yiksing
10-05-2005, 08:33 PM
If u rev-match downshift, the blip wasn't enough for the shift. Are you destroying the synchro, the clutch or the gears in the transmission?
View Full Version : Transmission Damage yiksing 10-05-2005, 08:33 PM If u rev-match downshift, the blip wasn't enough for the shift. Are you destroying the synchro, the clutch or the gears in the transmission? QBallz 10-05-2005, 08:51 PM It's hard on the clutch and gears. Syncros are only used to sync the layshaft with the driveline. tuj 10-07-2005, 02:33 PM If u rev-match downshift, the blip wasn't enough for the shift. Are you destroying the synchro, the clutch or the gears in the transmission? I think you're asking if erroring on the lowside of the revs while rev-matching will cause any problems? The answer is not really. When you let out the clutch, the engine basically gets forced up to speed. Yes, this puts some stress on your driveline and your clutch, and no, it doesn't affect the syncros at all. Its generally better to error on the high-side of the revs when rev-matching as that extra engine speed will bleed off quickly. yiksing 10-07-2005, 07:19 PM Thanks for the feedback, I was kinda worried I might destroyed the gears while getting used to heel and toeing in the car. |
