Anyone with regrets after greddy turbo?
Old Oct 31, 2005 | 10:11 AM
DARKMAZ8's Avatar
"Call me Darkman"
I am seriously thinking of jumping on the bandwagon!
1)Is the power enough or do you want/wish you had more?
2)Other then engine management is there any other problems with the kit?
3)Has anyone used an rp supercat successfully with this kit?(without backfiring like crazy)
Old Oct 31, 2005 | 12:02 PM
Moostafa29's Avatar
Storm Trooper
I regret installing it myself, does that count? I'm sure it will be worth it in the end though.
Old Oct 31, 2005 | 12:38 PM
Fanman's Avatar
Good question. I still have some hesitations on this kit to this day. I LOVE the extra power, and the fact that I get more power from the bottom & midrange. But the Emanage had me pulling out my hair at times. I have pulled it out for something far superior right now. Car sometimes does overhet when you stand on the turbo for excessive amounts of time. 2 things I would change about this kit. Engine management & oil lines. The oil lines were leaking all over the place. Had to swap them out a bit.
I currently am running the RP Supercat on my car. With the hi-flow cat & original engine management the backfires were random & more than annoying, but now with the new engine management I no longer have that issue.
If you are going to drop big $$$ on a turbo kit I would suggest you wait for the PTP unit to come out. If you are on a budget, or want to build progressively than the Greddy kit makes sense. Just make sure that you have somebody that is very good at tuning & turbo installation.
Old Oct 31, 2005 | 03:15 PM
rkostolni's Avatar
What do you mean when you say the car overheats when under boost for excessive amounts of time. Could you elaborate on that.
Old Oct 31, 2005 | 03:49 PM
adrian-1's Avatar
Ex- member.
1) In stock form, the power is not enough. You'll need a boost controller and a better EMS and then some dynotuning. Even then, the turbo is too small to create over 300whp.
2) The engine management is a BIG problem in terms of driveability. Theres too many dongles involved in tricking the stock ECU. backfiring, stuttering, airpump on after shutoff.
3) My rp supercat has STOPPED backfiring since I installed the new Interceptor EMS. And yes, it was very annoying backfiring even at cruising speeds.
The PTP kit does look to be very impressive but if you get their HKS FCON, you'll have to get it tuned by an authorized tuner which could be far from your area.
Since I'm local, I may switch to this kit in the future, depending on price.
Old Oct 31, 2005 | 04:14 PM
Fanman's Avatar
At normal freeway driving my exhaust gas temperatures run about 1000-1100 degrees farenheit. When you stand on it (boost) for a bit the EGT's go up to about 1300-1400 degrees farenheit, the CEL lights starts flashing & you have to back off a bit. Fine in everyday city driving though.
Old Oct 31, 2005 | 04:43 PM
rkostolni's Avatar
Wow, I haven't had the luxury of having that happen yet. About how long do you need to be under boost before you see your CEL start to flash?
Old Oct 31, 2005 | 06:37 PM
RX8FOREAL's Avatar
Captain Spaulding
I agree with Fanman that the extra power at low and midrange is great compared to stock. My main issue is the same as most - the Emanage and the fact that Mazda continues to reflash the computer. My car ran great after the M flash - I would have told Mazda not to flash me anymore, which is OK per the service manager at my local Mazda dealer. I know I need a more comprehensive piggy back but I also do not know of any qualified tuners in my area regardless of which one I get. I have found that for simply adding boost, the manual boost controller is OK as long as there was a way to tune further. Although I have defended Greedy for customer service- at least in my case ( I have had a good raport with Benny, who has sent me his first attempt at correcting R flash changes by modifying one of my 2 adapters- this fix needs additional work) I am still not happy with the overall perfomance.
Old Nov 2, 2005 | 12:06 AM
rudy8's Avatar
^ditto mostly.
sold mine. driveability questionable. wait
Old Nov 2, 2005 | 02:36 AM
JeRKy 8 Owner's Avatar
Stuck in a love triangle
We sure do love our guinea pigs though.
Old Nov 2, 2005 | 06:08 AM
rudy8's Avatar
can you put some more pellets in our bowl, please?
Old Nov 2, 2005 | 06:16 AM
smrx8's Avatar
Old Nov 4, 2005 | 12:50 AM
cretinx's Avatar
ok so the R flash messes the car up ?
my car has been totally screwed up since I got it back from the dealer for the last two recalls
more details here
https://www.rx8club.com/series-i-major-horsepower-upgrades-93/few-fun-problems-75873/
is there a way to get my M flash back?
Old Nov 4, 2005 | 08:52 AM
RX8FOREAL's Avatar
Captain Spaulding
Unfortunately I just got off the phone with the RX8 Mazda tech at the local dealership and he told me that there is no going back. I told him how bad the car drove after the R flash and totally unrelated to the turbo. He told me the R flash was to correct the amount of oil flow to the rotors for specifically automatics, but the change was made for 6 speeds as well. He was going to talk to the Mazda tech line and told me to call him back later
Old Nov 4, 2005 | 12:26 PM
cretinx's Avatar
yeah I talked to mine, he said basically I should replace the o2 sensor and get the car retuned, maybe load a new map from GReddy.
le tme know if he can put you back to the M flash.
Old Nov 5, 2005 | 11:57 PM
Aseras's Avatar
they can flash you back but they gotta dump their WDS and reload it from scratch up to the M flash or before the update with the R flash or whatever. I doubt they will do it just for you.
( once the WDS is updated it only has the newest updates.. it's also the reason that the dealers are often behind on flashes, they never update the WDS, or only do it when they have too... )
Old Nov 6, 2005 | 12:07 AM
Spyder_doo's Avatar
Turbo'd 5
The 'R' flash had a part in messing up my oil seals in the front plate of the engine causing me to get a new engine. I'm just wondering why the seals went soon after the 'R' flash was done. With the 'M' Flash it ran great though.
Old Nov 6, 2005 | 12:11 AM
IZoomZoomI's Avatar
Boost needed
sound like a lot of headaches...
Old Nov 9, 2005 | 01:50 PM
FLybOi drE's Avatar
hmm...after you guys talk like this....makes me really wanna reconsider getting that turbo...
i still have the M flash and dont plan on getting it flashed EVER...man i really want a turbo!
decisions decisions decisions...
Old Nov 9, 2005 | 02:00 PM
FLybOi drE's Avatar
hey anyone recommend using emanage ultimate with the turbo?
Old Nov 9, 2005 | 02:13 PM
MadDog's Avatar
Consiglieri
I have the M flash, and I am also one of the biggest fans on this forum of the GReddy kit. I really think staying with the M is important. I have had zero problems. My only regret: that I didn't do it sooner!
Old Nov 9, 2005 | 02:18 PM
FLybOi drE's Avatar
cool...i keep hearing that people have oil leaks and stuff...is that a common problem for everyone with the kit?
Old Nov 9, 2005 | 02:33 PM
MadDog's Avatar
Consiglieri
I didn't have a single drop.
Also, I think you are supposed to go around only once with teflon tape.... more than that, and you are really cramming too much material in there.
Old Nov 9, 2005 | 02:47 PM
Moostafa29's Avatar
Storm Trooper
I keep hearing diffrent opinions about that. I think I went around 2-3 times with my supply line, and still have leaks. BUT, I think the leak is coming from somewhere else, which kind of scares me. I think the turbo is great, but mine may have been damange from being shipped so many times. I will have it check out very soon though. Overall, I'd recommend it, and hopefully I'll be driving mine by my birthday (nov. 29).
Old Nov 9, 2005 | 02:53 PM
MazdaManiac's Avatar
I concurr on the "R" flash issue. Nothing but problems at the moment.
I disconnected the buss wires on my OBD port so that the dealer can't flash mine while in for other things (foggy tail light, creaky sun roof).
