GReddy Turbo Problem
Old Nov 7, 2005 | 09:57 PM
Moostafa29's Avatar
Storm Trooper
Unhappy GReddy Turbo Problem
As some of you may have heard, I'm having problems with my turbo install. There are two main problems: 1) When car is about to hit boost, or reach zero on the boost gauge, the car will stutter and stall out, and 2) There is oil leaking around the turbo (not from the return or supply lines). I was hoping to start this thread, and ask for some ideas as to what my two problems could possibly be, and if one could possibly be related to the other.
Just to give some more background, when I first installed it, I noticed that there was an oil leak from both the return and supply lines, then I thought to myself, "duh, I forgot to put the teflon tape on!". So after I did that, and finally got everything back on and together, I cranked her up, and there was a steady stream of oil dripping out. Could something have possibly come loose within the turbo?
Any help, or ideas you all could provide, I'd much appreciate. Thanks!
Old Nov 7, 2005 | 10:07 PM
Sapphonica's Avatar
PingMobile
My stutter & stall problem was due to funky vacuum hose routing.
The 'R' flash doesn't help either.
As far as the oil leak goes, I would suggest taking off the lines & reinstalling them with some kind of sealant.
Old Nov 8, 2005 | 10:19 AM
Moostafa29's Avatar
Storm Trooper
Ok, I think I may have figured out one of the problems. I was reading through some notes I had taken, and I think Adrian(?) had mentioned that you are supposed to take the plastic plug off the boost control solenoid labeled "NC". I'm pretty sure I did not do that, so maybe thats why I can't boost. As far as the oil leak, I'll have to tripple check everything. Any more ideas?
Old Nov 8, 2005 | 10:37 AM
rkostolni's Avatar
I would recommend disconnecting the boost controller all together until you get the turbo itself running right. Once you are confident everything is okay, then put the boost controller in.
Old Nov 8, 2005 | 10:42 AM
Moostafa29's Avatar
Storm Trooper
Yeah, I was thinking I should do that as well. At least that would help eliminate some of the possibilities.
Old Nov 8, 2005 | 10:45 AM
adrian-1's Avatar
Ex- member.
Yeah, if taking that plug out doesn't fix your boost problem, take out the boost controller for now.
Also, you said both the return and supply connections are leaking? It sounds like you may have overtightened it and cracked the housing (since you said steady stream) . You'll have to get a good look at the ends it's leaking at to be sure, that means draining the oil and possibly taking the turbo out.
Old Nov 8, 2005 | 11:28 AM
rkostolni's Avatar
How many times did you go around the ends with the teflon tape?
Old Nov 8, 2005 | 11:38 AM
Moostafa29's Avatar
Storm Trooper
2-3 times (?). Should I maybe do more than that? It didn't seem like it was coming from that area, but I'm going to have another look tonight.
Old Nov 8, 2005 | 05:42 PM
rkostolni's Avatar
I would do at least 3 times. I think I went around 4.
Old Nov 8, 2005 | 10:13 PM
Moostafa29's Avatar
Storm Trooper
Well I checked all the vacuum hoses, and they seemed to be ok. Then I tried disconnecting the extra plastic tab on the boost control solenoid, but had the same problem when it would try to boost. Tried routing a hose just from the nipple to the actuator...same problem. So I'm really not sure what to do with that. Could something be wrong with the actuator? Like it is not opening up the turbo to create boost?
For the oil leak, I'll try disconnecting the supply line again, and reapply the teflon tape, and make sure to wrap it 4 times or so. If it still leaks, then I just gotta say the turbo is f*cked.
Old Nov 9, 2005 | 01:51 PM
MadDog's Avatar
Consiglieri
The actuator opens to limit boost. If it didn't have a signal line connected, you would overboost.
Do you have a leaking BOV? Also, do you have an AFR gage? You are running the Interceptor, right?
with regards to the oil lieak: The first place I would look is that damn drain pipe. Its so hard to get that thing tight
MD
Old Nov 9, 2005 | 10:56 PM
Moostafa29's Avatar
Storm Trooper
MD
I'm not sure about teh BOV, but would that completely stop the turbo? Also, I don't have a AFR gauge, but yes I have the interceptor. Scott was trying to help me over the phone, and as far as he could tell, everything was running correctly.
I know there is nut and bolt on the left side of the turbo, on the same side as the engine. If that nut somehow came loose, what effect would that have on the turbo. I have no clue, but at this point I'm throwing out any kind of ideas I can think of.
Old Nov 10, 2005 | 08:48 AM
MadDog's Avatar
Consiglieri
If your BOV was leaking under boost, you could be running VERY rich - causing misfires and hesitation. This would depend on where the pressure gage is relative to the BOV - before or after.
Are you talking about the nut and bolt holding the housing clamp together? I guess that would cause a leak if the clamp were loose. Did you check the drain pipe and gasket?
Old Nov 10, 2005 | 09:02 AM
Moostafa29's Avatar
Storm Trooper
I don't think it is leaking, but of course I could be wrong. The problem is, it won't even go into boost, so it would be hard to determine.
Yeah, thats the one I am talking about. I can't tell if it is tight or not, but I am going to try tightening it later on and will report back. Is the drain pipe the same as the downpipe? Sorry, I'm still learning terminology.
Old Nov 10, 2005 | 09:12 AM
adrian-1's Avatar
Ex- member.
Downpipe
Oil drain (return line)
Is the shiny line connected to the black hose going into the oil pan. There should be a gasket between the turbo and this drain line.
Old Nov 10, 2005 | 09:27 AM
Moostafa29's Avatar
Storm Trooper
Originally Posted by adrian-1
Downpipe
Perhaps that is one of my problems. I never had a gasket. Both me and my father were saying how we thought that was odd. Is that a standard thing that I can go pick up, or do I have to order that from GReddy?
Old Nov 10, 2005 | 09:44 AM
adrian-1's Avatar
Ex- member.
That is definitely a problem. Metal to metal without that gasket will leak.
The gasket part number on the parts list is 48 and is blue. Call up greddy, I doubt you'll find it in a hardware store.
Old Nov 10, 2005 | 09:59 AM
Moostafa29's Avatar
Storm Trooper
Thanks Adrian. I thought that was weird. Just to make sure, thats where the oval shape piece with the two bolts, meets the turbo correct?
Old Nov 10, 2005 | 10:19 AM
adrian-1's Avatar
Ex- member.
Yes, it's in step 3-3-2 where it says to install it.
My kit was missing 3 nuts for the turbo and I got them at home depot. Another member was missing one of the intercooler pipes.
Old Nov 10, 2005 | 10:20 AM
MadDog's Avatar
Consiglieri
Hell yeah! I think we found your leak!!
You can order one, or you can get some gasket material from a parts store. There are at least two options: 1) gasket-in-a-tube: like caulk that forms a gasket. 2) they sell a sheet of gasket material that you cut yourself. This is what I did.
Old Nov 10, 2005 | 10:38 AM
adrian-1's Avatar
Ex- member.
Now we just need to get the boost issue fixed.
Old Nov 10, 2005 | 10:55 AM
Moostafa29's Avatar
Storm Trooper
I would like to try the caulk, but I wonder how that would work with the high temps of the turbo. I'll call GReddy to see how much the actual part is, and depending on the price I'll get it. If not then I'll either search for some high temp option 1, or just do option 2.
You got that right! I'm hoping that the problem is the nut on the side is loose, and causes the turbo to not spool up. I'll check it out later.
Old Nov 10, 2005 | 12:01 PM
MadDog's Avatar
Consiglieri
on to the boost issue then. Since you didn't recieve one gasket, how abou these: there is also a gasket that should go between the turbo housing and the intake and return pipes. If those aren't installed, you could be loosing pressure there.
Old Nov 10, 2005 | 12:21 PM
Moostafa29's Avatar
Storm Trooper
Those I do have. The gaskets that I can recall having are those two, one for the air pump hose that goes to the downpipe adapter, and one on the turbo that sits between the turbo and downpipe adapter.
Old Nov 10, 2005 | 01:04 PM
MadDog's Avatar
Consiglieri
Do you have a CanScan? We need to find out if you are rich or lean going into boost.
