RX8 Lightweight Pulleys
Old Oct 7, 2005 | 03:40 AM
Erv187's Avatar
RX8 Street Racer
I was just wondering, if anyone that has installed lightweight pulleys, did you feel any big difference once the pulleys were installed?
Old Oct 7, 2005 | 10:48 AM
Fanman's Avatar
Have em' & they are worthless. Save your money & get a nice air intake, or hi-flow cat.
Old Oct 7, 2005 | 11:12 AM
Jaguar_MBA's Avatar
I have them also. I think they dynoed out at 1 HP gain by somebody else on the board. On a regular piston car these work just fine because they have a heavy harmonic balancer. The RX-8 does not. Reducing weight on the crank shaft increases HP to the rear wheels...or reduces inefficiencies that rob HP from the Rear Wheels. A standard harmonic balance on my 300zx must have wieghted ~ 18lbs and I replaced that with an aluminum unit that weighed ~ 4-5lbs or so. That is where the performance gain is to be had. RX8's underdrive crank pulley must weight ~ 1.25lb stock.
blainezoomzoomrx8
Sep 9, 2017 08:29 PM
UHATEIT
Dec 10, 2015 02:57 PM
Modified Dave
Sep 19, 2015 08:58 PM
rx8inator
Sep 1, 2015 07:18 PM
rx8inator
Aug 14, 2015 10:53 PM
