A-RF TREC(Throttle Electronic Control) installed
Old Nov 12, 2005 | 06:42 AM
zaku's Avatar
車の性能の違いが戦力の決定的差ではない ということを
It comes with a tiny red box and code to connect the factory ECU. A normal/action switch is option.
Because ECU cover can't be mounted if you intall it as A-RF suggest, I relocated it below the steering wheel. the switch was relocated above the fuse box. There are 4 buttons space.My Type E came with one functional boton(panel light adjust)only,then there came, a rear foglight/DSC button. Now the TREC button was added.
There are 6 jummper on the box. jumpper 1-3 was used for selection of TREC control rate( small, mid,large), jumper 4-5 was the selection of control range (4: 70%, 5, 90%). junmmper 6 confused me a little. As A-RF instruciton, I should set it disable but I found it would disturb the DSC. I set it in"enable" then all abnormal light singal was gone.
A "ST screw" was used to adjust the sensitivity. You should turn off the engine
(but remain power on) to set it. The instruction said you should let the green light off during the throttle is closed and linght on at the throttle level you wish. The green light should turn off during full throttle.
My initial setting was set on 2,4. The throttle resposne was really improved on low rpm range as A-RF declare.
The total work hour is about 3hrs under my friend's help. I will try to put come photos on latter.
Old Nov 12, 2005 | 04:34 PM
Moonrover333's Avatar
My Goodness My Guinness
soooo what is the point to this thing?
Old Nov 12, 2005 | 08:23 PM
Xyntax's Avatar
THREAD KILLER
what does this do?
Old Nov 12, 2005 | 10:38 PM
RX8SaxMan's Avatar
Just a guess, but it sounds like a throttle sensitivity controller that probably gives a placebo effect that your throttle response is quicker
gwailo
May 14, 2024 06:57 AM
drebbrnator
Dec 27, 2018 07:02 PM
rotorocks
47
May 11, 2016 03:23 PM
MANIACman
Nov 11, 2015 10:58 PM
04MazdaMan
Jul 15, 2015 08:23 PM
