View Full Version : shifting with D
foo77
11-19-2005, 09:36 AM
hi guys! i've question about shifting our car with D :scratchhe
i realised it when my friend shift his car with D, the shift number(1,2,3,4)appear :Wconfused
so do you guys think it should appear when i shift it with D?because its never appear except when i used M(semi) :confused:
therm8
11-19-2005, 12:14 PM
Mine disappear, in Drive also. Always have.
Vertigo-1
11-19-2005, 10:35 PM
Mines appear even in Drive and goes up and down as the car shifts on its own. Which is a good thing as it lets me monitor which gear the car is already in in the event I need to go into Manual and downshift.
JonnyBoy
11-20-2005, 12:40 AM
YOu mean that when its in D, u cant see the gear number? My car has always shown the number in D or M
mikeb
11-20-2005, 03:41 AM
what
mine only shows the numbers in M
NgoRX8
11-20-2005, 05:26 AM
Mine shows in both. It helps to know when the car shifts itself.
JonnyBoy
11-20-2005, 05:38 AM
this is quite strange! and i agree with NgoRX8, its good to knwo wat gear it is in, even when in D mode
Rotor Kreuzer
11-20-2005, 06:33 AM
Huh?!?! Mine shows 'D' when I drive with D, and numbers when I manual shift. My 8 is an '03.
foo77
11-20-2005, 11:18 AM
thanks for the reply guys :) at least i know its not just me :uhh: mine same like Rotor Kreuzer 2003,but my D never appear except a small dot gren lamp next to it :scratchhe hows bout you mikeb :icon5: its make me wonder the wiring :Wconfused any idea guys? :confused:
ps: i agree its help us to know what gear we shift at :)
JonnyBoy
11-20-2005, 11:45 AM
you guys get a D displayed instead of the gear numbers? my is an 05 build, JDM spec. i'll try and find out from the people with 03 JDMs...very strange in deed
therm8
11-20-2005, 12:17 PM
numbers when in M, blank in D, for me. Must be an early build thing. Mine was built Jun '03 iirc.
foo77
11-21-2005, 04:28 AM
^^just like me D:blank M:numbers , mine JDM spec 03
Guisslapp
11-21-2005, 09:50 AM
I have numbers in both D and M. Mine is an '05.
NgoRX8
11-21-2005, 10:30 AM
Then so it must be that the 03 builds didn't come with this feature.
mikeb
11-21-2005, 06:20 PM
^^ must be
I got mine in july 03
bxb40
11-22-2005, 07:12 PM
May '04 build shows gear numbers in both D and M.
ZooTender
11-22-2005, 10:03 PM
Ditto
ferrocene
11-22-2005, 11:35 PM
Mine shows numbers in both D and M, early '04 model. As a side note, the numbers change sometimes a good second or two before the tranny shifts. Anyone experience this? It only makes the shift lag appear worse. Esp. from 3rd to 4th.
NgoRX8
11-23-2005, 12:42 AM
^ Yes, thats how it works.
Rotor Kreuzer
11-23-2005, 11:00 AM
Oops! Sorry guys! Hehehehe, just checked and my JDM '03 shows nothing when I drive in 'D' too! Been driving in manual mode too much I guess! :D:
my10ae
11-25-2005, 07:33 PM
So is there anyone out there who drive in "D" and see's the gear number they are in? I have a 2004 build date of 8/03 and when in full D mode, I only see the D, when in manual-matic, I see the gear numbers.
foo77
11-26-2005, 04:37 AM
^ what do you mean when in full D mode, I only see the D?
mostly 03 D don't come with number or letter D, D:blank M:number and 04 both D & M come with number ;)
BRGREEN8
11-26-2005, 06:49 AM
i have an 05 and in both auto and semi-auto mode numbers show. although in full auto mode the number will go from 3 to 1 if it was in third
lsujim
11-29-2005, 08:01 PM
I have an 04AT and numbers show in either mode!
Terrance26
12-05-2005, 06:19 PM
Mine is an 04 I get numbers with both.
Steakboy42
12-07-2005, 08:15 AM
Mine's an 04 witha build date of 7/03. Mine only shows numbers in M and nothing in D
-Steakboy
foo77
12-07-2005, 10:39 AM
i think all Rx8 that build date around 03' probably will be no numbers in D although the car is 04' ;)
punikin
12-09-2005, 09:16 PM
Build date June 2004, and I get numbers in both M and D.
my10ae
12-11-2005, 09:21 AM
This is too weird. When in full manual mode, I get the numbers for what gear I'm in. When in full auto mode I just get the letter "D". I wonder what the difference or similarity is between all the models? Some folks with '04's do get the numbers in full auto mode while some other's don't. And to throw another monkey in the wrench, some '05 folks have the same thing.
Weird!
dova
12-11-2005, 08:55 PM
bought it in 9/11/2003 and only shows the numbers when manual mode... i wonder if is there an flash that we can get.... whats the lates flash out there... last one i got is m
MidLife8
01-30-2006, 05:21 PM
Mine is an '04 auto (Sept 2003) and it shows only the letter D in automatic and M with gear number in M mode. Go figya'
N rider89
01-30-2006, 06:50 PM
mines a 05 and im getting numbers in both
zoom44
01-31-2006, 12:40 PM
bought it in 9/11/2003 .... whats the lates flash out there... last one i got is m
did you have the thermal damage recall work done? if so then you are on the newest flash which is S for the Automatics.
if not-go get your recall done.
