I gotta have one of these!
Old Oct 6, 2005 | 07:54 PM
SilverEIGHT's Avatar
I think I need one of these to drive to work! :D
Old Oct 6, 2005 | 07:55 PM
Theelectricchild's Avatar
Now all you need are spinners and you'll be the "undisputed king of the parking lot."
Old Oct 6, 2005 | 08:19 PM
juikster's Avatar
Im 8 drifting on a budget
definetly OVERKILL.
Old Oct 6, 2005 | 09:31 PM
legokcen's Avatar
The Turkish Delight
A .50 cal machine gun turret would make it better.
Old Oct 6, 2005 | 09:32 PM
oreo's Avatar
Just a question,
ARE THOSE THINGS REAL? I mean, Iv'e seen them on the net a couple of times and technically they are possible to make but is somebody actually selling those and if so, What is the porpouse? Other then prooving it can be done I see no practicality to them, even in mud or other terrain.
Also for them to work, the lower pulleys would need to be fixed to the chasis of the car , otherwise they would rotate and hit the fenders on the first bump they encounter.
Old Oct 6, 2005 | 11:36 PM
The are used in the Artic. Oil companies etc..
Old Oct 6, 2005 | 11:39 PM
juikster's Avatar
I think thoses tracks would'nt climb up inclines steeper than 48/49 degrees....but that pic is not in the truckers mag.,I'm sure...
Old Oct 6, 2005 | 11:46 PM
Cynic10508's Avatar
And there's a second one behind it. Notice the mystery fifth trend under the body and the other truck cab through the windows.
Old Oct 7, 2005 | 09:10 AM
midlifer's Avatar
Here is a site that sells them. Some pretty cool pics.
http://www.mattracks.com/index.htm
Old Oct 7, 2005 | 09:14 AM
lurch519's Avatar
www.evoperform.com
they reviewed those on either discovery or tlc, show was called "from tactical to practical" they raced a hooked up 4x4 with big monster tires (like 33's or 35's) and a regular 4x4 with the mattracks installed up a huge sand dune. the one on the mattracks won, easily.
Old Oct 7, 2005 | 09:40 AM
KYLiquid's Avatar
Oil Injection
pretty cool, will the fit the rx8 for winter driving. jk
Old Oct 7, 2005 | 10:08 AM
AKBen's Avatar
We had a brand new Yukon with matttracks sitting at the GM dealer up here last winter. Pretty cool. They sit a lot higher off the ground than it really shows in the pics. You can only go like 35mph and can't rally them too hardcore.
Old Oct 7, 2005 | 10:30 AM
Tigster's Avatar
RX8 ADDICTED!!!
I looked at getting these awhile back for a Jeep wrangler I had (for fun). The idea of these are to allow less weight per square inch on the tire thus keep the trucks "floating" on the surface not sinking into the sand or mud. I have seen guys purposely run over thier feet to demonstrate the weight per sq inch is very low. They are not intended for street use as the treads wear very quickly on the roads, but I think they are a great idea for trucks.
1.21 gigawatts!!!
Feb 14, 2019 03:23 AM
mariohardleft
Sep 13, 2015 11:17 PM
PlayInMyWoods
Aug 8, 2015 07:03 AM
Rambling Man
9
Jan 28, 2004 01:03 AM
