I need some help
Old Nov 20, 2005 | 11:13 PM
Jonjieracer's Avatar
I need some help
I just noticed driving tonight that my head light on the left is out. Has anyone had the same problem, mine is about 25thou miles, I thought that was too early for my head light to go out. Pls. direct me to a site where I can buy a replacement and how to replace it. I will continue to search online. thanks guys!
Old Nov 21, 2005 | 12:29 AM
high beam or low beam, which model of car????
if it is a low beam and you have a sport, gs or gt take it to the dealer. it is a zenon bulb, expensive and is covered.
Old Nov 21, 2005 | 12:33 AM
hoping that it'll be covered. It's an RX8 6 speed, thanks!!!
Old Nov 21, 2005 | 12:35 AM
do you know what type????? do you have fog lights or traction control???? leather or sunroof????
Old Nov 21, 2005 | 12:36 AM
got the basic
Old Nov 21, 2005 | 12:39 AM
then you has standard bulbs. i think they are type h 7. doubt the dealer will cover it.
i think the easiest way to change them is to loosen the covering in front of the wheel and get to them from there.
hope this helps.
Old Nov 22, 2005 | 08:49 PM
Astral's Avatar
Purveyor of fine bass
when you go to your local store to buy a replacement, i strongly recommend the phillips hivisbility "30%+" bulbs (the packaging has some blue design on it). these are the best/brightest/sharpest cutoff halogen bulbs that you can buy in a store right now. barring that, sylvania xtravision is your next best bet. would not recommend sylvania silverstar, as those are the white-style headlights and burn out quickly while delivering not much more light than the stockers.
Old Nov 25, 2005 | 05:04 AM
thanks, guys for all your response. The day after I posted the topic, I have it taken cared of by Mazda of Clearlake, they replace the whole headlamp, I think it would cost close to a thousand but it was charged under warranty. The bulbs bursted into fine little grainy pieces 2-3 times bigger than of a sugar. Yep, just like that....so I really don't know what caused the blow-out, it was replaced. Mazda of Clearlake; You're awesome
Old Dec 4, 2005 | 11:09 AM
TCReedy1's Avatar
Your bursting bulbs
Fek! Sounds horrible.....did your dealer give you any explanation? Not seen any threads or posts on this issue before this. Busrting bulbs sounds like spring fantasia or a nasty short circuit but i`m no sparky and the direction of electrons is all witchcraft to me!!
