Subs for the 8: What sizes fit?
Old Oct 24, 2005 | 09:43 PM
HardHitter's Avatar
So basically, I am a hardcore audio fanatic and I am going to start doing an install for my 8. The question is, would I be able to fit a 12 into the 8? I will most likely have it sealed, but if I have enough room I will build a ported box for it. I want to still have trunk space in able to hold some boxes or bags, so would a 12 be a good choice or do you guys suggest I go with a 10 or two 10's or what?
Give me some ideas, in my old car I had two 15's and then a 12W7 so I am a mix of SQL now, most likely going to go ported if I can.
www.cardomain.com/id/silverrx8 is my cardomain page, the 96 Blazer was my old car that I did all the audio too so you can check it out.
Old Oct 24, 2005 | 10:02 PM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
Most people go with one or two 10's (sealed). You're not going to have any trunk if you install a ported 12.
Old Oct 24, 2005 | 10:41 PM
Jabberwock's Avatar
I installed a ported Bass Reflex 12" sub and it fit perfectly with a lot of room.
Old Oct 24, 2005 | 10:45 PM
HardHitter's Avatar
Any pictures?
I am basically going to go with a "super-sub" being a 10" Brahma, IDMax, or XXX
I'm going to need around 1400-1500RMS to run them.
Those running "true" high powered systems, is the 8's alt strong enough to handle the current draw? Experience any dimming of the lights?
Old Oct 25, 2005 | 01:30 AM
staticlag's Avatar
The Professor
You could fit 2 12w7s in there but with the amps in there also it would be tight.
Old Oct 25, 2005 | 01:38 AM
HardHitter's Avatar
Not going to go with JL. Although they are good subs, they are over priced. The Brahma, IDMax and XXX are all in the same ballpark than the W7, and for about 1/2 the price.
Second problem with JL is their 3ohm voice coils meaning it'll be harder to find an amp to power it (other than their 500/1 or 1000/1 which is also over priced)
Old Oct 25, 2005 | 02:33 AM
Boxcar's Avatar
Round round round we go
Originally Posted by HardHitter
Any pictures?
Our alternators barely run the AC so I imagine you might have some problems trying to run an amp with that much draw.
But seriously our alternators are only rated at 100 Amperes. I'm running an Orion 1200D and 2x10w6v2 and was really considering a couple of XXX but I can already feel the car slow with what I have. No dimming but I've had a 1 Farad cap on since the begining.
Old Oct 25, 2005 | 02:39 AM
Boxcar's Avatar
I have this guys info who goes by HCCAfan if I remember correctly. He got me a brand new Orion 1200D for $300 shipped and he sells the 2500D for $500. I know they are not the best of the best but for that price they kick ***! They are both 1ohm stable which allows me to push both 10w6v2 to their max. PM if you want his info.
Old Oct 25, 2005 | 02:48 AM
oh...... forgiveness please!?!?!?!
Old Oct 25, 2005 | 02:49 AM
Boxcar's Avatar
lol
Old Oct 25, 2005 | 03:16 PM
rkostolni's Avatar
I have a 12w7 in a 1.5cuft sealed box that fits underneath the rear deck and comes up to about 1" before the well in fhe floor starts. Still leaves considerable room. There's also about 3" left on each side of the box, so you could lessen the intrusion into the remaining trunk by making the box wider.
Old Oct 26, 2005 | 02:30 AM
Ryan28A's Avatar
You saw the subs in my trunk... veilside kit with 12's in the trunk in Hayward. Not much other room, but the sub box could have been flatter, but they need to stick out about there far or the quality of sound would have been reduced.
Ryan
Old Oct 26, 2005 | 07:08 AM
staticlag's Avatar
The Professor
On an interesting note, I took a road trip to Kansas this last weekend. And I took out my sub to put in the spare tire.
Oversteer was gone.
Dangit, why can't I have good handling and good base?
Old Oct 26, 2005 | 12:07 PM
Oversteer was gone.
If you look at my car from the side it looks like I lowered the rear because of my subs. It makes me want to build a fiberglass box. Anyone want to help me?
Old Oct 26, 2005 | 12:16 PM
Ryan28A's Avatar
LOL! Instead of doing all that, I just enstalled a new suspension.
Old Oct 26, 2005 | 12:34 PM
Because I've always wanted to build a fiberglass box.
Old Oct 26, 2005 | 01:44 PM
dmp's Avatar
dmp
RX8 and a Truk....
Prolly hard to see anything - this is about how much room is taken w/ two 10" JL subs, and 3/8" thick baffle (baffle hides the box)
Old Oct 26, 2005 | 01:47 PM
Tamas's Avatar
Registered Lunatic
"hard to see" is the understatement of the day
Old Oct 26, 2005 | 05:26 PM
dmp's Avatar
dmp
RX8 and a Truk....
:D
I'll try to get better pics tonite...if I have enough lighting. :D
Old Oct 26, 2005 | 06:39 PM
fenderlover's Avatar
so which would be better 2 10's or a ported 12 or 13
Old Oct 26, 2005 | 07:22 PM
I think two 10's would be more crisp / cleaner.
Old Oct 26, 2005 | 07:55 PM
HardHitter's Avatar
depending on the subs. 2 10's will be louder if both were in sealed boxes due to cone area, however, since the 12 is ported, it will maybe get a little louder than the 10's but maybe not as good in the SQ. But again, it depends on the subs, efficiency, amp, and box.
If using only a single sub setup, comparing 10W7 vs 12W7.
12W7>10W7 both in sealed or ported box due to cone area
10W7 a little > 12W7 if 10 is ported and 12 is sealed
Basically, porting any sub is a 3db gain, doubling the power is again another 3db gain.
3db gain is accountable for 2x as loud as what it was before.
Old Oct 26, 2005 | 08:43 PM
wat about 2x 13w6v2?
or would 1 ported be better.
i don't need any trunk space
Old Oct 27, 2005 | 01:31 AM
MrWigggles's Avatar
Fender,
If you don't need any trunk space, you probably can go with two 15" drivers with 1000 watts a piece. With the right fiberglass box you will still have enough room for amps, wiring and whatever else.
I don't know how good it will sound but for some reason I don't think a lot of people car too much about sound quality in this thread.
-Mr. Wigggles
