Engine problems with '04 RX8
Old Oct 18, 2005 | 12:33 PM
Chris4401's Avatar
'04 RX8, 4 speed auto. Last Sunday we were driving and the engine started losing power. The transmission was shifting into 4th at 35 mph and would not downshift. I put the trans in "manual" and the car would not accelerate past 4000 rpm at which point a loud rattle / knock started coming from the motor. Keeping it below 4K eliminated the noise but we were unable to go over 60 mph. At stoplights, the motor would die. Again, no acceleration off the lights.
This persisted for 30 minutes (20 miles). We got to our destination, shut the car off for 4 hours and it ran fine all the way home.
This is the second time this has happened. Spent three days at the dealer and they changed the plugs (said we were driving too slow and it was loading up) and did several diagnostic checks / reprograms.
Anyone else had these problems??? Read on another forum of engine replacements (sometimes even that didn't fix the problem).
Its going back in tomorrow and I have told them I don't want it back until it'd fixed.
Thanks,
Chris
Old Oct 18, 2005 | 12:38 PM
zoom44's Avatar
failed cat
Old Oct 18, 2005 | 02:05 PM
Chris4401's Avatar
Help me out. What is a failed cat???
Old Oct 18, 2005 | 02:19 PM
Blue87Sport's Avatar
Rotary only since 1980
failed cat = catalytic converter. The materials in the cat break down and clog up the flow of exhaust gases. This increased back pressure prevent the engine from revving very high.
Old Oct 18, 2005 | 02:24 PM
ZoomZoomH's Avatar
Mulligan User
go to another dealer if they can't diagnose this as a failed catalytic converter in the first place...
Old Oct 18, 2005 | 02:41 PM
Invasion8's Avatar
I had almost the same problem, next time it happens go straight to the dealer and have the service manager road test it with you in it. I bet the car acts normal when it sits over night and then gets worse when it is fully warmed up?? i just had a new engine put in.
Old Oct 18, 2005 | 03:39 PM
Chris4401's Avatar
The first time it was running poorly when I took it in. They had it for three days - lots of tests and downloads. Two months later and its doing it again.
Why did you have your engine replaced and how is it running so far ??
Old Oct 18, 2005 | 03:41 PM
Chris4401's Avatar
Wouldn't this cause it to run poorly all the time ??
Thanks.
Old Oct 18, 2005 | 03:55 PM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
How many miles are on the car?
Old Oct 18, 2005 | 04:20 PM
Chris4401's Avatar
27,500 miles. All recalls completed, regular maintenance.
Old Oct 18, 2005 | 04:23 PM
zoom44's Avatar
not as the honeycomb breaks down a portion can clog the outflow but then be forced out allowing the exhaust to flow again. it can happen without triggering a cel.
Old Oct 19, 2005 | 11:35 AM
Chris4401's Avatar
Took the car in this AM. Of course it ran fine on the way in and for the dealer. Asked about compression and the catalytic converter. Said he couldn't do anything unless it ran poorly for him. After I explained how unsafe the car it when it doesn't run and that he could keep it until it did something wrong so he could fix it, he decided to call Mazda.
The plan is to take the ECM (?) module out, send it to CA for a MOP 1 Reflash (???) and that is supposed to correct the problem.
I hope so. In FL we have a Lemon Law that I will pursue if it happens again.
Anyone else heard of this (the reflash) and if so, did it help?? I'll report on the lastest "fix" when it comes back.
Thanks for all the suggestions.
Chris
Old Oct 19, 2005 | 11:57 AM
zoom44's Avatar
yes they have been sending someAT cars' pcms to MNAO in irving for a specific programming fix. apparently soemthing that cannot be doen by the tech in the feild with his equiptment.
Old Oct 19, 2005 | 06:19 PM
Rick's Avatar
Chris
The ECU in my 8 was reprogrammed but it did not fix the knocking issue. THe Mazda tech also decarbed the engine twice now. That cure only lasts for about a week. I was told that an engine replacement was the next step. I would think that checking the knock sensor would be the next step ,but I'll happily take a new engine.
Old Oct 20, 2005 | 01:26 AM
allmotorRX8's Avatar
銀い 雪
you are driving too slow, go faster
maybe then, when you do drive faster and this still happens
they'll void your warrenty cuz u were driving too fast.... dealers... :p
Old Oct 29, 2005 | 04:33 PM
Chris4401's Avatar
Got the car back on the 21st. Ran fine for about 300 miles. Yesterday (the 28th) we were driving on the interstate at abot 78 mph with the cruise control on. The car kept slowing down causing it to downshift to third to keep the speed up. When we got off the interstate it died at the end of the exit ramp. Started it up and it had no power, engine knock at 3800 rpm, the same problems as before.
Called the dealership and was told there was nothing they could do right now as they were all going home for the day. Shut the car off, waited 3-4 hours and it runs OK again.
I am at wits end with this. I have read of "replaced engines" but (of course) my dealed has not heard anything about these problems - states that mine is the first - Mazda has no reports of anything similar, etc.
Planning on going to the dealer on Monday AM to see about a replacement engine, computer, car, money back (Lemon Law) or whatever it take to get this resolved.
Any suggestions ????
Old Oct 29, 2005 | 06:07 PM
therm8's Avatar
Bummed, but bring on OU!
definately sounds like the cat. Probably a piece of the catalyst that's to large to continue down the pipe. I'm guessing it gets jammed at the end of the cat after a while, and then falls back down while the car sits for a bit. If your dealer won't do anything without the problem existing at the time of service, you may have to request them to remove the cat and look at it. But you'll probably have to pay for it if that's not the problem. I would say you could remove it and look yourself, but then, knowing dealers, they might not cover it since you removed it yourself.
Old Oct 31, 2005 | 02:05 PM
Chris4401's Avatar
Took it back in this AM. Service Manager had called Mazda prior to my arrival. He said they told him to try to replicate the problem(drive the car) and do a compression test. He went on to say that they would probably replace the engine. I asked what was going on (what did he know that he wasn't telling me) and he would not elaborate.
Sucks that there is obviously an issue here and they (Mazda and the dealer) aren't giving me any straight answers. Interesting thing is that I suggested checking the Cat and he said unless they get a code for it they won't do so.
Not real happy with the whole Mazda experience............
Old Oct 31, 2005 | 03:12 PM
czr's Avatar
czr
RX8 RX8!
This weekend also had a loss of power issue as well and car feels sluggish @ 22k miles. Gunned it and car surged - rpm went down slightly and car jerked. I have a MT though. From reading here and other threads in the past, I also suspect this is a cat problem. I will argue like hell if they say they can't replicate the problem. It is damn dangerous if you are merging into the highway and you are decelerating.
Old Oct 31, 2005 | 04:35 PM
Chris4401's Avatar
Very similar to mine except that it stays that way. The only way to "fix" the problem is to shut the car off for 2 - 3 hours. I would think they would troubleshoot all other possibilities (like the Cat) before just replacing an engine. Unless there is a known problem..............
Old Nov 1, 2005 | 10:39 AM
zoom44's Avatar
yeah this is what i dont understand- tell them to look inside the CAT. if they say no its because they dont think mazda will pay them. why not? Mazda does pay for diagnostic time. besides which YOU could pay them the hour to look if it turms out its ok. but make sur eyou get to look at it. for that matter go to a midas or somesuchand ask them to drop it and have a look and let you look.
im quite sure your state law says they have to tell you WHY they want to do any repair that they say is needed.
Old Nov 1, 2005 | 10:58 AM
Chris4401's Avatar
I think there is a lot more to the story than what I am being told. The daeler is saying nothing. On the one hand, if it fixes the problem, I'm good with it. On the other, I would sure like to know what is going on. As for the Cat issue, they won't do anything unless Mazda tells them to. I don't understand that either.
Waiting for a call from them (today?) to see what their next course of action is.
Old Nov 1, 2005 | 06:17 PM
Rick's Avatar
Originally Posted by Cool-Blue-Dad
Whoa! Whoa! Whoa! Replace the engine? Based on what theoretical failure mode? .
My 8 is getting a new engine because of knocking. I thought it was strange that they would give up so easy and replace an engine after only decarbing it twice and reprogramming the ecu to inject more oil. They did not even bother to check the compression. Hell, if I was a tech, my curiosity would make me check other components when no one was looking.
