View Full Version : Slight sqeal when gas is initially applied
SilverrbRX8
10-09-2005, 11:33 AM
Does anyone know why this is happening? when i apply the gas in local slow driving i hear a slight squeal....not quite sute if its a whistle....dont think it is....seems to be like a very very faint brake squel but occurs when the gas is pressed and the car starts to move but goes away once speed increases. any ideas??? ill probably just take it to the dealer ...it has to go in anyway for somethin else.
RotaryManiac
10-09-2005, 12:18 PM
Is it a high pitched sound, because i get that too then.
Brice-RX8
10-09-2005, 02:56 PM
If you get a high pitch whistle when applying the throttle, that is the sound a rotary makes, kinda like a supercharger, but only quieter.
tiggerlee
10-09-2005, 03:03 PM
I've been known to squeal when I push on the gas. ;) :D
MazdaManiac
10-09-2005, 04:09 PM
Actually, that is a bit of pre-ignition that happens when accelerate from idle and the ignition timing scheme switches.
There is a lot of initial ignition advance under light throttle (to make it "crisp").
This is "normal" and not an issue. Kind of a "fingernail-on-chalkboard" type of sound for about 1/2 of a second at most.
SilverrbRX8
10-09-2005, 07:15 PM
yes yes very high pitch...not totally unbearable just not sure if it is normal for the time being.....good to hear im not alone nad that its cool. thanks everyone!!!!
