recalls
Old Oct 17, 2005 | 09:59 AM
billypsm's Avatar
recalls
I took my 8 in for the recalls, and when I picked it up...they said it inspected fine and no work was needed. Had a hard time understanding this since they held off for a week because they were waiting on parts. I thought the ball-joint was an inspect and repair as necessary and the gas tank was a mod. Can anyone give me some insight here?
Old Oct 17, 2005 | 10:08 AM
Glyphon's Avatar
脾臓が痛みました
depending on the build date of your car, its possible that no action is needed.
Old Oct 17, 2005 | 12:33 PM
V_for_velocity's Avatar
One more couldn't hurt
From: Saskatoon, SK -- go to Winnipeg then head west
But if you got a letter from mazda about recall(s), the dealer is bullshi!!ing you.
Old Oct 17, 2005 | 01:30 PM
beachdog's Avatar
The ball joint recall was sent to all cars within the build date becuase they did not have accurate record for the specific control arm installed in each car. the visual inspection is nothing more than identifying the casting code. In rare circumstances they arms will be replaced. Majority require no work at all. You can do this one yourself.
The heat recall was sent to all group 1 cars. The various meltable items might have been fine on your car but all group 1 cars needed the insulation added above the gas tank. If they didn't add the insulation bring it back.
Go to http://www.finishlineperformance.com...ins_index.html and print out the repair procedures and go over with the dealer.
Old Oct 25, 2005 | 02:31 PM
blue flash's Avatar
took my 8 in for the noraml 3000 mile oil change since it's on them ,and while they had her they replaced the ball joint[recall] and the insulation for the gas tank[recall] .
Old Oct 25, 2005 | 05:38 PM
beachdog's Avatar
Do you have the part numbers for the control arms that were replaced? Are you sure that they just didn't inspect? Actual replacement is very very rare.
Old Oct 26, 2005 | 07:24 AM
blue flash's Avatar
i drove my truck to work today and the invoice is in my car .i will get you the part # tomorrow.they charged mazda 2.5 hrs labor on the control arm ,thats seems quite a bit for an inspection don't you think.
Old Oct 27, 2005 | 06:41 PM
SarahSHater1's Avatar
They just put a new transmission in my car and when it was there they inspected the ball joint and did the fuel tank isulation recall
Old Oct 28, 2005 | 05:41 PM
beachdog's Avatar
Interesting. None of the bad arms were supposed to have escaped Japan. What's your build date?
theblinkof
Oct 4, 2023 05:24 PM
gwilliams6
General Automotive
60
Nov 3, 2015 02:50 PM
Tweaked Tay
Sep 25, 2015 07:54 AM
