Stock Tire Pressure
Old Oct 21, 2005 | 08:10 AM
Umbra's Avatar
Question Stock Tire Pressure
What's the stock tire pressure on the four tires for an RX8? My low tire pressure sensor was on this morning for about 3 miles before going off so I opened the door to take a look at what the tires should be set at and nothing is written on the sticker so I have no idea what to set them to.
Please help a poor little shinka owner with his tires.....
Old Oct 21, 2005 | 08:56 AM
Labop's Avatar
searching revealed:
https://www.rx8club.com/showthread.p...=tire+pressure
and many many more. Which door did you look on? Cause I have two sticker/plaques, one on the suicide door, and one on the front door. The one on the front door should have the tire pressure info. I'm assuming you meant for street driving, not competition. :D
Old Oct 22, 2005 | 10:51 AM
jaedcem's Avatar
Interestingly, the sticker on my driver's door is not filled out. There are blank spaces for the tire pressure, but they aren't filled in. (I should just write 32 psi in with a marker.) Does anyone else have a blank sticker on their car?
Old Oct 22, 2005 | 10:55 AM
V_for_velocity's Avatar
One more couldn't hurt
From: Saskatoon, SK -- go to Winnipeg then head west
Mine is blank.
Old Oct 28, 2005 | 10:41 AM
iridearocket's Avatar
increase the pressure
I run 36-38psi in the tires. It increases sidewall stiffness, response and tire longevity.
I race superbikes and the optimum psi for maximum grip is 35 when hot. This means you need to start at 30 psi when cold. Tires on cars will never get this hot during road driving, so you can put at least 35 psi in them.
Old Oct 28, 2005 | 11:04 AM
ucfracerx8's Avatar
Pistons are Over Rated
WOW, I am glad I am not the only one, my sticker is blank as well. I have been running 32psi in them as recommended all around, I check them every Sunday, same time I check the oil level. Call me ****, but I love pampering my 8.
Old Oct 28, 2005 | 11:13 AM
Gerael's Avatar
Rexella's Daddy
I believe the last time I checked.. i had one blank and one that had the numbers...
neat huh?
Paul_Y
Sep 21, 2015 02:23 PM
Octomus
Sep 3, 2015 11:40 AM
20b-3rotor
Sep 2, 2015 08:54 AM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
