Cutting the Rear Bumper with the Hacksaw?
Old Oct 13, 2005 | 01:38 AM
slllygrl10's Avatar
EX-Member
I plan to install the ms rear today I was wondering if I should just get the hacksaw blade or hacksaw w/ frame? How do I take out the rear rotary accent?
Old Oct 14, 2005 | 01:31 PM
The words Hacksaw and RX-8 should never be in the same sentence.
Old Oct 14, 2005 | 01:42 PM
truemagellen's Avatar
Attracts tree branches
yes install for the MS rear is the most ghetto installation procedure I've ever seen from a major manufacturer
Old Oct 14, 2005 | 02:40 PM
ZoomZoomH's Avatar
Mulligan User
ghetto, but it works though :D
Old Oct 14, 2005 | 04:00 PM
Nemesis8's Avatar
Bigus Rotus
I think I'll have the shop here cut mine with the plasma torch
Muuhahahaha
Why not use a powered jigsaw or sawzall?
Old Oct 14, 2005 | 09:23 PM
SnowFl8k's Avatar
mas than meets the ojo
Just the blade won't do you any good - you'll need the frame too. Pretty easy to cut through once you have a cut started...its just starting. As far as the rotary accent - it is just held on with tape. If you can't pry it off with your fingers (which I was able to do - girl upper body strength and all..) heat it up first with a hair dryer and then start prying.
Old Oct 14, 2005 | 11:13 PM
ZoomZoomH's Avatar
Mulligan User
for those JUST joining in, she already finished the install, and she DID only use the blade... some brilliant bladework i tell ya :p
https://www.rx8club.com/rx-8-multimedia-photo-gallery-6/ms-rear-diffuser-installed-74391/
Old Oct 21, 2005 | 07:19 AM
slllygrl10's Avatar
EX-Member
How did you manage to fit the frame and cut it at the same time?
RXFEVER
Aug 29, 2018 10:14 AM
Kahl
NE For Sale/Wanted
21
Aug 5, 2017 02:49 AM
RXFEVER
Sep 11, 2016 02:51 PM
paporx8
Nov 5, 2015 07:20 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
