First Oil/Filter Change - When?
Old Nov 5, 2005 | 01:14 PM
RotoRocket's Avatar
Freely Radical
I've searched, and yet again found differing opion on this issue.
I'm at 1,300 miles now.
I've changed the oil and oil filter @ 1,000 miles on past vehicles for the 1st oil/filter change, but I'm not sure if this necessary today, or even prudent.
It is my understanding that the factory fill of oil (break-in oil, if you will) has a high concentration of moly, and that it might be advisable to do the 1st oil/filter change at 2k or 3k, instead.
So, what does everyone here think?
P.S. - I've already added 3/4 of a quart of Castrol GTX 5W-20 (non-synthetic).
Old Nov 5, 2005 | 04:37 PM
Old Rotor's Avatar
I never add oil. There is 1.8qts of oil between the marks on dip stick. The car is oil injected according to how hard you drive it. You will normally get 2-4k in that 1.8qts. I just change the oil and filter between 2-4k. This is my 7th rotary and what I have always done. Rotary engines run hot and that breaks down the oil faster.
Old Nov 6, 2005 | 08:35 AM
rxeightr's Avatar
M0D Squad -charter member
Mine gets changed every 2,500 miles, regardless.
For the very 1st one, I'd change it after you've clocked 500-1,000 miles.
Old Nov 6, 2005 | 09:21 AM
NoTears316's Avatar
Shock and Awe
I change my oil and filter every 3k miles. I usually have to add .5 to 1 quart of oil every 1.5k - 2k miles.
airlive
Jun 28, 2020 07:46 AM
mdl0209
May 23, 2019 05:46 PM
Danield97
Sep 30, 2015 05:59 PM
XianUnix
Sep 29, 2015 03:48 PM
