Metal vs. Rubber Valve Stems
Old Sep 25, 2005 | 10:21 PM
Cap's Avatar
Cap
At the risk of sounding stupid... Is there a performance difference between metal and rubber valve stems?
Old Sep 26, 2005 | 06:26 AM
pcimino's Avatar
They don't flex around. So I guess the rim would be easier to balance at high speed. But I can't imagine it's significant. Need to ask someone who speed balances tires.
One issue people have had with the aluminum, is they can snap off.
Old Sep 26, 2005 | 07:12 PM
bgreene's Avatar
Time of your life, kid...
The metal valve stems are part of the sensor units for the TPMS system, which intall onto the rims where normal valve stems would go in.
Probably about the only difference is that you won't have to deal with tire shops billing you for new stems when you get new tires put on.
Old Sep 27, 2005 | 07:02 AM
pcimino's Avatar
SSR Comps come with aluminum valve stems. I thought he was asking about aluminum vs rubber. Although if the question was "why does tpms come with aluminum" it's probably to keep guys at tire shops from ripping them out before taking the tire off the wheel.
Old Sep 27, 2005 | 03:39 PM
Nubo's Avatar
Lubricious
I've had valve caps with metal (brass?) inserts start to seize on the aluminum valve stem. I recommend sticking with caps which have plastic threads.
JimmyBlack
273
Feb 10, 2020 10:23 PM
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
Evan Gray
Nov 24, 2015 01:00 AM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
