Doctorr
07-29-2003, 10:25 AM
After spending an hour or so looking for the block heater, I phoned Mazda Canada - "No Sir, the RX-8 doesn't have a block heater."
doc
doc
View Full Version : No Block Heaters........... Doctorr 07-29-2003, 10:25 AM After spending an hour or so looking for the block heater, I phoned Mazda Canada - "No Sir, the RX-8 doesn't have a block heater." . . . doc wakeech 07-29-2003, 12:17 PM :eek: WTF??? i suppose in their view anyone who can afford an RX-8 can afford a HEATED garage, eh?? :eek: Midnight Flyer 07-29-2003, 12:41 PM Before anyone gets upset, did the 7? I have found with my Miata that even on the coldest day I have not needed the block heater. That may change in a number of years but after 3 winters it has never been plugged in. WankelWannabe 07-29-2003, 01:16 PM While it may not come with one standard I would assume you get one added, no? I'm pretty sure the 7 had em. Wing 07-29-2003, 01:25 PM It's an option on most cars, it's only $100, it's on the option list. Buy one at crappy tire and put it in. Simple. But heck my Hyundai doesn't have one and I have no troubles. Midnight Flyer 07-29-2003, 01:54 PM It is not that simple. There has to be a place to install it. In most cars they take the frost plug out and replace it with a coil that gets heated to warm up the engine coolant which warms up the engine and oil. If there is no hole you can't install the block heater. Wing 07-29-2003, 01:56 PM You can get the "stick-on" kind although I guess that won't work if it's alluminum.... anyway it's an option on the website. Isell8'stoyou 07-29-2003, 02:27 PM Hey there. I am friend of a parts guy for a Mazda dealership, so when i saw this question i called him up for the answer. In his listings for accessories it is not shown as an available part. Maybe someone saw it as an after-market part but from the factory it is not available. Sorry! Doctorr 07-29-2003, 03:04 PM So, there you have it. No, it doesn't have one, and no, they're not an option....... Looks like there will be a warranteed starter motor in MY future! And when it won't start, I'll be having Mazda Assistance thaw it out for me. . . . doc Doctorr 09-05-2003, 12:43 AM Well, it's now September...... There is still no block heater listed for the '8'. Consulted an expert in Mazdafixology - Carl at Mazdicare in Edmonton, and several random parts guys.......no, Mazda has none listed, and the RX-7 one will definitely not fit, there is a motor mount where it goes. September, people........ Things go downhill fast from here.......... . . . doc canzoomer 09-05-2003, 01:31 AM Thanks for mentioning this guys! I just looked at my sales invoice, where it says: "Price Includes: Freight & PDI, Block Heater, Floor Mats, Full tank of fuel..." This might be fun. I intend to winter drive this car. Are there no frost plugs in the engine anywhere?? Let's face it, at -30, it is going to be a bitch to turn over.. TT2RX8 09-05-2003, 06:13 AM I remember that many years ago, on my Toyota 78, I installed a different kind of block heater; it was install on the hose between the radiator and the motor (you had to cut the hose to install it). The nice thing about it was that the coolean not only was heated, but was also circulating into the motor. radiator =====//////===== motor Block heater -----^ I think I bought it at Canadian Tire... anyone knows if it's easy to reach the main hose on the 8.. and cut it? Wing 09-05-2003, 07:28 AM Good battery, new car with good compression. Shouldn't be an issue. Maybe for you guys up north, but I never had a problem with my Hyundai in the winter, even when it was -40. Just DON'T let go of the key until it starts, because if you do, YOUR SCREWED! Len 09-05-2003, 09:19 AM I've never had a place where I could plug in a block heater, so I'm just hoping the RX-8 starts as well in the winter as my old Prelude did. elusiv 09-05-2003, 02:36 PM Originally posted by Wing Good battery, new car with good compression. Shouldn't be an issue. Maybe for you guys up north, but I never had a problem with my Hyundai in the winter, even when it was -40. Just DON'T let go of the key until it starts, because if you do, YOUR SCREWED! can you or someone else please elaborate? or are u just joking? .. im assming this has something to do with flooding the engine.... Wing 09-05-2003, 03:08 PM Yeah, if you flood it your screwed. So sometimes when I start the car, I accidently let the key go too early (since I never want to hold it too long!). If you do this in the summer, no biggy you just try again, chances are you will have to crank a little longer to get rid of that excess fuel you just pumped into the engine. The problem in the winter is that your battery ain't going to last for that extra cranking time. If you flood it, chances are the battery isn't going to have enough juice to crank for the next 20 seconds to get it going. I've had a few close calls at -40 this way. When it's REALLY cold, I usually make SURE the engine is started before letting go, JUST IN CASE. Also, instead of cranking you can let the car sit and the gas will evaporate after awhile. But again in the winter it will take a long time for that to happen. canzoomer 09-05-2003, 03:44 PM I talked to Mazda Canada today, got the call escalated to the manager for Customer Relations. Posed a list of questions, he called me back with the answers, including the block heater: 1) What about the lack of block heater? "Mazda Canada is aware of the problem. At this time we have no solution or plans to respond with. We will likely have something, but I can not tell you when. " I suggested simply adding an inline circulating heater, such as is mentioned a few messages up. He said that he personally had used such a thing, but Mazda Canada has no policy, response, or stance on this. As it is included on my sales invoice I should take it up with my dealer. 2) What about the fact that the dealer gave me a brochure at time of ordering that lists the leather covered parking brake handle? "That has been deleted in newer brochures" I asked what that means. In less words than he used: "Tough" 3) The brochure lists a dashboard 12 volt outlet, AND it lists a cigarette lighter. "Mazda Canada has included the cigarette lighter at no charge" What about the fact the brochure lists both? "The outlet referred to is the one with the cigarette lighter in it." 4) I am one of the owners with the problem with the oil light coming on sometimes: "One should check oil level every time you buy gas" I do, but it comes on when the oil is at 3/4 full.. "We expect to be issuing a service bulletin soon, perhaps in a couple of weeks. We will have to bring the parts needed into Canadian inventory" What if I am going to the USA in about 2 weeks. Can they do the work down there for me? "Yes, but you will want to contact them first with your VIN # so they can order in the part. You might want to make sure the dealer is not doing this for the first time on your car" I asked him how this would be different from my dealer doing it for the first time? He replied"If they do it here, at least you will not be stuck in the USA with no car." I replied that this should be no problem as Mazda USA has a loaner program in place, unlike Mazda Canada. He replied: " True, but Canada cars have a 5 year powertrain warranty" I asked him that if this was the case, and if my engine fell apart after 4 years, would they offer me a $500 rebate? Such glowing confidence they have in their service centres.. 5) The brochure lists the headlights as being Xenon. On my car only the low beams are Xenon. "All specifications are subject to change without notice" Mazda Canada are incompetent slimeballs. And the only way we are going to get enough pressure on them to act ethically is for the majority of us to refuse to take their bullshit. It is too bad the majority of you reading this are so much in the honeymoon stage that you cannot see them for what they are. Wing 09-05-2003, 03:58 PM 1. at least they are aware, that is good, will they do anything? Time will tell 2,3,5 (well 2 I didn't know about, 3 is a technicallity probably printed wrong by marketting and so is 5). I don't have xenon's so for me this is a non-issue. Do any other cars have high-beam xenon's? That is ODD..... 4) Not sure I understand the 5 yr power train comment, or the $500 rebate??? I am not in honeymoon phase anymore, I'm still thinking about the offer. But I can't say they are totally incompetant. Now Hyundai Canada WAS, they didn't care a rats ass about the customer. Seems like Mazda is MILES and MILES ahead of them. Look at the hyundai HP issue, they didn't do ANYTHING in canada, only the US. canzoomer, have you had to deal with this type of thing before with another car company? I went through crap with Hyundai and it was HORRIBLE. I got nowhere, even after talking to the President of customer service, I had his direct line number we talked for 3 hours, no go, NOTHING NADA. A big screw you, you customer you are nothing to us. It would be the same with any company... trust me on this. But again if you are truely dissatisfied return the car. I'm teatering..... I LOVE the car, but there are a few problems that need to be addressed. They might be addressed in time, but then it might be too late (october) by then. canzoomer 09-05-2003, 04:19 PM Originally posted by Wing 1. at least they are aware, that is good, will they do anything? Time will tell 2,3,5 (well 2 I didn't know about, 3 is a technicallity probably printed wrong by marketting and so is 5). I don't have xenon's so for me this is a non-issue. Do any other cars have high-beam xenon's? That is ODD..... Many do. In the case of most brands they either say: Low beam Xenon HID, or "bi-Xenon", and so on. Audi says "Xenon", and it means both low and high beams. Mercedes says BiXenon, Lexus say "low beam Xenon" for examples 4) Not sure I understand the 5 yr power train comment, or the $500 rebate??? Mazda USA provides 48 month, 50,000 mile warranty. Mazda Canada provides 36 month, 80,000km warranty. USA includes loaner cars and tank of gas with each service. Canada does not. USA offered teh $500 US dollar credit. Canada offered us $500 Canadian, about the equivalent of $350 US. I am not in honeymoon phase anymore, I'm still thinking about the offer. canzoomer, have you had to deal with this type of thing before with another car company? I went through crap with Hyundai and it was HORRIBLE. I got nowhere, even after talking to the President of customer service, I had his direct line number we talked for 3 hours, no go, NOTHING NADA. A big screw you, you customer you are nothing to us. It would be the same with any company... trust me on this. But again if you are truely dissatisfied return the car. I'm teatering..... I LOVE the car, but there are a few problems that need to be addressed. They might be addressed in time, but then it might be too late (october) by then. I have not owned a Hyundai, but did get a run-around from Nissan Canada on my Spec V with the claimed horsepower, and with the fact that we told them about an ECU over-rich condition causing backfiring, and it took them about a year to own up to it and issue a recall. About half the owners got new engines as a result. The pre-cat would get damaged by the backfiring, and bits got sucked into the exhaust valves. I had no problems at all, as I replaced the entire exhaust system almost immediately with a header, pipe, Vibrant Tech cat, and Magnaflow resonator and muffler. Between that and a cold air intake and a few minor bolt on mods I kicked the cars power up from 143 on a dyno to 190. For a pretty small cost too. In the recall Nissan replaces engines as needed, replaces exhaust on all cases, and are reprogramming the ECU, resulting in a mileage improvement of about 3mpg, and 5hp. It took them a while, but they DID do it. In the case of the RX-8 I am nervous about wholesale changes. I bought the Spec V expecting to do the work. I sold it to get my RX expecting a car with the power from the factory. I recall telling my wife about a month before I got my 8: "I thinkit will be nice to just drive a car, and not be working on mods and wasting my time chasing the manufacturer" Boy, was I wrong. This sucker is looking more an more like your Hyundai experience every day. No provision for a block heater? They did not even think about it? Freaking rocket scientists You are right. IF I want to drive the car in the winter I need to do the oil pan, block heater, wheels and tires now, not later. The heating controls bug would be nice to have fixed as well. I LOVE the car. I HATE mazda Canada. They are such assholes. If I keep it I can pretty well assume I am on my own from now on for warranty and service. If I sell it I have to get a car to drive. What car? Either I spend about $5 to $8K more, wait 3 to 6 months for back ordered cars, or just give up and drive a pickup truck or something.. Crap! Wing 09-05-2003, 04:27 PM Originally posted by canzoomer If I sell it I have to get a car to drive. What car? Either I spend about $5 to $8K more, wait 3 to 6 months for back ordered cars, or just give up and drive a pickup truck or something.. Crap! This is MY dilema, how dare you have it too :p Although the car I would buy to replace would probably be an acura TSX which is a few thousand cheaper. But then I think, hell, why not just take the $2000 I put down. Buy a car / truck or something with it, drive a crap car and save $800 a month financing charges! If I put that $800 a month on my house it would be paid in like 10 years instead of 25! But damn it..... I'm stupid and love my flashy cars! :D Wing 09-05-2003, 04:38 PM Was talking to my father (mechanic) he said they sell magnetic heaters that you can stick onto the oil pan. It is not the best solution but it would warm the oil which should warm the engine faster on startup. canzoomer 09-05-2003, 04:50 PM Originally posted by Wing Was talking to my father (mechanic) he said they sell magnetic heaters that you can stick onto the oil pan. It is not the best solution but it would warm the oil which should warm the engine faster on startup. I tried one a few years back. they don't work worth crap. An inline heater is easy to install, does not cost much, and works really well. They go inline into the heater hose. You just cut the hose, pop it in, tighten two hose clamps, and plug it into a 12V source. My dealer could install it if Mazda Canada would bless it.. But they won't so to get a block heater I have to install it myself. Technically that would void my warranty if they want to play that card on me. Do I trust them NOT to? Hell no. Evolv 09-08-2003, 09:04 AM To answer the ? did an RX-7 have a block heater: YES, the 1st gen 12A did but the block was drilled to accept it. It was about 10cm in length and was installed in the center of the block from right to left at the base of the engine just above the oil pan. It worked better then anything I have ever seen. Too bad its not available for the Renesis. If you want a block heater, but dont want to cut hoses incase Mazda tries to void your warantee try one of these. A Crankcase/Oil Heater designed for Airplanes. They are flat in shape, self adhesive and can be stuck to the bottom or side of your oil pan. They plug into a 120V source. The cost depending on size is 60-100 USD. Just do a search for Aviation Crankcase Oil Heaters. These work very very well. I had one on my Volvo when I lived in the Yukon. I would llike to say that in my opinion and dealings with Mazda Canada in the past, that they have been excellent to work with. Customer service among most auto manufacurers suck, you have all read the posts about the lack of customer service from Hyundai and Nissan, well those are just a few examples. Mazda listens, you can bet that anything you discuss with them gets forwarded to Japan for further discussion. With my 7, I had an excellent experience with Mazda getting some work done when the vehicle was out of warantee. Its a bit long so I wont post it here. It will take a few years to work all the bugs out of the 8, after all it is a new car and the first of its kind in the world. SA22C 09-08-2003, 01:43 PM The 'block heater' on my RX-7 is a strip of metal that fits over the front rotor's spark plugs. When plugged in, it glows red hot, and presumably warms the motor. I don't use it, and I don't need it. If the weather get's down to minus 40 centigrade, the 7 will still start on a regular basis. I have a good battery and use 0w30 oil. Literatii 09-08-2003, 07:47 PM This is interesting because if I were still in Winnipeg I certainly would not buy the 8 for lack of a block heater. But Calgary has, at most, 3 weeks of > -20c weather per year and that's where I am now. However, I spent years with vehicles in Winnipeg that did not have good block heaters, or had no place to plug them in. The solution was to start the thing just before I went to bed, and run it for 10-15 minutes. Made all the difference in the world the next morning. --Lit Edmonton s/silv 09-14-2003, 06:44 PM I have a new mazda now, but not before my 225 audi tt burnt up in 20mins.....Stuck a audi pan warmer to the bottom and it fried everything never ogt the truth but got the $$$$$$. Audi was faster, but cant beat the back seat of the mazda a little more versitile. He lets hold are dealers responsible for this block heater where the hell is it...i asked specifically if they came with one at the car show and dealership everyone said "YES" canzoomer 09-14-2003, 08:45 PM Originally posted by Edmonton s/silv I have a new mazda now, but not before my 225 audi tt burnt up in 20mins.....Stuck a audi pan warmer to the bottom and it fried everything never ogt the truth but got the $$$$$$. Audi was faster, but cant beat the back seat of the mazda a little more versitile. He lets hold are dealers responsible for this block heater where the hell is it...i asked specifically if they came with one at the car show and dealership everyone said "YES" Don't blame the dealers for that. They were specifically told by Mazda Canada that they would be shipped with block heaters. This led my dealer (Jarman) to put on the sales invoice"block heater" It was only later that they were informed that there is no block heater option. As posted earlier it is no big deal to install a circulating heater, but as it is not genuine Mazda, the dealers have concerns that is might present warranty issues. |
