Turbo charging rx8
Old Oct 18, 2005 | 05:09 AM
prorx8's Avatar
Turbo charging rx8
Hi all im new to this site and would like any info and/or pics of any rx8 turbo exhaust manifolds, anyone have that sort of info or know where i can get it,big demand for turbo kits in aus,yes im from aus
Old Oct 18, 2005 | 12:06 PM
mike1324a's Avatar
Need'd a Turbo
Hi and welcome. im going to save yu from the verbal abuse some people are about to dish out on you. we have a few "search *****", meaning they will just tell you to search and not help you. just a warning ya :D . i would check out any of the threads that have custom turbo installs. There is one guy(caio sp?) in aus doing a custom job. check out his thread in the aus section. I would also look at the ptp thread in the major horsepower section. actually many of the threads in that section would be helpful to you.
Here is the typical greddy kit which is the most abundant. http://www.intensepower.com/grtukitt6rxs.html
Old Oct 18, 2005 | 03:45 PM
Mugatu's Avatar
Even My Dog Searches
Old Oct 18, 2005 | 07:58 PM
mike1324a's Avatar
Need'd a Turbo
No offense to ya man :D , I just had to help out a new guy before he got flamed.
Old Oct 19, 2005 | 04:31 AM
prorx8's Avatar
Thanks mike1324a i wont try a stunt like that again not really into getting flammed thanks for the info anyway,am in the process of making kit quite confident will make 280rwhp on 8psi will post pics as they come to hand
Old Oct 19, 2005 | 08:14 PM
mike1324a's Avatar
Need'd a Turbo
sounds fantastic. we want some pics. good luck
Old Oct 20, 2005 | 04:47 AM
prorx8's Avatar
yes should be,turbo being used is GARRETT GT35 700hp roller bearing turbo with internel wastegate, ECU is MICROTECH LT10S and intercooler will be the best suited to application with stainless steel polished piping,package is will make around 400+ rwhp just depends weather rx8 engine can handle it, also changing 3rd set of injectors to 880cc to compensate for the boost and fuel pump to larger in tank pump with higher flow rate
Old Oct 20, 2005 | 11:50 AM
mike1324a's Avatar
Need'd a Turbo
Very impressive. This sounds very much like the PTP turbo kit. I would suggest reading up on that thread.
rotorocks
47
May 11, 2016 03:23 PM
Eirulisse
Aug 15, 2015 12:34 PM
shambo
Jul 18, 2015 02:07 PM
Belalnabi
Jul 17, 2015 07:48 PM
