How much for installing Racing Beat sways?
Old Oct 10, 2005 | 01:13 AM
sunilseru's Avatar
Guys, what do you think is a reasonable price to pay for installing Racing Beat sways? I can't do it myself - live in an apartment and park on the street.
Just came back from firestone. They quoted $106.60. I think it is a bit too much. What say???
Thanks in advance.
Old Oct 10, 2005 | 06:11 AM
Go48's Avatar
Just came back from firestone. They quoted $106.60. I think it is a bit too much. What say??? Thanks in advance.
I doubt you will get it done any cheaper. Check out the rate at one of my local RX shops. Click on the link below.
http://www.performancebuyers.com/ser...umbs=0&start=1
Old Oct 10, 2005 | 06:30 AM
momo's Avatar
Registered Laker's Fan
Thanks in advance.
Is that the price for both the front and back sway bars? I think its a good deal either way. Its a beeeyioch getting the front sway bars in and you have to drill bigger holes.
Old Oct 10, 2005 | 06:54 AM
Go48's Avatar
Installation of the bars does not require drilling anything. Only if you install the optional end links do you need to drill out the holes. BTW, I didn't think installation was that difficult. Just took a little finesse when snaking the front bar into place.
Old Oct 10, 2005 | 07:21 AM
expo1's Avatar
He's as bad as Can
That is a good price for BOTH bars. Two things to keep in mind.
Make sure they install the rear bar correctly (2nd post)
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-racing-beat-sway-bar-install-43677/
See how much more they would charge you to put grease (zerk) fittings in the bushing brackets. https://www.rx8club.com/series-i-trouble-shooting-95/something-owners-aftermarket-swaybars-might-want-lookout-65304/
Old Oct 10, 2005 | 09:28 PM
sunilseru's Avatar
Thanks guys. Got it done at Midas today as it is very close to work. $60 for the front and $40 for the rear. They did it in 40 mins. Maybe two people worked on it.
Old Oct 11, 2005 | 12:57 PM
oryas's Avatar
How does it drive with the new sway bars installed ?
Old Oct 11, 2005 | 06:47 PM
sunilseru's Avatar
Didn't really get a chance to push the car, but the car seems to be having less body roll. Not much difference on bumpy surfaces in a straight line. I am hearing a squeaking sound sometimes. Most probably the guys did not grease the bushings properly. Have to check that.
20b-3rotor
Sep 2, 2015 08:54 AM
wayloco
Sep 1, 2015 09:03 PM
beastman_5
Aug 30, 2015 10:22 AM
RenzoRx-8
Aug 25, 2015 10:29 PM
