Clutch slipping ... How can you tell?
Old Sep 27, 2005 | 06:41 PM
psbjames1970's Avatar
Come Rain, come shine :-D
What are the symptoms? Is there a test you can tell?
Old Sep 27, 2005 | 06:49 PM
Brice-RX8's Avatar
If the rpm's go up and the car doesn't pick up speed it is slipping. Usually it is the upper gears (4,5,6) that will slip before the lower gears, since it takes more torque to turn those gears.
Old Sep 27, 2005 | 06:51 PM
Aseras's Avatar
put it in 3rd and let clutch out.. if it doesn't stall immediately it is slipping.
Old Sep 27, 2005 | 07:30 PM
so putting it in third while stop should stall it
Old Sep 28, 2005 | 07:30 AM
Brice-RX8's Avatar
I would suggest not doing it too often though, or you will end up killing the clutch.
theblinkof
Oct 4, 2023 05:24 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Kim Jong Illest
Sep 4, 2015 04:27 PM
