marked "Edit Marked Points" or something similar.
Old Nov 29, 2005 | 04:39 PM
mikeb's Avatar
100% Italian
thanks guys I will try it later
Old Nov 29, 2005 | 05:35 PM
JeRKy 8 Owner's Avatar
Stuck in a love triangle
Is this a joke? You've owned your car for this long and still don't know how to work everything with the navigation system?
Old Nov 29, 2005 | 05:37 PM
mikeb's Avatar
100% Italian
I know, but I have not set a point since I got the new nav disc and its not the same as before
Old Nov 29, 2005 | 06:35 PM
mikeb's Avatar
100% Italian
sorry guys but just hitting down or enter doesnt help remove it
Old Nov 29, 2005 | 06:42 PM
dwill9578's Avatar
I got the same problem, can't seem to get rid of them either. Also did Mazda send you the new disc? or did ya buy it?
Old Nov 29, 2005 | 06:59 PM
Napboy's Avatar
Sho'Nuff
i haven't really seen the answer to this, but do the new maps have updated restaurants and other poi's?
Old Nov 29, 2005 | 07:11 PM
mikeb's Avatar
100% Italian
mazda sent me the disc and its free
Old Nov 29, 2005 | 07:14 PM
RedSheDevil's Avatar
.:. causing mischief
the mazda disc is for the updated SOFTWARE. you have to buy the updated MAP disc.
oh and id suggest for the delete marked point. i can explain it ... but it was more fun to use my "read the manual" smilie ...
Old Nov 29, 2005 | 07:25 PM
mikeb's Avatar
100% Italian
thanks^^^^^^^^^^NOT
Old Nov 29, 2005 | 07:30 PM
ok fine...
Setup Menu>Edit Marked Point>Edit>Select a Marked Point from the List>Delete
better?
Old Nov 29, 2005 | 07:31 PM
or pages 333-334 in the online manual ...
Old Nov 29, 2005 | 07:33 PM
mikeb's Avatar
100% Italian
thank you but that delets it from the history but not off the main screen which keeps recalculating the location
Old Nov 29, 2005 | 07:38 PM
hmmmm ... and you already tried pushing the joystick down to get the menu on the left? you should be able to scroll down that menu and hit "Stop Navigation" or sumpin to that effect
Old Nov 29, 2005 | 07:39 PM
Enter>Stop Calc>Enter
or
Enter>Guidance Off>Enter
Old Nov 29, 2005 | 07:42 PM
mikeb's Avatar
100% Italian
I will try those
Old Nov 29, 2005 | 09:47 PM
mikeb's Avatar
100% Italian
thank you
that was it
Old Nov 29, 2005 | 10:13 PM
sweet. glad it helped!
Old Nov 30, 2005 | 11:58 AM
NomisR's Avatar
How do you get the update disc? Does it get rid of the voice but keep the Ping, warning thing on?
Old Nov 30, 2005 | 12:10 PM
you do know you can turn the voice off, right?
Old Nov 30, 2005 | 02:13 PM
UK BLACK's Avatar
Simply press POS and that will get rid of the marked point.
