srm858
10-07-2005, 10:02 AM
I have posted before about my sudden oil usage increase. Up to 18k miles, I was getting what seems to be the average of 3000 miles per quart. I brought the car in for the previous flash last spring when the car had 18k miles. When I got it back it idled roughly. The mechanic had no idea why. It then started using oil at approx. 1000 miles per quart. I now have 22k miles and the oil usage has stayed at the 1000 miles or less per quart. No changes in driving habits.
Also, I have noticed a drop in mpg. I was getting 18 to 19 mpg in mixed driving and 22 to 23 on the highway. Now I'm getting 17 to 18 in mixed and 20 on the highway.
Typically, I would expect a car that is now nicely broken in to have reduced oil consumption and slightly better mileage. The rough idle is annoying and is bad enough that it rattles the sunroof.
The dealer says nothing is wrong and won't even look at it. They checked the idle issue at the last recall and flash and said the new flash would fix it. It did nothing.
Any ideas out there as to what could be the issue? The car runs great and there are no oil leaks or tell-tale residue in the tail pipes. It has a new air filter and the oil is changed with Castrol 5-20 every 5k. I drive smoothly and do occassional high revs, but mostly shift around 5k.
At the spring dealer stop, when I got my car back it had a few miles put on it. I didn't think too much about it, because I figured they needed to test drive it. Is it possible that someone could have over revved the engine and done some sort of damage? I have not owned a rotary engined car before and I can't understand what is going on here.
