brillo
10-24-2005, 09:58 AM
I noticed this weekend that since its cool enough in Houston now to not need the A/C running, the car doesn't have that annoying studder every few seconds where you can really feel the car shake. It seems that the A/C compressor contributes to the problem for me. I can still feel a slight more continous vibration at idle, but not the studder sensation.
Any idea how we can use this info to fix the problem while the car is running? I'm a little confused why the A/C would matter when I know the issue is the PCM trying to run the car at a ridiculously lean AFR at idle. Someone stated the the studder is the fuel injectors cutting on and off trying to fight to keep that real lean idle setting, which I believe given my megasquirt tuning experience. Does the A/C just put more strain on the engine at idle than it would when driving?
