Putting car in neutral with ebrake on before washing it warps rear brakes?
Old Oct 24, 2005 | 09:11 AM
RotoRocket's Avatar
Freely Radical
So says this thread (I think):
https://www.rx8club.com/rx-8-discussion-3/another-tip-new-rx-8-owner-75147/
That's the first time I've heard a claim that one should put car in gear, rather than in neutral with ebrake on, in order to avoid warping rear brakes.
Old Oct 24, 2005 | 09:24 AM
expo1's Avatar
He's as bad as Can
He started his post with ' I was enjoying my daily spirited drive'.
If they are HOT using the Parking Brake can warp the rotors.
Old Oct 24, 2005 | 09:27 AM
RotoRocket's Avatar
Freely Radical
So, this is relatively true (if they are hot)?
Wow. This is complete news to me.
I'm glad I asked, though.
I rarely put my car into gear when parking it, unless I'm on anything other than a totally flat surface.
Old Oct 24, 2005 | 09:33 AM
expo1's Avatar
He's as bad as Can
Unless your driving on the tail of the dragon (US129), this would only be an issue on the track.
He did not explain what he meant by ' I was enjoying my daily spirited drive '.
Old Oct 24, 2005 | 09:51 AM
KYLiquid's Avatar
Oil Injection
yeah what expo 1 said :
If you are using heavy braking, and the rotors/pads get hot, when you stop, leaving the hot pads tight against the rotors (parking break engaged) can cause a temp difference as the area the pad is contacting will stay hotter than the rest of the rotor, this can cause the rotors to warp or cause stress cracks.....really a non-issue unless you REALLY push the car. Normal braking or even 1 or 2 hard brakes wont really cause a problem.
One way to avoid it is to drive around for a few minutes with out using much braking. I always have a slow drive thru my sub-division before I park the car.
Old Oct 24, 2005 | 10:57 AM
beachdog's Avatar
By the same logic, after a spirited drive, you come to a long red light. You have to sit there with the brakes applied. Now you have all 4 pads in lengthy contact with one spot on the rotors. It's actually going to be way worse for the fronts.
There's another thread dedicated to the subject of rotor warping. It all comes down to the design and the quality of construction of the rotors. One would hope that as a high performance vehicle, the 8's rotors are designed and built to withstand all of these normal usage modes.
Old Oct 24, 2005 | 12:43 PM
Umbra's Avatar
98 Grand Voyager
I think the problem is obvious here.
Old Oct 24, 2005 | 01:37 PM
RotoRocket's Avatar
Freely Radical
So, let me be perfectly clear here:
Is everyone saying not to use the ebrake on a regular basis when parking, especially after a spirited drive?
My usual protocol is to park, put the transmission into neutral, and engage the ebrake.
I've done this with other MT cars, with no rotor warping.
I've heard too many stories of MT vehicles popping out of gear, without the ebrake engaged, and rolling into God knows what, when parked.
Old Oct 24, 2005 | 01:51 PM
expo1's Avatar
He's as bad as Can
I thought the replies were clear; it’s heavy repeated braking like you would do on a track or road like the dragon or the hills in San Francisco that heats them up to the point of possible brake warping. Hot enough so that you can smell them. Hot enough that you would burn your fingers if you touched them. What kind of street driving are you doing to get brakes this hot?
Attached Thumbnails Putting car in neutral with ebrake on before washing it warps rear brakes?-poster2005.jpg
Old Oct 24, 2005 | 02:07 PM
RotoRocket's Avatar
Freely Radical
Well, maybe you were clear.
But some of the responses at least insinuated that hard breaking cycles of just several times may heat the brake pads and/or rotors to a point where using the emergency brake may not be prudent.
And I like to be prudent.
I don't drive my car hard, so if the clear answer is to use the emergency brake without worry when parking, under those circumstances, I can live with that.
Old Oct 24, 2005 | 02:56 PM
Krankor's Avatar
Klingon Grammarian
RotoRocket, there are a lot of people here who seem to think their cars are made out of crystal. I shall continue to use the parking brake as I always have, with ne'er a problem. Nice job by expo1 and KYLiquid of explaining the issue.
Krankor
05 Shinka 6MT
Old Oct 25, 2005 | 01:08 AM
mazdabob's Avatar
You should always put the car in gear when parking. The parking brake will not always hold the car on an incline. There have been many stories of people returning to their cars, and finding that they rolled into another car, or something else. On an incline, you should set the parking brake to take pressure off the transmission.
Old Oct 25, 2005 | 08:58 AM
Aseras's Avatar
someone correct me if I'm wrong but isnt the parking brake pads seperate from the regular rear calipers. I though it was two smaller pads inside the rotors with a mechanical linkage..
on another note the only problem I have had is that sometimes after a hard drive and parking on a incline I've had my car roll.... after setting the parking brake very well. consequently i always leave it in gear now too.
Old Oct 25, 2005 | 09:13 AM
expo1's Avatar
He's as bad as Can
When you pull up on the parking brake handle you retract cable (part #1) which rotates the brake piston just enough to force the pads to hold to rear brake rotors.
Attached Thumbnails Putting car in neutral with ebrake on before washing it warps rear brakes?-pb1.jpg
Old Oct 25, 2005 | 10:49 AM
carbonRX8's Avatar
U-Stink-But-I-♥-U
I am confused here. Does spirited driving have anything to do about driving on Halloween, or is this an open container issue (say, like, driving with jim beam).
Thanks for the US129 map Expo.
Old Oct 25, 2005 | 10:52 AM
Butt Dyno's Avatar
Level 5 of The Pyramid
Re: "warped" rotors
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
Old Oct 26, 2005 | 04:28 PM
MrJynx's Avatar
damn that road looks AMAZING!!!!! to bad it's on the wrong side of the continent
MrJynx
Old Oct 26, 2005 | 04:29 PM
MrJynx's Avatar
spirited driving = driving like you stole it = driving like a maniac w/o endangering other people
Basically drive the **** out of your car redline the car, go fast around corners, fast launches..
MrJynx
Old Oct 26, 2005 | 05:06 PM
Gerael's Avatar
Rexella's Daddy
MrJynx
i wouldn't say spirited is that far.... its a level below drive it like you stole it...
and about ebrakes... they freaking suck... honestly.. i found my car rolled out just barely into the street with the ebrake on... but i musta forgot to put it in gear.. or it popped out... eitherway.. it was quite scary to see it like that...
so no more trusting ebrake for long periods of time
Old Oct 26, 2005 | 07:50 PM
yiksing's Avatar
the giant tastetickles
Let me clear up some confusion here, obviously spirited driving means different thing to different people. What I did was repeated heavy braking (trying to figure the threshold of it) in a closed abandoned road (lots of twists). I fried the brakes in my other car before (the brakes were smoking) although its not a performance car so it was just a "better safe than sorry thing".
BigMikeATL
May 26, 2016 12:31 AM
20b-3rotor
Sep 2, 2015 11:09 AM
thewatcher101
Jul 27, 2015 09:44 PM
Belalnabi
Jul 17, 2015 07:48 PM
AussieGray
Jul 16, 2015 03:58 AM
