Jusr did a oil change, but how many quarts do i need.
Old Nov 11, 2005 | 11:41 PM
EdvinRX8's Avatar
Ok, i read the manual it says, 3.7QT with filter, and thats what i pore in, but every time i check the dip stick it shows that iam low on Oil. So what gives, dont wana drive until i get this answeard dont wana ruin my new 05 RX8, its a 6speed if that matters. Any help is good thanks.
Old Nov 12, 2005 | 12:00 AM
StealthTL's Avatar
Metatron
Post Quarts....
I usually jack up the drivers side, to get a little more out, then it takes about five quarts, (we use litres, and five is too many!)
S
Old Nov 12, 2005 | 12:39 AM
army_rx8's Avatar
X-Sapper
i do mine on a lift......adn afer it drains all teh way (jo more drips)...i put her down and she takes just under 4 quarts (about 3.8 or so).....that's an oil change and filter change.
Old Nov 12, 2005 | 01:06 AM
BoosTED's Avatar
Do you jack up one side of the car EdvinRX8? You may be getting extra oil out of the oil cooler lines. The oil pan holds 3.8 quarts but the oil system holds more.
The 6 speed RX-8 has an extra oil cooler than the automatic does. More lines = more volume of oil it will hold.
Old Nov 12, 2005 | 01:08 AM
army_rx8's Avatar
X-Sapper
i believe the 6sp holds liek 7.8 quarts in all..but only 3.8 drains out the rest are tin the lines and oil coolers
Old Nov 12, 2005 | 01:11 AM
BoosTED's Avatar
So it is good to change the oil every 3,000 miles since a person can't get all the oil out.
I've heard funny stories about people draining the oil cooler lines to switch to synthetic and not attaching them fully. It makes a huge mess.
Old Nov 12, 2005 | 05:02 AM
Go48's Avatar
The 3.7 qts is an approximation. The amount you need to refill the pan can vary depending on how you drained it. Put in 3 qts and then add a bit, checking the dipstick each time until the oil level reaches the top mark.
Old Nov 12, 2005 | 09:02 AM
EdvinRX8's Avatar
Yeah i jacked it up on one side higher, my left i think and then all of a sudden more came out. So far i have put in 4qt. Iam gona add some more just keep checking my dip stick. Thanks alot guys. And sorry for the slopy typeing i was so tired from work last night. Again I'am sorry and thanks alot.
Skyl3r
Dec 2, 2019 04:51 PM
Silver_Excalibur
23
Jun 6, 2019 07:23 PM
talonhart2
Aug 26, 2015 04:14 PM
RotaryRider
Jul 20, 2015 07:05 AM
