Oil Filter Relocation Kit with Oil Cooler
Old Nov 12, 2005 | 03:24 PM
Asheboro8's Avatar
I found this kit it is 299.00.... Do you guys think it would be worth it? Or should i find other parts and make my own kit?
Attached Thumbnails Oil Filter Relocation Kit with Oil Cooler-relocation.jpg
Old Nov 12, 2005 | 05:51 PM
Moostafa29's Avatar
Storm Trooper
Can you not reach the one you have stock, or just want added convenience?
Old Nov 12, 2005 | 06:26 PM
Asheboro8's Avatar
Mainly for the oil Cooler but I think I would like it better relocated.... since I have my turbo
Old Nov 12, 2005 | 07:05 PM
Moostafa29's Avatar
Storm Trooper
I think Maddog has a 3rd oil cooler. I'm wondering where you would mount it though. With the intercooler in the middle, and one oil cooler on each side of that, I guess I dont' see where you would put it.
Old Nov 12, 2005 | 09:37 PM
Richard Paul's Avatar
Old Nov 12, 2005 | 10:33 PM
Jaguar's Avatar
Mazdaspeed has a oil cooler kit out. It's on RX8Garage.net. Not sure where it's located or any other info.
Old Nov 12, 2005 | 11:13 PM
hondasr4kids's Avatar
Why would you need a 3rd oil cooler for? The one that Mazda Speed sells is an upgrade.
Old Nov 13, 2005 | 12:27 AM
Moostafa29's Avatar
Storm Trooper
Cooler oil temps for the turbo.
Old Nov 13, 2005 | 02:34 AM
adrian-1's Avatar
Ex- member.
I believe the mazdaspeed oil cooler is meant for an upgrade for the automatics, since they only have one. Looks like it goes on the side.
Old Nov 14, 2005 | 01:51 AM
MadDog's Avatar
Consiglieri
Mine is 28"x3"x3". It sits just behind and below the intercooler.
Old Nov 14, 2005 | 07:58 AM
zaku's Avatar
車の性能の違いが戦力の決定的差ではない ということを
But according to the mazdaspeed official website's description, this oil cooler is for MT only
Old Nov 14, 2005 | 10:37 AM
KYLiquid's Avatar
Oil Injection
The kit you will see for sale as the 'Mazdaspeed Oil Cooler Kit' is pointless on a US/North American RX8 MT, we already have it, the car in other parts of the world comes with only 1 oil cooler, the Mazdaspeed RX8 comes with 2, the Mazdspeed Upgrade Kit is so that people with a Non-Mazdaspeed RX8 can upgrade the system for track use, or just added protection. The Mazdaspeed Upgrade Kit is just a 2nd oil cooler, its not any thicker, doesnt hold more volume, its just a 2nd one, setup to mount on the other side of the car...
As far as the kit you posed, I paid 260 shiped a while ago for that (over a year ago) and used it on my miata, It was a pretty good kit, and made a good 20* dent in my oil temps on track days. While it could fit the RX8, I dont see the need, unless you run the car in a really hot area or you have added FI or something) Also the core on that kit is kinda small, it was pretty good for the 1.8L in the miata, but the RX8 motor makes a lot more BTU's of heat, and I would go with a bigger core.
You should be able to buy an adapter plate for the oil filter location and add a 3rd oil cooler or relocate the filter, using oil lines and a core you source from elsewhere....it would cost about the same or less.
If your turbo, and your running the stock nose, its already pretty taxed. Radiator, AC, Intercooler, and 2 oil coolers.
Old Nov 14, 2005 | 11:18 AM
ky,
where did you get the kit????
Old Apr 4, 2006 | 08:23 PM
Nemesis8's Avatar
Bigus Rotus
Originally Posted by Richard Paul
Something tells me you missed this one...
Old Apr 4, 2006 | 08:25 PM
rotarygod's Avatar
Double the size of that cooler and then use 2 of them. Then you'll have enough oil cooler.
Old Apr 4, 2006 | 08:35 PM
wow,
such abuse, i love it. if i can find the site i think options were there for different sized coolers. if not so shoot me. i think i am going to stay out of the compotion section...
i think just adding more oil would help some. then again i am fighting sudden power loss syndrome now. got bigger issues.
Old Apr 4, 2006 | 08:56 PM
rotarygod's Avatar
Since the rotary dissipates nearly as much heat through the oil system as the coolant system, it never hurts to have more oil cooling ability.
Old Apr 4, 2006 | 10:09 PM
takahashi's Avatar
agree to everything you said.
I REALLY think my MazdaSpeed oil cooler is the same as the Mazda oil cooler on the RHS. - so no need to change~!
How much is the R hand side spare part oil cooler in the US, I wonder??? I may be cheaper.
No need for 3rd oil cooler even for turbo in endurance race. I think the oil temp is ok enough, if more is need, as RG said - get a bigger oil cooler. Stock (MazdaSpeed is 13 lines). HKS is 15 lines.
mr. GrandGame
Sep 9, 2025 10:41 PM
05TR1CH
Apr 18, 2023 04:56 AM
drebbrnator
Dec 27, 2018 07:02 PM
Junirol
Sep 22, 2015 06:02 AM
eazzyg
Aug 12, 2015 09:09 PM
