Third port for exhaust tip on factory muffler behind rotary symbol?
Old Oct 24, 2005 | 10:00 AM
Mantis's Avatar
Have any of you seen that extra welded piece on the factory muffler in the spot where the rotary symbol is on the bumper? Seems like someone welded that piece/ cap there as an extra effort. Anyone have a take on this? Was this for a 3rd exhaust tip option that never made it to the general public? Or is it an option in Japan? Am I crazy?
Old Oct 24, 2005 | 10:09 AM
mike1324a's Avatar
Need'd a Turbo
No, it was just a custom job someone did that. it eliminates the the actual factory exhaust on the sides. its just a single pipe to the middle with a custom shape outlet.
Old Oct 24, 2005 | 10:11 AM
expo1's Avatar
He's as bad as Can
I think he / she is asking why that cap is on the stock exhaust, I do not know.
Attached Thumbnails Third port for exhaust tip on factory muffler behind rotary symbol?-dcp_2431.jpg
Old Oct 24, 2005 | 10:25 AM
truemagellen's Avatar
Attracts tree branches
my guess is it was cheaper for mazda to build a can...cut/drill a hole in it...and insert the sound deadening material connected to a metal cap...then weld the cap
than
creating the sound deadening material and then carefully finishing the can and closing it
a guess but I've done metalsmithing work before and to save time I would have done the same thing :D, especially with something that is out of site to almost everyone
Old Oct 24, 2005 | 10:41 AM
mike1324a's Avatar
Need'd a Turbo
Originally Posted by expo1
I think he is asking why that cap is on the stock exhaust, I do not know.
ohhhh ok. but does any one have a picture of that custom center exhaust?
Old Oct 24, 2005 | 10:51 AM
the custom center exhaust is a poor idea unless you really open up the area
you need air space from the bumper or it will melt very quickly
Old Oct 24, 2005 | 10:55 AM
mike1324a's Avatar
Need'd a Turbo
yeah. i dont remember who did it but they did and they said it had better flow than most.
Old Oct 24, 2005 | 11:06 AM
mike1324a's Avatar
Need'd a Turbo
By the way, that is the coolest light i have ever seen.
Old Oct 24, 2005 | 11:13 AM
expo1's Avatar
He's as bad as Can
It's about the only thing you can do with an extra OEM exhaust.
https://www.rx8club.com/rx-8-discussion-3/uses-extra-exhaust-60296/
Old Oct 24, 2005 | 02:28 PM
Mantis's Avatar
Expo, that seems like a pretty good answer.
Just seems strange that it is in that location. Looking forward to taking that out!!
BTW he is a she.
Old Oct 24, 2005 | 03:58 PM
therm8's Avatar
Bummed, but bring on OU!
I thought that was where the muffler grease went??
mike1324a's Avatar
Need'd a Turbo
ohhh sorry. we dont typically have a lot of girls here.
Old Oct 24, 2005 | 04:06 PM
expo1's Avatar
He's as bad as Can
Originally Posted by Mantis
BTW he is a she.
Based on your gender, name & Avatar should we avoid asking you out on a date?
"The female praying mantis widely known for her particular habit of biting the head off her partner while they are mating."
Old Oct 24, 2005 | 04:49 PM
Based on your gender, name & Avatar should avoid asking you out on a date?
Old Oct 25, 2005 | 06:55 AM
Mantis's Avatar
Good screen name huh. That mantis ate your baby!! :P
Old Oct 25, 2005 | 11:44 AM
zoom44's Avatar
could it be for sound tuning? i have seen extra short tube on some aftermarket exhausts for that purpose.
Old Oct 25, 2005 | 12:11 PM
StealthTL's Avatar
Metatron
Not.....
If you check the location, you will see it is the "other end" of the input tubing - probably stabs right thru the muffler like that for strength, then welded in place at BOTH ends.
The inlet has holes along it's sides for the gasses. If you removed the cap, you would have a direct "no muffler" outlet, very loud and nasty.
S
Old Oct 25, 2005 | 12:48 PM
zoom44's Avatar
aha
ableobject
Mar 22, 2016 11:37 PM
Mr.Durden
Aug 12, 2015 02:21 PM
vssystemluba
Jul 19, 2015 04:16 PM
AussieGray
Jul 16, 2015 03:58 AM
