Horsepower v Torque
Old Oct 4, 2005 | 03:31 AM
Muzz's Avatar
Horsepower v Torque
Hi,
Sorry to post what may be very obvious to a lot of people, but I often see various arguments/misunderstandings on torque/hp all over this forum and I thought this link gave a very good explanation.
http://www.v8914.com/Horsepower-v-torque.htm
Here's a little snippet for all of you lazy link clickers:
There is a lot of confusion about the relationship between horsepower and torque, I was guilty until I decided to do some investigating. Here is my summary.
Lets cut to the chase, in the context of this article it is torque and torque alone that accelerates a car. That's great you think, my big block sticks out 750lbf-ft of torque and that small high revving engine only puts out 250lbf-ft, I'll blow him away. Sadly its not quite as straight forward as that, there is a small caveat I did not mention, what I should of said was it's torque at the wheel and torque at the wheel alone that accelerates a car. All things being equal the car that has the most torque at the wheel will be accelerating harder. Well your first reaction may be 750lbf-ft is 3 times 250 so there is no contest, wrong. It's all about gearing, the best way to explain is an example, see diagram below.
OK, we have two engines both putting out 714hp, one makes 750lbf-ft at the engine and the other 250lbf-ft. The important factor is the speed at which the torque is made. The small engine is revving 3 times faster, so we can gear it down with a 3:1 ratio to achieve the same rpm at the output shaft (the wheels in real life). The consequences of this is the torque is multiplied 3 times, hey presto we have the same torque at the output shaft.
So after having said that torque alone accelerates a car, the torque figure is meaning less if we don't know at what rpm the torque is being made, this is where horsepower come in. Think of horsepower as a way of factoring in rpm to the torque equation.
You may be surprised, I know I was, but horsepower is simply a calculation based on rpm and torque. Dynos and rolling roads only ever measure torque. Horsepower is calculated after. Here's the formula:
Horsepower = Torque * RPM / 5252
So how is this formula arrived at, and where did 'horsepower' come from?
(I have no affiliation with this site )
Old Oct 4, 2005 | 04:00 AM
timbo's Avatar
rock-->o<--hard place
Good reference, Muzz
There was an interesting snippet in last Saturday's SMH 'Drive' section, which summarised the debate as follows: horsepower is what will get you to the hill first; torque is what will get you up the hill first
Old Oct 4, 2005 | 07:49 AM
Wildcard's Avatar
NT Rotorhead
I was going to try and explain it myself, but these guys do a better job than I ever could:
http://auto.howstuffworks.com/horsepower1.htm
Old Oct 4, 2005 | 06:24 PM
Revolver's Avatar
Shootin' from the hip
Too much for me to cope with in the morning while I've got a bad headcold.
Old Oct 4, 2005 | 06:29 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
It is a piddling exception barely worth mentioning but impellor based dynos do directly measure the work done over unit time, which is basically horsepower.
This is a great summary, btw. I came across it a couple months ago and was similarly educated.
OnebaddRx8
Aug 25, 2019 11:34 PM
crimson809
Aug 14, 2016 10:03 PM
FubarI33t
Sep 28, 2015 08:45 PM
