Rear screen demister problem
Old Nov 18, 2005 | 08:29 AM
chig's Avatar
Has anyone else had a problem with demisting the rear screen? There are areas of the rear screen that do not demist but appear to have screen heater 'wires'. I am aware that the radio antenna is also part of the rear screen. Have I mistaken the antenna wires for the heater wires? It seems strange to me that the whole screen can't be cleared of mist.
Old Nov 18, 2005 | 08:31 AM
LiveToRev's Avatar
Bah! Who needs a redline?
It is the same for my car.
Old Nov 18, 2005 | 09:05 AM
Sephiroth's Avatar
lurking
Same thing occurs in some of my other cars.
Old Nov 18, 2005 | 09:25 AM
ZoomZoomH's Avatar
Mulligan User
is it like the bottom 2 'wires' don't seem to do any defogging? because i see the same thing in mine
maybe this is normal then?
Old Nov 18, 2005 | 09:34 AM
RX-8 friend's Avatar
The antenna built into the rear hatch glass is more complex than you may think. There is also a ground that surrounds the heater wires (to keep noise out of the antenna). There is an additional wire that isn't connected to anything. I think that is a capacitive "choke".
Anyway, same thing applied to the previous 3rd gen RX-7. It seems to be ubiquitous technology used in many vehicles.
Old Nov 18, 2005 | 11:39 AM
dzm's Avatar
dzm
Mine does something similar. Of late, and possibly more worrying, is a general demisting problem throughout the car. There are no open liquid containers anywhere in the car or boot (trunk). Any ideas?
dzm
Old Nov 18, 2005 | 01:31 PM
Krankor's Avatar
Klingon Grammarian
When I took my 8 in for first service, I pointed out that exact problem to them. They explained that those wires on the top and bottom that don't defog... aren't supposed to. They're the radio antenna.
Old Nov 18, 2005 | 01:33 PM
ZoomZoomH's Avatar
Mulligan User
well, at least now i know everyone's 8 does it, so mine's not broken
Old Nov 18, 2005 | 03:20 PM
beachdog's Avatar
There were some problems with the wires delaminating from the glass and there was a tsb to repair those. But you would know if the wire was broken because it wouldn't be attached to the glass.
Old Nov 18, 2005 | 04:40 PM
Mugatu's Avatar
Even My Dog Searches
i had no idea what the heck a 'demister' was until i read this thread.
Old Nov 18, 2005 | 06:59 PM
NomisR's Avatar
Well i'm glad i'm not the only one with this problem, and I thought the window tinters did it.
Old Nov 18, 2005 | 08:41 PM
ZoomZoomH's Avatar
Mulligan User
i don't think it's a 'problem' if it's designed that way
consider it a 'special feature'
Old Nov 18, 2005 | 11:53 PM
YT1300's Avatar
Turning and burning
Demisting? Isn't it called a 'defogger' or a 'defroster'?
Cabin fog is a huge problem when it's cold outside and you start breathing inside as well. Two solutions: 1) warm up the interior with dry air; 2) stop breathing.
Or you can fire up the rear defroster.
Old Nov 19, 2005 | 12:07 AM
Frostee's Avatar
I am Goober Wafflelips
giving the AC a quick run works REALLY well usually too
Old Nov 19, 2005 | 03:05 AM
YT1300's Avatar
Turning and burning
The AC normally kicks on when you've selected the front defroster; it's actually a bit of a misnomer in the winter, since it's using the condenser coil to dry out the air.
Old Nov 29, 2005 | 10:27 AM
chig's Avatar
Thanks for the replies everyone. You've put my mind at rest. I checked the 'problem' out with the dealer and they said the same thing too.
Old Nov 30, 2005 | 03:39 PM
If you have moisture buildup problems there are two very effective things you can do.
1. Make sure the system isn't on recirc.
2. Use the front defrost function as indicated above - it uses the A/C condenser to dry out the air.
If you still have problems, check the passenger floor area for moisture. Sometimes the A/C drain hose can become detatched and dribble onto the passenger floor.
Be aware that if you have more than one passenger, misting problems can be common in winter. You need to use the front defrost function and fairly high fan speed.
Old Dec 1, 2005 | 07:20 AM
New Yorker's Avatar
I think I know what you're trying to say - that everyone normally equates AC just with cooling the interior. But since it is called an "air conditioner", it's not really a misnomer.
xAgyex
Jun 3, 2026 03:47 PM
drebbrnator
Dec 27, 2018 07:02 PM
BigMikeATL
May 26, 2016 12:31 AM
WingleBeast
22
May 23, 2016 09:22 PM
FirstTimeRX8Girl
Aug 21, 2015 06:51 PM
