How long to install a flywheel and clutch pack
Old Nov 9, 2005 | 06:47 PM
sunilseru's Avatar
Guys, I am budgeting for a lightweight flywheel and a new clutch. Any ideas as to how many man hours it would take for a pro to install both?
Thanks in advance.
Old Nov 9, 2005 | 07:14 PM
Im_DANomite's Avatar
I love GOOOLD
it takes me about 2.5 hours to swap trannies in an X5 4.4L and close to 2 hrs. to do a clutch on an E36 M3. so i'm gonna say around 1.5 hours for our RX8.
Old Nov 9, 2005 | 07:45 PM
staticlag's Avatar
The Professor
I got quoted $250, but I think I'm going to attempt myself.
Old Nov 9, 2005 | 09:11 PM
two rotors's Avatar
I would like to be there using my stopwatch.No chance!
Old Nov 9, 2005 | 09:49 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
A pro on a lift with a mazda manual and powertools: 3 hours
Me on jackstands with handtools:10 hours first time (over several days); 5 hours second time (minus removing the flywheel)
Old Nov 9, 2005 | 09:58 PM
I love GOOOLD
a pro shouldn't require a manual to remove a transmission. 3 hours sounds pretty long just for a RWD transmission. transaxles are a totally different story, you might as well just pull the entire motor out. $250 doesn't really sound too bad for a clutch/flywheel job. my dealership charges way way more than that @ a shop labor rate of $100/hr.
5 hours with no power tools and on jack stands is pretty freakin' impressive.
Old Nov 9, 2005 | 10:03 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
I was kinda thinking of a non-mazda grease-monkey like my brother-in-law that would need a manual, possibly (for torque numbers and bolt locations and such.
And the 5 hours was not changing the fly, just the disk and pressure plate. The Flywheel adds and hour just for jacking the car up higher on concrete blocks and jackstands (so that I could get leverage on the breaker bar with the 54 mm nut)
Old Nov 9, 2005 | 10:06 PM
army_rx8's Avatar
X-Sapper
would only need the manuel for tq numbers. everything else is self-explanitory....if he has exsperience
carbonRX8's Avatar
U-Stink-But-I-♥-U
Originally Posted by army_rx8
wold only need the manuel for tq numbers. everythign else is self-explanitory....if he has exsperience
Then I stand corrected
Old Nov 9, 2005 | 10:07 PM
army_rx8's Avatar
X-Sapper
also 3 hours isn't a bad time...if you are rushing you can do it in 1.5 but i liek to take my time when i do work.....so abotu 3 i'd say for the average grease monkey
Old Nov 9, 2005 | 10:13 PM
I love GOOOLD
oh...you didn't mention torque-ing everything. i only torque down the important stuff like the pressure plate and flywheel. everything else is around two ba-dats.
Old Nov 9, 2005 | 10:16 PM
army_rx8's Avatar
X-Sapper
^hahahha
Old Nov 9, 2005 | 10:18 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
shame. Do you check your shaft-dif bolts after a week or so? PPF bolts are like 119,; they deserve some accurate cranking.
Old Nov 9, 2005 | 10:28 PM
I love GOOOLD
no...honestly tho, how many technicians out there torque every single bolt to the specified rating?? it's good practice to torque everything, but c'mon, i need food in my mouth and bills to pay. it would be different if i got paid salary instead of flat rate.
Old Nov 9, 2005 | 10:36 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
You a tech? Then blast away with that power tool and forget it. Flat rate sux.
Old Nov 9, 2005 | 10:45 PM
I love GOOOLD
yeah, i'm a tech. flat rate can be good when it's good. but since the holiday season is coming up and the weather is getting colder, business will be getting much slower. i enjoy using my ingersol rand titanium 3/8" and 1/2" impact guns to their full extent. well, maybe not their full extent, the 1/2" gun has a rating of a 1000 ft/lbs. that annoying crank pulley bolt giving you a hard time? my gun will take care of that...
speaking of torque-ing. i need a new torque wrench....but they're so expensive.
Old Nov 9, 2005 | 11:20 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
Husky's are cheap. They are basically stanleys. Pick them up at Home depot. 60 bucks for a 1/2 inch maybe.
Do you work in Laurel?
Old Nov 10, 2005 | 01:33 AM
staticlag's Avatar
The Professor
Huskys are pretty good, I have a bunch of their sockets and they have always worked well for me.
Old Nov 10, 2005 | 11:04 AM
I love GOOOLD
i work in annapolis. only tools i buy are matco and snap-on.
Old Nov 10, 2005 | 11:12 AM
carbonRX8's Avatar
U-Stink-But-I-♥-U
Ahhh. Tool Snob.
drebbrnator
Dec 27, 2018 07:02 PM
uZu
Dec 30, 2015 12:35 PM
MrORAN6E
Jul 24, 2015 09:32 AM
AussieGray
Jul 16, 2015 03:58 AM
